Old 04-06-2011, 09:19 AM   #1
davemon OP
High Speed Airhead
Oddometer: 121
Airhead Rear Disc brakes
I realize the brakes on the airhead leave a lot to be desired but anyone figured out how to make the rear disc on a 77 R100S work? Caliper change?
Master cylinder change? Mine won't lock the rear wheel if I stood on it with both feet. Not really willing to go to drum but looking for a fix.
davemon is offline   Reply With Quote
Old 04-06-2011, 11:47 AM   #2
Hawk Medicine
Coyote's Brother
Oddometer: 3,304
77 R100S with a rear disc?
The "S" bikes were manufactured with drum rear brakes.
Hawkdude
Hate rots the pocket that carries it.
Hawk Medicine is offline   Reply With Quote
Old 04-06-2011, 01:01 PM   #3
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
Until 78.
www.wirewerkes.com
KILL YOUR TELEVISION !!!!
Old 04-06-2011, 07:53 PM   #4
supershaft
because I can
Oddometer: 9,116
It is a REAL job to get all the air out of that system. I suspect that is your problem. That and/or a shot rubber line.
Old 04-06-2011, 07:57 PM   #5
Boxer Metal
Mad Scientist
Boxer Metal's Avatar
Oddometer: 3,521
It could have been made from 9/77-12/77. The only way to get the rear disc to work is a smaller bore master cylinder like a 12mm. Modify the mounting to use an earlier K100 with ABS, R1100 or R1150 rear brake master cylinder.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 04-06-2011, 08:05 PM   #6
Reryder
Onward through the fog...
Reryder's Avatar
Oddometer: 1,399
New brake hose is a must on these old Airheads. The originals have all swelled up and choked the hole down the centre by now.
And that rear brake is a bitch to bleed for some reason. Taking caliper off and hanging it so rubber hose is vertical helps, as does a vacuum bleeder.
Can't remember exactly but I think there were two sizes of master cyl bore, the later ones being smaller and more effective. You can get the old ones sleeved to fit the later piston/seal.
'77 Harley Ironhead 6,000 miles across Oz
http://advrider.com/forums/showthread.php?t=527966
Reryder (AKA Hopper)
1977 Harley Sportster
81 BMWR100RS
01 HONDA VFR800
99 SV650
Ancient Harley 45, Snortster (Sporty engine in a Norton), Norton Atlas, Honda 350/4, Ariel HS scrambler
Reryder is offline   Reply With Quote
Times are GMT -7.   It's 09:10 AM.
