Old 06-10-2011, 08:23 AM   #1
JimVonBaden OP
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 51,489
NEW Maintenance/Repair/Accessory DVDs (need opinions)
OK, so I am about ready to do another BMW DVD. I am thinking about Repairs or Accessories (2 different DVDs).
Here are to rules:
Repair DVD:
  • Able to be done by the average home mechanic.
  • Typical issues, nothing rare or unusual.
  • Medium levels of difficulty
Accessories DVD:
  • Common accessory done to a BMW
  • VERY available items
  • Level of difficulty average for home mechanic/tech
Tell me what you think, what you would like to see, and give me links to products if you have one or more in mind.
By the way, I will be looking for volunteers for these projects. The benifits to you are free installation, credit, and a DVD of your choice.
I "may" purchase the needed items for "some" of the work. Definitely shop supplies and smaller components, no final drives, lighting systems etc.
If you live within striking distance of DC, you can get the work done at my place. If you come up with a great idea, but do not live close, and I use your idea, a free DVD of your choice will be given!
Thanks, I am looking forward to your input!
Jim
Old 06-10-2011, 10:41 AM   #2
jtbvaca
Oddometer: 27
DVD's
Jim, I have to tell you and anyone who is thinking about getting your videos. I have a 2011 R1200GS and not long after I got the bike I got your videos. I have the Cam Head video and the accessory video, I think those vidoes will save me alot of money because now after seeing the vidoes I am brave eonough to tackle the valve check/adjustment on my bike and just about all of the maintenance it needs. I already used the accessory video to help me install the ROX riser/bar backs, I did not realize how easy it was to lower the tubes so I can easily re route the cables. I must thank you for quickly responding to emails I sent you asking the many questions I tend to ask.
In short I must recommend the vidoes to anyone who is considering them!
jtbvaca is offline   Reply With Quote
Old 06-18-2011, 07:26 PM   #3
JimVonBaden OP
"Cool" Aid!
Oddometer: 51,489
Shirely some of you have some good ideas, right?
Jim
Old 06-18-2011, 07:38 PM   #4
flemsmith
lurk
Oddometer: 593
lowering the GS
Jim,
I'd buy one if it included details about what components are needed to lower a std GS. I'm getting ready to lower one for my wife, and just starting to look at what the options are.
Also, seems lie you'd have a ready audience for how to ad some things to RT's, like light mounting/wiring and best GPS mounting options.
roy
flemsmith is offline   Reply With Quote
Old 06-18-2011, 08:18 PM   #5
Jason1202GStime!
Jason1202GStime!'s Avatar
Oddometer: 251
Maybe you can have a section that touches on those parts that are always in the spotlight.
Just to name a few.
Final drive side seal replacement.
Signal switches repair. (I think this is made into stickies already)
Fuel pump leaking issues and replacement?
ops... did I just mention final drive?
Jason1202GStime! is offline   Reply With Quote
Old 06-18-2011, 10:28 PM   #6
gastone
R.I.P. sweet Angus
gastone's Avatar
Oddometer: 2,169
Jim,
I'd like to add some aftermarket shocks to my ride (Hyperpro). How about an install vid?
Garrett.
gastone is offline   Reply With Quote
Old 06-19-2011, 12:05 AM   #7
omeier
omeier's Avatar
Oddometer: 365
Jim,
I'd throwing diagnosing sticking brakes on there.
figuring out what was wrong with my brakes on my '05 gs took a while (and you're help!).
It ended up being a leaking master cylinder, but along the way I found a few other things to check, namely the pin that can get gunked up and causing sticking....
Edit: forgot to add, the busted micro-switch that can be a problem for the servo assisted ABS's. Also having gunk stuck inbetween the pistons and the caliper that can cause stickyness..
I'll think some more about things I've come across in the forum... Fortunately (or unfortunately) the leaky master cylinder was the only problem I had in the year or so I owned my '05 GS...
omeier screwed with this post 06-19-2011 at 12:02 PM
omeier is offline   Reply With Quote
Old 07-19-2011, 07:31 PM   #8
Monroe
Monroe's Avatar
Oddometer: 655
Jim
don't call me that, on a public forum
.....your videos to date have saved me major dineros at the dealer
Monroe is offline   Reply With Quote
Old 06-28-2011, 11:57 AM   #9
JimVonBaden OP
"Cool" Aid!
Oddometer: 51,489
Scheduled for this weekend filming, R1100/1150 Hall Effect Sensor (HES) replacement, possibly a rebuild as well.
Also scheduled, fuel line Quick Disconnect replacements, including R1200 Puel pump plate fitting replacement.
Still looking for more ideas!
Jim
Old 06-28-2011, 10:22 PM   #10
malloy
Oddometer: 720
JVB : How about these: bleeding, cleaning, maintenance and replacement of clutch slave; disconnecting the side stand safety switch; lubing drive shaft splines @ transmission end; replacing throttle cables; installing a power outlet plug; replacing the EWS ring and getting rid of those damn security screws. Pretty common, not too difficult with guidance. Love your stuff
F650GS (Build Date 11/11)
malloy screwed with this post 06-29-2011 at 04:15 PM
malloy is offline   Reply With Quote
Old 07-13-2011, 07:41 AM   #11
JimVonBaden OP
"Cool" Aid!
Oddometer: 51,489
Filming for the quick disconnect install and the HES install are complete. I plan to rebuild the old HES as well.
If you live nearby, and wish to do some repairs or accessories, let me know, maybe we can help each other out.
Jim
Old 03-21-2012, 10:50 AM   #12
khale
ride dirty
khale's Avatar
Oddometer: 557
+1 on this
Throw in changing rear main output seal, transmission seal and final drive seal. A huge and heavy job, but would save us lots of $$, as I had to have the job done myself.
Clutch replacement
2013 BMW R1200 GSW | 1972 BMW R75/5 toaster | 2011 Husky TE310
"4 wheels move the body, 2 wheels move the soul"
khale is offline   Reply With Quote
Old 07-13-2011, 08:10 AM   #13
Boxerwrench
Boxerwrench's Avatar
Oddometer: 106
Need more exposure of 1100 & 1150RT's
GS's are fine but there are some differences from RT's.
(Ya, I know this is a GS place but not all readers have one.)
A whole lot of tupperware for a newbie to figger how best to remove.
Like my tank is plastic and the location of fuel filter/ level float is in a different place in the tank. ABS reservoir is under the tank.
Getting the 1100RT fuel guage to show all the bars.
Changing the RT charcoal filter.
Installing an HID system.
Dimming down the HI beam indicator light.
Replacing/ upgrading headlight bulbs in RT's
aiming RT light.
Replacing a leaking final drive large seal.
Installing peg lower kit
Installing floor boards.
retrofit an RTP oil fan system.
Just off the top of my head.
Changing a tire on an alloy rim and a spoked one.
2000 R1100RT, Opel blue
2006 Zuki C50 w/ modified C90 drive.
Boxerwrench is offline   Reply With Quote
Old 07-16-2011, 01:16 AM   #14
Just Paul
Pro Cat Herder
Just Paul's Avatar
Oddometer: 2,099
when I had my 1200 GS I bought your video and loved it.
Now I have a KTM 990 adventure and would love your product.
The bike is complicated to work on and your video would sell well I believe.
Honda 450X (plated)
KTM Adventure S
Paul's SPOT TRACKER
“The world is a book and those who do not travel read only one page.” – St. Augustine
Just Paul is offline   Reply With Quote
Old 07-16-2011, 09:13 PM   #15
JimVonBaden OP
"Cool" Aid!
Oddometer: 51,489
I wouldn't mind doing a KTM. I would need a KTM guru and a bike to do it on.
Jim
Times are GMT -7.   It's 04:07 AM.
