Old 08-16-2011, 07:34 PM   #1
El Borracho OP
sheperd
El Borracho's Avatar
Oddometer: 18
Question Plugging a tire
As a noob, this may be a silly question, So I humbly seek advice from those of you who may have the knowledge.
I found a nail in my rear tire today.
Rode home slowly and just am wondering, should I buy one of those plug kits to repair it?
Seems like a failure of the repair job would be ugly!!!
I am not independently wealthy, but I have a long ride coming up this weekend.
Tire is a tourance with 1500 miles on it.
El Borracho is offline   Reply With Quote
Old 08-16-2011, 07:46 PM   #2
Bigger Al
Still a stupid tire guy
Bigger Al's Avatar
Oddometer: 7,898
What kind of bike? Is the tire mounted tubeless? If not, then no, you can't plug it.
Plugging a tubeless tire is perfectly acceptable.
"I'd rather wake up in the middle of nowhere than in any city on Earth."
Steve McQueen
Bigger Al is offline   Reply With Quote
Old 08-16-2011, 07:55 PM   #3
El Borracho OP
sheperd
Oddometer: 18
The bike is a 1200 GSA and the tire is tubeless.
Any plug kits that you recommend?
Also any other tips are appreciated.
Thanks and thanks
Old 08-16-2011, 08:05 PM   #4
hugemoth
hugemoth's Avatar
Oddometer: 2,787
I've plugged many tires with the "sticky rope" type plugs and have never had one fail. YMMV. Just follow the instructions on the package.
Old 08-16-2011, 08:12 PM   #5
GreaseMonkey
Preshrunk & Cottony
GreaseMonkey's Avatar
Location: The only county in Illinois with no train tracks
Oddometer: 5,288
Go ahead, get a kit and make sure you read the instructions, and get an air pump (there are quite a few people who like to get the $10 slime pump from Wal mart and take all the plastic bits off so they get pretty tiny) and go ahead and ride.
With any new tire repair, it is a good idea to check the tire pressure a few times for the first couple of days. It may lose a couple pounds while the string seats in but it should be stabilized after a day. If not, redo it IMHO.
GreaseMonkey is offline   Reply With Quote
Old 08-16-2011, 09:18 PM   #6
Flashmo
Whatever...
Flashmo's Avatar
Oddometer: 2,562
+1 on every word GM said.
I have NO issues with plugging my tires with the sticky strings and riding them to the end of their useful life.
Flashmo is offline   Reply With Quote
Old 08-16-2011, 08:19 PM   #7
El Borracho OP
sheperd
Oddometer: 18
Thumb Thanks one and all
Thanks to all for advice.
I will repair it and ride.
Camping at Big Sur this weekend with old high school buddies ( about 450 miles round trip ) so I wanted to be sure about the repair.
Anyhow, Thanks again
Old 08-16-2011, 08:55 PM   #8
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 51,552
http://www.jimvonbaden.com/Tire_Plugging.html
No worries!
Jim
JimVonBaden is online now   Reply With Quote
Old 08-16-2011, 09:02 PM   #9
El Borracho OP
sheperd
Oddometer: 18
Originally Posted by JimVonBaden View Post
Thanks for the great demo Jim!!
Old 08-21-2011, 06:16 PM   #10
ibafran
villagidiot
Oddometer: 1,287
Nice production, Jim.
And I agree with everything posted.
However, rider may want to consider some tweaks to this operation.
I didn't get a reall good look at Jim's sticky string insertion tool but I suspect that it is of the 'buttob hook' design. I have had the hook snap off inside the tire and think that the design is weak. Therefore, I recommend the 'tweezer' design. It is more robust and about as bullet proof as you can get. Also, Jim's tools have the screwdriver type handles. Some tire are unbelievable tough and that type of handle just doesn't cut it. My tools have a 'T' handle.They don't pack as nice as the others. I cut about an inch off each end to make them more compact. Works great for me.
The downside to the tweezer tool is that the sticky string may be inserted too far and come out of the tweezer uselessly on the inside of the tire. What happens is that the rubber cement acts like a lube. And when the string gets to the inside of the tire, it suddenly slides too good and too fast to keep the whole string from going inside. There are several ways to avoid this problem. My fav way is to clamp a small pair of vice-grips (usefull to get the nail out too) to the tweezer tool shaft causing the tool to stop before the string disappears into the tire. Pretty much idiot proof and it gives me a two-handed grip on the tool if I need it.
Some other pointers: Carry a big tube or two of glue. There is no such thing as too much glue. Pack it in a zip-lock bag so if it busts, you don't have a mess in your kit. Carry at least a dozen sticky strings. If you have a choice between red and black, the red are better and the black are fine. If you are going on an expedition, buy new glue for the trip, even more strings; and add them to the stuff already in your kit.
DO NOT trim the string flush with the tire. Trim it off about 1/8 inch long. The end will sort of mushroom over and help keep the end of the string from working into the tire while the glue sets up good.
Do not pull the puncturing object until you test that it is indeed leaking. Mark the rim at a non-active leak with a bit of duct tape so that you can find it again while you look for another puncturing object that is probably the active leak. Plug active leaks first, duh.
Do not pull the puncturing object, if any, unless you have the reamer in hand for immediate insertion into the hole. Some holes are so small that if you take your eye off it, you play hell trying to find it for the reamer.
Do not take the reamer out of the tire until you are ready at hand to insert the sticky string.
Sticky string can be doubled over or two or more strings added to the tweezer to plug larger holes. (Let's see 'em do that with that Stop&Go stuff.)
If you are in the boonies, plug a sidewall hole anyway to get to safety and then replace that tire asap. Pick a safe place to make tire repairs if possible. Right next to the side of the highway after a blind curve or hill, is not optimal especially after dark. Nor is it a good idea to do the work in the bottom of a wash or gully. Working with poisonous snakes, fire ants, and large carnivors in the vicinty isn't optimal either. If you ride with ear plugs/music, take that shit out so that you can hear stuff coming.
It helps if your tire repair kit has its own bag. Thus, when you need it you don't have to unpack the whole bike to gather everything that you need. My tire repair kit also has a couple of bandaids, small flash light, insect repellant, and a very small mister of soapy water to test the plug (saliva works about as well as soapy water for a test), and a bit of bar soap in case I need to make up a lot of soapy ditch water to find a leak.
That's all that comes to mind at the moment.
"beware the grease mud. for therein lies the skid demon."-memory from an old Honda safety pamphlet
ibafran is offline   Reply With Quote
Old 08-21-2011, 06:36 PM   #11
Lone Rider
Registered User
Oddometer: 25,130
Originally Posted by ibafran View Post
... Nor is it a good idea to do the work in the bottom of a wash or gully. Working with poisonous snakes, fire ants, and large carnivors in the vicinty isn't optimal either. If you ride with ear plugs/music, take that shit out so that you can hear stuff coming.....
You guys are so anal, thinking you've crested the mount....
How should a BWM rider wipe his or her butt when needing to take a dump in the woods?
This is plugging a tire, using a system that's worked for upteen years.
Afterwards, you sould wash your hands with 'x' cleaner, and don't forget about your nails, unless your wore latex gloves. The best gloves for repairing a tire on a BMW bike are 'x'. I always carry 'x' pair of these and keep them in a special place.
Lone Rider is offline   Reply With Quote
Old 08-21-2011, 07:32 PM   #12
shu
Oddometer: 996
At least the rest of us added something constructive, unlike your spew, eh?
..........shu
shu is offline   Reply With Quote
Old 08-16-2011, 09:20 PM   #13
shu
Oddometer: 996
Yes, get the 'sticky worms' kit and follow the directions. Use the glue provided.
Actually, the sticky string is not going to fall out, they get hot as you ride and bond to the tire, so failure mode would be a small leak not a sudden loss of air.
My opinion, and my experience with 3 plugged tires.
...............shu
Old 08-17-2011, 02:04 PM   #14
LittleRedToyota
Yinzer
LittleRedToyota's Avatar
Oddometer: 2,232
all my bikes have always used tubed tires, so no plugs in those.
but i have plugged more cage tires than i can remember (all with the self-vulcanizing plugs...no glue). only ever had one fail...and that "failing" was a very slow leak--had to make sure to put air in it about once a week.
if you are uncomfortable about the plugs, though, you can remove the tire from the rim and patch it from the inside "the right way". they sell those kits in auto parts stores, too. (it's kinda like an innertube patch, but you put it on the inside of the tire instead of the outside of a tube.)
LittleRedToyota is offline   Reply With Quote
Old 08-17-2011, 02:50 PM   #15
mjydrafter
evil boy for life
mjydrafter's Avatar
Oddometer: 4,102
As a goodyear certified tire jocky and retreader, the super preferred method is to plug (seals the cords from water & corrosion) and a patch on the inside (seals the liner). This is for truck tires BTW... should be major overkill for autos and cycles.
That said, I think I have plugs without patches in about 4 of the 8 cage tires between the wife and I.
Plug away.
Some companies make some fancy rubber plugs, but like many above, I have nothing bad to say about the sticky ropes. Plus you can find them anywhere.
1974 Suzuki TC-185 (The little 10 speed)
1986 BMW K75c
Yes! Whenever bicycles are broken, or menaced by International Communism, Bicycle Repair Man is ready!
mjydrafter is offline   Reply With Quote
Times are GMT -7.   It's 03:45 PM.
