01-05-2012, 06:22 AM
#1 |
Oddometer: 60
2011GS..GPS recommendations?
I have a new 1200GS and need a GPS, need some recommendations on GPS units, mounting, and wiring.
Thanks in advance. |
01-05-2012, 07:22 AM
#2 |
Runs with Scissors
Oddometer: 871
I got a 550 mounted to the lower bar of the windshield support
Power routed to Centech Fuse Panel Easy reach and readable I'll try to add a picture later
2011 R1200 GS Adventure Smoke Grey Metallic Matt 2009 G450X White IBA #35651 |
01-05-2012, 07:42 AM
#3 | |
Dumba$s Jarhead
Oddometer: 2,950
If you want just a GPS go with the Garmin Montana. It will still speak to your headset with a bluetooth dongle but wont play MP3s or radio. you can wire it directly to your battery or through a fuse block of some sort.. centech etc. You really need to give more information on what you want it to do, where you plan on using it, how you plan on using it, and you would be beter off asking in the "laying down tracks" forum.
We are enmeshed in the cancerous discipline of "security." And in the worship of security we fling our lives beneath the wheels of routine - and before we know it our lives are gone. There is no diagnostic computer for the female mind... The Simpsons 2013 |
01-05-2012, 08:51 AM
#4 |
Oddometer: 828
I had a Zumo 550 on my old '06 GS mounted to the left handlebar, but when I picked up my '10 GSA I got a Zumo 66 and mounted it like so:
![]() I really like the position and it could all be done with the mounts and wiring that came with the Zumo, so nothing else was needed.
“If you are neutral in situations of injustice, you have chosen the side of the oppressor. If an elephant has its foot on the tail of a mouse and you say that you are neutral, the mouse will not appreciate your neutrality.” Bishop Desmond Tutu 2010 GSA |
01-05-2012, 10:25 AM
#5 |
Smile 4 Miles
Oddometer: 1,376
"Best Mount" for GPS :-)
I tried many different mounts, this is the best (4me):
RAM-Mount with original Garmin Nuvi 550 cradle (not the one sold by RAM). No vibration. The Garmin cradle allows you to insert the power plug (mini USB) in the GPS before inserting the GPS in the cradle. With the RAM cradle you have to plug in the cable in the back of the GPS after inserting the GPS in the cradle: Painful! Used a rubber cable insulation (removed wire) and pushed the metal clamp through it: ![]() Also painted the nuts black matte so there are no reflections when looking at the instrument cluster: ![]() ![]() No vibration and GPS can be adjusted so it won't cover anything. I like it. ![]() iPhone 4 picture tallguy-09 screwed with this post 01-05-2012 at 10:30 AM |
02-10-2013, 12:40 PM
#6 |
Oddometer: 241
I've mounted my Zumo 660 like this and the windscreen bracket has brocken twice now within a short time. Has anybody else had this problem?
Any advice? Thanks.
1998 KLR 680C; to many mods to list. 2007 BMW 1200GSA. |
02-10-2013, 06:42 PM
#7 |
"Cool" Aid!
Oddometer: 41,921
![]() ![]() ![]() Jim
02-10-2013, 07:42 PM
#8 |
Retarded User
Oddometer: 586
There is a whole AdvRider sub-forum dedicated to GPS's at,
http://advrider.com/forums/forumdisplay.php?f=75 Lots of answers and probably the best place to search. My particular unit is a Garmin 376C (a lucky and inexpensive find for $150), but it is older and no longer supported by Garmin. Nevertheless, some consider these Chartplotters (276C, 376C, 478, etc.) as the off-roading gold standard because they are tough, have buttons and have big screens. I also use a Ram mount and like the vibration isolation of the rubber they use. I hope my gps lasts a long time. It works very well. YMMV.
Sticks and stones, love. 2011 BMW R1200GS, 2004 KTM 950, 1996 ATK 605 ESDS |
01-05-2012, 10:38 AM
#9 |
Oddometer: 207
Depends on how much off road riding you'll be doing. The Zumos and Nuvis do not handle tracks very well, which is an essential feature off road.
I bought a garmin montana and the AMPS mount for it, then the RAM amps mounting kit. The AMPS mount comes with power cables, and I bought the 'repair' plug from BMW, spliced the wires together, and connected it to the GPS plug under the steering head. (That page is slightly out of date - on 2011/12 GSes the plug is right under the beak and easy to get to without taking any body work off) The mount is quite nice- it snaps right in and uses open contacts for power and data instead of a cable, so you don't have to plug/unplug anything to remove it. I suck at wiring things and had to cut a few crimps back off because I forgot to put the heat shrink on first The Montana is nice because it handles tracks and routes easily, and you can add your own maps to it (as you can on most Garmin devices). I have two profiles set up- on road and off road. On road uses city navigator maps and a 3D view, where off-road uses USGS 24K Topo maps from a top-down perspective and shows me my current track on the map. But, it doesn't have bluetooth or store MP3s, so it's a GPS and only a GPS. Also, we have a specific forum for your question, so you might want to try there: http://advrider.com/forums/forumdisplay.php?f=75 |
01-05-2012, 01:22 PM
#10 | |
Just Lookin'
Oddometer: 303
http://sites.garmin.com/montana/
'00 BMW R1150GS -- '07 TRIUMPH SPEED TRIPLE
01-05-2012, 12:23 PM
#11 |
Oddometer: 60
Tallguy09...where did you get your ram mount if it is not made by Ram?
01-05-2012, 02:17 PM
#12 | |
Smile 4 Miles
Oddometer: 1,376
If you need tracks then get a different GPS. Garmin GPS: http://www.gpscity.ca/garmin-nuvi-550-automoto-kit.html Shows Garmin cradle with +12V charger. $33 at Amazon: http://www.amazon.com/Garmin-010-111...5801702&sr=1-3 or here: http://www.gpscity.ca/garmin-nuvi-5x...and-power.html
01-05-2012, 08:11 PM
#13 |
Resident Raggamuffin
Oddometer: 1,705
I have the same exact setup as Tallguy but mine I mounted on the handlebar. The Nuvi isn't very sophisticated but it seems to offers enough for most on-road travels, and it comes at a very attractive price.
2012 Ducati 1199 Panigale 2012 Ducati MTS1200St Ti 2003 Aprilia Tuono Racing 2012 Vespa 300 Super past: Ducatis, Aprilias, Moto Guzzis, a Husky, and some BMWs as well. |
01-06-2012, 05:49 AM
#14 |
Adventure Seeker
Oddometer: 527
Had a Zumo, what a POS. sure you could listen to music and chat on your phone, which will be needed btw to ask for directions when the Zumo ultimately gets you lost.
Seriously though, the Zumo is more of an entertainment center than a navigational device. The resolution is terrible, it simply paints a magenta line on a beige background unless you are zoomed all the way in, no customization of features and all in all, a very expensive and frustrating experience. Garmin seems to be the best of the worst unfortunately and I currently ride with a Montana. Although it is still a Garmin with their usual frustrations, in terms of actual navigation, customization, resolution and overall features, I would not even compare it to the Zumo. Btw, I have mine mounted above the instrument cluster dead center just a few inches below my line of sight. The eyes do not come off the road to see it.
"The trouble with quotes on the Internet is that you don't really know if they are accurate" - Thomas Edison- |
01-06-2012, 08:09 AM
#15 |
Oddometer: 576
Hmmm... Hasn't been my experience. I have been pleased with my 665 and have used it to get me through anything from large cities to Colorado fire roads. Maybe I am just unaware of other possibilities out there, but the Zumo has got me there and back without issue. |
