Old 01-13-2012, 09:51 AM   #1
Yardstick OP
Hydrophobic
Yardstick's Avatar
Oddometer: 3,012
Fastway Adventure Footpegs - Big Thumbs Up!
There are a lot of footpeg options for the big bikes right now and I probably over-analyzed each one. Do I trust the small hardware used in the add-on type for the kind of riding I do? Is there enough grip? Is the peg TOO grippy or dangerous if I fall? Will the peg fold up enough to keep from ripping the footpeg mount off the frame? And on and on... It came down to a couple of choices - stay with stock or find more stock footpegs or a couple sets of Fastways to make Frankenpegs. Then I found the Fastway Adventure Footpegs.
I e-mailed Pro Moto Billet/Fastway to express my concerns about their footpeg being aluminum and about the amount they fold up. A couple hours later I had a reply addressing my concerns and a request to call in if I had any more input. I called. After hearing how much thought and actual engineering (and some build 'n' break methodology) went into these, I was convinced. PMB/Fastway also has the ability to tweak the design as necessary down the road since they manufacture these in-house!
I got the pegs last night and loctited all the pins in. Unfortunately I didn't have a lot of time (or light) this morning and the pictures I took didn't all come out very well. Here are what I did get (more later and/or on request!).
Compared to stock. These guys have actually done some Finite Element Analysis to try to optimize the strength of the pegs.
Mounting these is a WHOLE lot easier than the stock pegs. Also, check out the shape. They have a 45-degree cut at the rear, close to the mount, to provide extra clearance when folded up. The front, outside corner is rounded which should help to keep it from hanging up on things.
They fold up pretty well. In the low/back position shown here, there is no contact between the pins and brake pivot area yet. I think there is even a little room for improvement here by shaving the stop you can see in the first picture.
I just wanted to give a big thumbs up for the Fastway Adventure Footpegs and the guys at PMB/Fastway. I'm not easy to convince or to please when it comes to aftermarket stuff but these guys have done a great job with these pegs.
Yardstick is online now   Reply With Quote
Old 01-13-2012, 10:13 AM   #2
xcflyn
xcflyn's Avatar
Oddometer: 1,138
Nice write up with pics . I have been on the fence for a while. I loved pivot pegs on other bikes but would like to support CJ and run add on's. Now I have a 3rd choice to consider-fastway.
xcflyn is offline   Reply With Quote
Old 11-15-2012, 08:55 AM   #3
Splisken
I'm not dead yet...
Splisken's Avatar
Oddometer: 127
Hi Thanks for the write up. I own Fastway Evo2 pegs for my EXC and agree that they build quality equipment. I have been pondering these Adventure pegs for my SE but I would need to mount them in the "LoBoy" position. Would you be able to add any information on how well they fold in this position or how much lower they sit? My EVO2s dropped my feet roughly .75" at least in practical leg position if not actual vertical height. I measured it at my knee vs the tank while sitting on the bike.
It appears from the pictures that you are using the "LoBoy" position is why I ask...
One additional tip...I believe the springs are intended to go inside the frame mount (I notice you have the top over/on the mount). You will avoid a lot of wear on the frame mount by squeezing it inside and get a bit more resistance from the spring...at least if it works the same as the EVO2s.
Splisken screwed with this post 11-15-2012 at 09:01 AM
Splisken is offline   Reply With Quote
Old 11-15-2012, 02:26 PM   #4
snowhawk jockey
Slack Jaw Gaper
snowhawk jockey's Avatar
Location: The other Center of the Universe: Bend, Oregon
Oddometer: 1,115
Nice write up!
Those look the treat.
Better than the all billet alu ones I keep seeing.
snowhawk jockey is offline   Reply With Quote
Old 11-15-2012, 04:06 PM   #5
Yardstick OP
Hydrophobic
Yardstick's Avatar
Oddometer: 3,012
In the pic where I show the peg folded up, that's about the same angle as stock. Since the peg is longer it does stick out more when folded.
I should have measured from the floor to the peg when I switched them to get a good comparison of drop. It's somewhere in the neighborhood of 1/8-1/4 inch at the peg. I'm running the longer traction pins (set screws) so they're probably closer to the stock height than they could be with shorter pins. I really don't notice that much difference, but I'm probably just not very sensitive to it. They are a BIG platform to stand on. That is something I notice in a big way. I have these on my 990 R and I keep thinking I need to order a second set for my SE!
On the spring, I remember trying it both ways and the way I have it seemed to work the best. There wasn't quite enough space to get them totally inside the footpeg bracket.
Originally Posted by snowhawk jockey View Post
Nice write up!
They are billet aluminum, actually. I really like the design of these pegs. It seems like a lot of thought went into them.
Old 11-15-2012, 04:32 PM   #6
BIG-E
AKA; Mongo-E
BIG-E's Avatar
Oddometer: 2,054
Hey Allen,
Are these the ones from KTM Twins for $270ish? Dillon just ordered mine in orange of course! I know, they will get all scrached up, but hey, I never fall!!
See you soon Brother, Eric.
"If my Technique Improves, so will my riding"!
BIG-E is offline   Reply With Quote
Old 11-15-2012, 04:35 PM   #7
Yardstick OP
Hydrophobic
Yardstick's Avatar
Oddometer: 3,012
Originally Posted by BIG-E View Post
Hey Allen,
Those are the ones! You're gonna like 'em!
Old 11-15-2012, 05:10 PM   #8
FakeName
Wile E Coyote SuperGenius
FakeName's Avatar
Oddometer: 1,777
On my EXC, I use the long spikes in the back, and short ones in the front. Fits the curve of the bottom of the boots much better.
These are on the growing list of future farkles.
2011 White 990 Adv S
2014 500EXC Black
FakeName is offline   Reply With Quote
Old 11-15-2012, 07:14 PM   #9
soupbone
soupbone's Avatar
Oddometer: 136
must have!
those are a necessity. as i stand quite often, even when riding on the street. being able to move your feet around on the pegs is +1 also.
soupbone is online now   Reply With Quote
Old 11-15-2012, 08:17 PM   #10
booger1
booger1's Avatar
Oddometer: 835
I don't think I would have ever bought them do to the price, but I bought a bike with them on already and now, I don't think I ever want a bike with out them, there an awsome add on.
Eating_goat_with_the_Cartel , Never_ventured_never_gained
oncostaricantime , boundlessbooger , 1998xr400buildwithe-start
Good judgment comes from experience. Experience comes from bad judgment - Mark_Twain
booger1 is offline   Reply With Quote
Old 11-25-2012, 10:31 PM   #11
Splisken
I'm not dead yet...
Splisken's Avatar
Oddometer: 127
Thanks for the extra info Yardstick. These are on my list for sometime in the next few months. I'm spending a ton on the SE right now not to mention shop time. Once I catch up to what I've got on hand I can add some more I figure those pegs and the Renthal Ricky Carmichal Fatbar (big rise) I have to put on should fit me really well (6'5") and improve riding comfort and control greatly.
Old 11-26-2012, 10:38 AM   #12
wreckinshop
super enduro
Oddometer: 53
old style
I have the old style fastways and they are awesome!! I just bought a 990r with pivot pegs on them and I hate them, they are to narrow for offroading.
wreckinshop is offline   Reply With Quote
Old 11-26-2012, 08:08 PM   #13
jsg161968
daydreamer
jsg161968's Avatar
Oddometer: 13
Sweet
These pegs are way nice for sure. I got these pegs because they run lo-boy and I'm 6'3"
jsg161968 is offline   Reply With Quote
Old 12-10-2012, 09:22 PM   #14
fastdirt505
Oddometer: 70
I just got mine and love them. I'm a huge fan of lower pegs and these are so comfortable standing up that I feel like I'm on flat ground. With the 950 being wider than a 450 bike these give you plenty of room. They did get me one time when dabbing my foot down to prevent a slide out. I'd love to put them on my 250. I might try it and see if it works.
The boots are empty and just sit there even all the way out at the end.
Brian
Erzberg SE 950R and a KTM 250SX
http://www.youtube.com/fastdirt505
fastdirt505 is offline   Reply With Quote
Old 03-20-2013, 09:20 AM   #15
zeropoint
Oddometer: 134
Just received mine. Can anyone tell me what this part is ? There was only one. Should I have two ?
2011 990 Adventure
zeropoint is offline   Reply With Quote
Times are GMT -7.   It's 12:16 PM.
