Old 02-06-2012, 05:21 AM   #1
Knobbiethrower OP
ADV in ADK
Knobbiethrower's Avatar
Oddometer: 1,339
Fuzeblock FZ1 mounting
Looking for ideas/suggestions for location and mounting this fuseblock on a 990 adv
http://blackdogadvbikes.com/black-do.../275-1152.html
Thanks in advance!
2013 KTM 990 ADV
2011 HUSABERG 570
Knobbiethrower is offline   Reply With Quote
Old 02-06-2012, 07:05 AM   #2
Dagwood_55
Dagwood_55's Avatar
Oddometer: 1,357
I put mine in the glove box between the tanks.
Live long, love much, laugh often, and
Ride, Ride, Ride.....
Dagwood_55 is offline   Reply With Quote
Old 02-06-2012, 07:22 AM   #3
mOtO_man
mOtO_man's Avatar
Oddometer: 11
my Fuzeblock mount
I put in on the right of the bike. Had to cut out some plastic on the inside of the right fairing for it to fit. The benefit of it being here is that it can easily be accessed and viewed. It did not go in the glove compartment because all the wires would have had to be removed to remove the glovebox....a pain for doing maintenance.
mOtO_man is offline   Reply With Quote
Old 02-06-2012, 02:42 PM   #4
torinreality
metaconscious
Oddometer: 57
Originally Posted by mOtO_man View Post
...It did not go in the glove compartment because all the wires would have had to be removed to remove the glovebox....a pain for doing maintenance.
I put mine in the glovebox, too, but I went to some effort to ensure I could remove the Fuzeblock without unwiring anything. Unfortunately the bike's in storage, so I can't post pictures right now, but here's a description of what I did:
1) Cut a hole in the bottom of the glovebox...bigger than the short dimension of the Fuzeblock ,but smaller than the long dimenion. This means the Fuzeblock will slip through the hole, but only sideways.
2) Fabricate an aluminum mounting plate that's bigger than the Fuzeblock in only the long dimension. Thus the mounting plate will also slip through the hole, but also only sideways. The extra aluminum along the two Fuzeblock sides gives me something to mount to the glovebox.
3) Mount Fuzeblock to plate with stock Fuzeblock mounting points (underneath).
4) Bolt mounting plate to bottom of glovebox using Dzus fasteners (with standard sportbike bodywork clips that grab the plastic glovebox bottom).
I'll try to take pictures and post them. If you're interested in the above and my description doesn't make sense, message me.
torinreality is offline   Reply With Quote
Old 05-27-2012, 04:32 PM   #5
CharlieFox
Oddometer: 199
Have taken any pics of your install?
CharlieFox is offline   Reply With Quote
Old 05-29-2012, 09:50 AM   #6
75monza
75monza's Avatar
Oddometer: 354
+1
This is exactly what I did. You can strip all the plastics and the tank from the bike and not have to undo any wiring at all.
I am weird. I use my glove box for storing little things like my parking pass and holding onto my phone or what not if I need to charge it.
2006 KTM 950 Adventure - Go Everywhere Bike
1993 Suzuki GSX1100G - Street Touring Shafty
2000 Suzuki DR200 - A Little Smaller
75monza is offline   Reply With Quote
Old 01-26-2013, 01:00 PM   #7
EZ300
EZ300's Avatar
Oddometer: 1,161
Wiring up my fuzeblock and don't know which wire to tap into for switched power.
Anybody got a pic or can you point me in the right direction?
.... Is Acc 2 only hot when key is on?
EZ
EZ
AMRA
2007 KTM 990 Adventure
2010 KTM 530 XC-W Six Days
www.rockstarsmc.com
EZ300 screwed with this post 01-26-2013 at 01:13 PM
EZ300 is online now   Reply With Quote
Old 01-26-2013, 06:53 PM   #8
batovif
batovif's Avatar
Oddometer: 48
EZ
ACC2 is switched and ACC1 is always on.
batovif is offline   Reply With Quote
Old 01-28-2013, 05:11 AM   #9
Sporting Wood
I <3 Energizer Bunny
Sporting Wood's Avatar
Oddometer: 896
With 2 accessory circuits already built into the bike, I'm sorta wondering why there's a need for a fuse block?
Is this just a BMW thing?
Can a mod move this to GSpot?
Sporting Wood is offline   Reply With Quote
Old 01-28-2013, 07:41 AM   #10
EZ300
EZ300's Avatar
Oddometer: 1,161
It simplifies the wiring process when running multiple accessories.
Gps, additional lights, heated grips, heated clothing,...
BMW thing?,...
EZ
AMRA
www.rockstarsmc.com
Old 04-03-2014, 02:12 AM   #11
Roeligan
Belgium power!!!
Roeligan's Avatar
Oddometer: 539
mounting
work in progress, but this is what I'm doing:
used the aux switched too to switch the power.
Mainline directly from pos plug right side of the bike (still needs a single connector attached).
Running the ground to the frame.
Connects:
  • heated grips
  • aux lights
  • gps
  • tripy (electronic roadbook)
  • hazard light blinkers controller
  • 1 spare atm
KTM 990 Adventure (Stealth one ; 2008-), now S-d & Beta 350 RR 2013 to play with
Suzuki DL-1000 V-Strom (2004-2008) and Suzuki GSF 600 Bandit (2002-2006)
www.roeligan.net
Roeligan is offline   Reply With Quote
Old 04-03-2014, 04:33 AM   #12
Orangecicle
On a "Quest"
Orangecicle's Avatar
Oddometer: 3,278
I put mine in the glovebox. That has worked out fine. The only concern that I had was working around the wires in a "field" repair. But even that has worked out. Here I am stripping the bike in Colorado to fix the carbs. I just used a strap to hold up the glovebox as I worked on the carbs. No real problem at all.
Orangecicle is offline   Reply With Quote
Old 02-06-2012, 07:29 AM   #13
Motard_Menace
Motard_Menace's Avatar
Oddometer: 333
The nine-fifty I just purchased has the fuse block behind the upper headlight/fairing assembly. There is quite a bit of room up there. It is similar to the pics posted but the previous owner fasted it with zip ties on the inside of the bracket. I will try to get some pics later and ad them to the this post for reference.
Here is a pic for the placement of the fuse block that was on my bike when purchased. Not as fancy as the ones on here but an old CanBus setup.
Photobucket
Motard_Menace screwed with this post 02-07-2012 at 12:06 PM Reason: Added Pic
Motard_Menace is online now   Reply With Quote
Old 02-06-2012, 02:05 PM   #14
PS-RagE
PS-RagE's Avatar
Oddometer: 674
I also put mine in the glovebox:
A. Dale McLean
aka PS-RagE
2007 Beta REV3 270
2012 KTM 350 EXC-F
2014 KTM 1190 Adventure R
PS-RagE is offline   Reply With Quote
Old 02-06-2012, 02:45 PM   #15
torinreality
metaconscious
Oddometer: 57
I love the Fuzeblock, BTW. So awesome to be able to change circuits from switched to "always on" and back again.
Times are GMT -7.   It's 10:21 AM.
