Old 03-02-2012, 05:50 PM   #1
FlatDarkGS OP
Master BS'er
FlatDarkGS's Avatar
Oddometer: 160
Harmonizer Suggestions
I recently purchased a Harmonizer so that I could balance the throttle bodies on my 2011 1200GS. When it was time to do the deed for the first time, everything went very smoothly and I followed the instructions per JVB's camhead DVD (minus the fans...my temp did go up to six bars whereas its normally a very static four...but no big deal as it was still in the acceptable range). I did not, however, disconnect the stepper motors...
Is there any reason I should have done this beforehand? Also, it seemed to me that making adjustments to the cable once the set screw is loose is most easily done by hand, as the wrench wants to vibrate all over the place. Is this what the rest of you have found too?
Finally, once you have achieved balance at 3500 RPM, are you truly finished? Also, I was thinking next time it might be easier to mark the throttle adjustment screw with a marker so I can tighten the set screw and visually see that my positioning hasn't been compromised in the process. Anyone have any other pearls/suggestions?
Thanks all!!
FlatDarkGS is offline   Reply With Quote
Old 03-03-2012, 08:13 PM   #2
Pickup man
Location: People's Socialist Republic of Ontario, Toronto
Oddometer: 286
I dont have any suggestions on it yet as I am about to do a throttle sync as soon as I get the tool.
Still not sure which one to buy though...twin max, carb tune etc.. Any suggestions about that?
Pickup man is offline   Reply With Quote
Old 03-03-2012, 09:25 PM   #3
johnjen
I've Been Resigned
johnjen's Avatar
Oddometer: 16,013
I just noticed that this thread has 148 views and only one other post. (until this one)
Hopefully JVB will be along shortly to clue you in because what I'd tell you would just make your head hurt.
And as for which differential synch tool is 'best' the Harmonizer gets my vote and by a HUGE margin.
JJ
The hidden harmony is found with joy, while the obvious brings indifference.
The farther you enter into the Truth the deeper your conviction for truth must be.
There is understanding of the world precisely to the degree that there is understanding of the Self.
WingMakers.com
Collected Works of the WingMakers Volume 1 pg. 590
johnjen is offline   Reply With Quote
Old 03-04-2012, 01:05 AM   #4
rattis
rattis's Avatar
Oddometer: 1,166
Thumb Grok's device roks
The harmonizer is very good, even up to V 12 engines (my bro's Jag)
I wish I had bought a GSA a long time ago
and now I drink Orange Crush as well, double up now, a 990Adv and a 950 SER
rattis is offline   Reply With Quote
Old 03-04-2012, 04:13 AM   #5
bmdavis
Oddometer: 1
I've used the twinmax and the harmoniser. The harmoniser is by far the most accurate and easy to use. I'm glad I bought it last summer.
bmdavis is offline   Reply With Quote
Old 03-04-2012, 05:17 AM   #6
opposedcyljunkie
Heavyweight Boxer
opposedcyljunkie's Avatar
Oddometer: 4,776
Yes, that's pretty much it. You will note that at idle speed, the Harmonizer would show that they are not balanced. But I understand that the allowable variance is +/- 25mmHg.
Throttle adjustment screw? Maybe you meant the cable adjuster screw. The adjustments can be so minute that marking the screw position would be useless. In time, cables stretch that's why periodic checking of cable pull balance is required.
OCJ
92 R100GS-PD Euro
01 Vespa PX150E - sold
05 Yamaha Fazer FZS-1000
07 R1200GS
opposedcyljunkie is offline   Reply With Quote
Old 03-04-2012, 12:12 PM   #7
FlatDarkGS OP
Master BS'er
FlatDarkGS's Avatar
Oddometer: 160
Yessir I did mean the cable adjuster screw. Thanks for the correction.
FlatDarkGS screwed with this post 03-04-2012 at 12:13 PM Reason: Too much coffee
Old 03-04-2012, 05:31 AM   #8
inbred
inbred's Avatar
Oddometer: 154
Best harmonizer: Probably Graham Nash. Don Henley is a close second.
"Not knowing where you're going is the best way to get where you've never been before" .... J. Peterman
inbred is online now   Reply With Quote
Old 03-04-2012, 06:12 AM   #9
Pickup man
Oddometer: 286
Thats funny. Seems like harmonizer is more popular choice, who sells these things at a descent price?
Old 03-04-2012, 06:32 AM   #10
opposedcyljunkie
Heavyweight Boxer
Oddometer: 4,776
Only Grok makes and sells them. Only one price anywhere AFAIK.
Sent via Tapatalk
OCJ
92 R100GS-PD Euro
07 R1200GS
Old 03-04-2012, 11:49 AM   #11
johnjen
I've Been Resigned
johnjen's Avatar
Oddometer: 16,013
see this thread
http://www.advrider.com/forums/showthread.php?t=701625
JJ
WingMakers.com
Old 03-04-2012, 12:11 PM   #12
FlatDarkGS OP
Master BS'er
FlatDarkGS's Avatar
Oddometer: 160
Originally Posted by johnjen View Post
Thanks for getting the responses flowing!! This link actually raises another question.. On the video it shows the balance being adjusted with a screwdriver via a screw on the TB. On my 2011 camhead I had to use two wrenches and the throttle cable which was much more of a pain in the ass. Why the difference?
Also, feel free to make my head hurt with your response dude (if it's info that isn't contained in your link). I'm a sponge when it comes to R1200GS info...I may not absorb it, but i'd rather have it out there and not understand all of it than have a look like this ----> and be *completely* ignorant!
Old 03-04-2012, 12:43 PM   #13
johnjen
I've Been Resigned
johnjen's Avatar
Oddometer: 16,013
When the 1200's came out BMW changed the entire fuel injection computer. The screwdriver is used on the 11xx series of motronic EFI computers because they have a Big Brass Air Screw that manually adjusts the idle air bypass circuit (idle speed circuit) for each throttle body. For more on this look in the Hall of Wisdom for the document TBSD.
The 1200's use a computer controlled stepper motor to adjust the idle air bypass, so there is no manual adjustment.
In order to 'properly' adjust the throttle bodies, both stepper motors should be 'parked' so that they are in a fixed equal air delivery position and THEN using the Harmonizer (or manometer of your choice) adjust the throttle cables while the throttle is in an open position to balance the reading shown by the manometer.
This parking of the steppers can be accomplished by using either a GS-911 tool, the BMW factory computer diagnostic tool, or other electronic tools designed for this purpose. It should be noted that simply unplugging the steppers is NOT the same as 'parking' them and further should only be done by someone who knows what they are doing. I say this because while the chances are slim it is possible to 'brick' the EFI computer if you unplug or plug the steppers into the wiring harness at the wrong time. This would be bad (read $$$$). And the synch job can't be done properly UNLESS both steppers are properly parked.
JJ
ps does your head hurt now?
WingMakers.com
Old 03-04-2012, 05:36 PM   #14
FlatDarkGS OP
Master BS'er
FlatDarkGS's Avatar
Oddometer: 160
JJ
Awesome. Just awesome answer. Thank you. Most of it makes sense...at least enough of it to plan on how to proceed with the harmonizer from here on out.
...and yes, my head now feels like I've stared at your avatar for two straight hours.
Old 03-31-2013, 02:46 AM   #15
Chat Lunatique
ACK
Chat Lunatique's Avatar
Oddometer: 1,050
Ok, this is where I disagree/get confused. Please correct me here if I'm wrong...
The "steppers" are actually the idle stops, a mechanical stop, ie.they set up the idle RPM by keeping the butterfly valves in the TB's open a crack to idle. They move up and down to make fast idle RPM as req'd by a cold engine temp. Yes?
If so then when balancing the TB's at 3500RPM, the idle stops are not touching the butterfly valves any more and do not need to be "parked". I balance my 2010 GS without using my GS911 to park the steppers and have a beautiful , smooth balance.
No chance of fouling up here if you do not park 'em!
I do not intend to tiptoe through life, only to arrive safely at death
Chat Lunatique is offline   Reply With Quote
Times are GMT -7.   It's 03:12 PM.
