Old 03-07-2012, 06:20 AM   #1
leadingedge OP
Trailing along...
leadingedge's Avatar
Oddometer: 33
Heated grip Fix - Step by Step
I recently had a left heated grip failure, but I managed to open up the "sealed" grip and get to the element to fix it myself.
This repair will work on all of the following new generation grips, because the current part numbers for the replacement BMW heated grips are the same on all of the following bikes:
R1200GS (2005-Current); R1200R (2007-Current); R1200ST (2005-2007); R1200S; K1200S (2005-2008); K1200R (2005-2008); K1200R Sport.
F800S; F800ST (2007-Current); F650GS (2001-2004); F800GS (2009-Current); F650GS (2009-Current).
This is what to do: (For the LEFT grip)
  1. Remove the handlebar weight. (If you have hand protectors, then remove them also)
  2. Open the multifunction switch cover by removing the 2 small screws on the back.
  3. Disconnect both plugs from inside the multifunction switch and then move them out of the way so you are then able to remove the 2 small screws that attaches the plastic attachment of the grip to the inside of the multifunction switch.
  4. Remove the multifunction switch.
  5. Remove the screw/s that attaches the grip to the handlebar, and then just slide the grip off.
  6. You now need to get to the root of the problem inside the grip. Normally it is one of the 2 wires that break off where they are attached to the element inside the sealed grip.
  7. Before going any further, I would suggest testing the wiring in the grip with a multimeter to see if electricity can flow from one pin, through the element inside, and out the other pin. If not, then proceed as follows.
  8. Use a sharp carpet razor blade to VERY carefully & slowly separate the rubber from the plastic all the way around the grip. The rubber is only molded onto the plastic for a short distance (only along the edge), so be slow and carefully cut a small bit at a time while you try to roll the rubber back onto itself to expose the element.
  9. NOTE - Some guys blow high pressure compressed air inbetween the rubber and plastic to blow the whole thing up like a balloon and thus force the rubber off the plastic, but this will basically stretch and ruin the whole rubber part of the grip. You DON'T have to do it this way, just carefully cut it open a little bit, and then you can simply roll it back to expose the element.
  10. Your problem is very likely now exposed, and is probably the wire soldering that broke where it attaches to the element. You can see in my photo below that my black/yellow wire has come loose.
  11. Simply solder the wire carefully back onto the element where it broke off, and you're all set!
  12. Roll the rubber back, and re-install everything, making sure that the markings on the handlebars, the clamps, the plastic guides etc. all line up nicely before tightening everything again. Don't over-torque!
  13. You've just saved yourself a couple hundred bucks.
  14. (Note - For the RIGHT grip, you will also have to remove the throttle cable & cover)
leadingedge is offline   Reply With Quote
Old 03-07-2012, 08:25 AM   #2
Mudcat
Unregistered
Mudcat's Avatar
Oddometer: 4,472
Thanks for the information and write up. I haven’t had a problem with my grips but you never know.
I've got to be cool
Relax
Take a long long ride on my motor bike
Untill I'm ready
Mudcat is offline   Reply With Quote
Old 03-07-2012, 08:33 AM   #3
leadingedge OP
Trailing along...
Oddometer: 33
No probs, hopefully you never have problems with it.
It seems that a lot of guys have them fail on them, and always end up being told that you have to replace the grip because it is a sealed unit...
Actually a pretty easy fix, but don't tell BMW!
Old 03-07-2012, 12:41 PM   #4
EJ_92606
Rider
EJ_92606's Avatar
Oddometer: 1,779
Excellent DIY, thanks for posting!
EJ_92606 is offline   Reply With Quote
Old 03-08-2012, 12:22 AM   #5
L.B.S.
Oddometer: 1,420
Awesome!
Thank you very much for your DIY post, very helpful and appreciated!
L.B.S. is offline   Reply With Quote
Old 03-08-2012, 01:58 AM   #6
mcmarcia
mcmarcia's Avatar
Oddometer: 200
Thumb good fix for a common problem
awesome, I vote this goes to the hall of wisdom. These grips eventually all break and it looks so easy to fix. I bet a small exacto knife might work good cutting around the grip end?
Current flock: GS1100, R1150R, KTM450MXC, G650GS. Flown away: GSPD, yam 250 & 450WR
mcmarcia is offline   Reply With Quote
Old 03-08-2012, 02:21 AM   #7
leadingedge OP
Trailing along...
Oddometer: 33
I'm guessing it will do the trick just fine, as long as you do it slowly & carefully.
Old 03-08-2012, 02:17 AM   #8
John Smallberries
John Smallberries's Avatar
Oddometer: 1,300
thanks! The RH grip on my '05 stopped heating a few weeks back. I think I will be following your tracks very soon.
I am worried that I F'd something up when I dug into the RH harness to tap into the turn-signal-cancel wire for my Autoswitch. The heated grip worked for months after my surgery, so I thought I was ok.
'05 BMW 1200GS '09 Honda CRF230 '10 Yamaha TW200 '07 KTM 400 XCW/EXC '15 Jialing 150 GY2
John Smallberries is offline   Reply With Quote
Old 03-08-2012, 02:43 AM   #9
leadingedge OP
Trailing along...
Oddometer: 33
Thumb
I'm sure it is nothing that you did wrong, just a bad design and flimsy heating element solder join that BMW punched out.
Keep us posted with pics of your own, and your result when you're done!
Old 02-09-2013, 08:01 AM   #10
rdcyclist
rdcyclist's Avatar
Oddometer: 1,242
thanks! The RH grip on my '05 stopped heating a few weeks back...
I believe the older R12GS's used nichrome wire for the heating element under the grip and it's not easily soldered. I don't know when they went to the flexible printed circuit elements but the 05 grips I disassembled had wire.
rdcyclist is offline   Reply With Quote
Old 12-03-2014, 09:17 AM   #11
Deanowade
Chronic Dumbass
Deanowade's Avatar
Oddometer: 122
I just had my right grip heat fail on my 2007 GS. Opened it up and discovered the "old style" wires, broken in such a manner that I did not believe I could repair with a quick solder. Just bit the bullet and ordered a new grip.
Deanowade is offline   Reply With Quote
Old 03-29-2012, 07:17 PM   #12
Max Wedge
ADVenture mowing
Max Wedge's Avatar
Oddometer: 512
My left grip died this morning. Still under warantee, but if it wasn't, or when it isn't I'll be doing this. Thanks for posting it.
'10 R1200GS
-you never see a motorcycle parked outside of a psychiatrist's office.
Max Wedge is offline   Reply With Quote
Old 03-29-2012, 08:36 PM   #13
leadingedge OP
Trailing along...
Oddometer: 33
No Problem!
See if they let you keep the old one, and fix it up for a spare in the future.
Old 02-08-2013, 06:09 AM   #14
vhugoabreu
Oddometer: 8
Heated grip
Hi, I have a 2008 gsa 1200 and I did is as you commended. It was the left grip and one of the wires was not proper soldered. Now everything is ok.
Thx for the tips
vhugoabreu is offline   Reply With Quote
Old 02-08-2013, 10:36 PM   #15
motorcy
motorcy
Oddometer: 20
Question same for 1150...2002?
hey, do you know if it's the same for a 2002 1150 ?
motorcy is offline   Reply With Quote
Times are GMT -7.   It's 02:48 PM.
