Old 03-25-2012, 10:10 PM   #1
lockyv7 OP
lockyv7's Avatar
Location: Sunshine Coast Australia, There is no winter here.
Oddometer: 1,035
R100GS Exhaust Weight
Anyone know the Difference between the Weight of a standard R100GS exhaust system and a system like this from Sibenrock. Will i save much.
Cheers Locky.
lockyv7 is offline   Reply With Quote
Old 03-25-2012, 10:31 PM   #2
walkingbear
walkingbear's Avatar
Oddometer: 3,493
Cheers Locky.
It will lighten you wallet for sure.
BMWMOA 82741 ABC 8418
2wheeltraditions@gmail.com
75 R90S , 77 R100 RS,88 R100GS ,94 R1100RS (Aragorn) 2k 1150GS DMC sidecar,
Rosso Mandello V11 , 2014 R nine T
walkingbear is offline   Reply With Quote
Old 03-26-2012, 03:14 AM   #3
gsd4me
90% bluff
gsd4me's Avatar
Oddometer: 7,482
Have you had a look on Motobins, or Motor Works web sites to check other exhausts? The Keihan brand is made very well and is cheaper than Staintune.
David Hunn:
R100GS Ray Peake special.
http://www.advrider.com/forums/showt...uild+australia
gsd4me screwed with this post 03-26-2012 at 03:45 AM
gsd4me is offline   Reply With Quote
Old 03-26-2012, 04:32 AM   #4
lockyv7 OP
lockyv7's Avatar
Oddometer: 1,035
I may end up just replaceing the collector box with a 'Y' section and building a alloy or stainless can in the style like the system Sibenrock sells, i am looking at mounting at a certain angle and height to work in with a set of Panniers i have built. Just interested in the weight i would save.
I have a new set of the Keihan Torpedo style stainless mufflers ready to fit on a 60/5.
Old 03-26-2012, 06:13 AM   #5
Rucksta
SS Blowhard
Rucksta's Avatar
Oddometer: 2,681
About 3.5 kg is easily doable without resorting to exotic material or high noise levels.
I kept the junction box for performance and noise supression
My bike is slow but the earth is patient.
Rucksta is offline   Reply With Quote
Old 03-26-2012, 07:57 AM   #6
lockyv7 OP
lockyv7's Avatar
Oddometer: 1,035
Thanks, thats a start, a bit here and there all helps.
Old 03-27-2012, 08:02 AM   #7
Rucksta
SS Blowhard
Rucksta's Avatar
Oddometer: 2,681
Best Kg/$ for me was a valeo starter and lighter battery.
Tossing the glass headlight and the brass speedo for a plastic headlight unit from Bursons Auto and a plastic instrument from VDO took care of another 1.2 kg
Old 03-26-2012, 08:02 AM   #8
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,493
According to the weights in the parts fiche, your stock system should weigh 21 pounds. Almost 10 kilos.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Airhead Wrangler screwed with this post 03-26-2012 at 11:19 AM
Old 03-26-2012, 08:59 AM   #9
One Less Harley
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 4,695
with the "Y" pipe you will loose a little bit of low end torque.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 03-26-2012, 11:10 AM   #10
Cigars&Scotch
My eyes are up here
Cigars&Scotch's Avatar
Oddometer: 1,835
I just received a Siebenrock exhaust kit on Friday. It is still in the box. Let me see what the weight of it is.
Mike
"Why don't you buy some flea collars for your ankles so the ants wont climb up you leg and bite your candy ass!!!" Kennyanc 07 H.Springs
38 BMW R71 w/sidecar Kung Fu version
77 BMW R90S Huh ?
90 BMW R100GS/PD "At last!"
NRA Life Member, Trout Unlimited Life Member
Drink till I'm Drunk Life Member
Cigars&Scotch is offline   Reply With Quote
Old 03-26-2012, 08:06 PM   #11
Infracaninophile
Finding My Way..
Infracaninophile's Avatar
Oddometer: 7,514
When I did the refresh of my old R80 G/S I replaced the stock exhaust with a Keihan. I did weigh it. It's in my old thread somewhere. I recall weighing the headers, collector, and muffler separately.
Tom
Infracaninophile is offline   Reply With Quote
Old 03-27-2012, 07:01 PM   #12
Cigars&Scotch
My eyes are up here
Oddometer: 1,835
Came in a little over 11lbs. I am going to try to put it o this weekend
Mike
77 BMW R90S Huh ?
Old 03-28-2012, 03:20 AM   #13
lockyv7 OP
lockyv7's Avatar
Oddometer: 1,035
Thanks guys, i think i can get rid of a little weight with the different exhaust, starter and battery. From there i will just ride it for a while to think about what i think my need are going to be.
Chers Locky.
Old 05-15-2012, 02:23 AM   #14
Box'a'bits
In need of repair
Box'a'bits's Avatar
Oddometer: 2,238
Locky, just as a FYI, the full Siebenrock system is 5.6kgs as stated in this site , compared to AW's estimation of the stock systems 9.5kgs from parts fiches.
Cigars & Scotch, what's the Seibenrock System like (quality, ease of fitting, sound, & riding)?
My '91 R100GS thread is here
My Ride photos are here
Box'a'bits screwed with this post 05-15-2012 at 02:28 AM
Box'a'bits is offline   Reply With Quote
Old 05-15-2012, 02:52 AM   #15
lockyv7 OP
lockyv7's Avatar
Oddometer: 1,035
Thanks Box-a , i ended up e-mailing Siebenrock and they got back to me with the 5.6kg.
I have picked up a stainless 100mm round can 420mm long that i will use for now then go with a set of stainless headers and 'Y' pipe from moto-bins i think. For now i have been doing all the oils, cleaning, ordering service parts, had to clean and seal the tank. Got a new solo sear and PD rear rack now am building panniers and pannier frames. next thing to make is the new better side stand and i may machine up a alloy shift leaver. I have new led tail light and blinkers coming that i will try and fit into some hand guards. I will price up some alloy stock and may machine up a sump extenion to get a bit more oil in there with out the oil cooler.
No big hurry.
Times are GMT -7.   It's 09:12 AM.
