Old 04-01-2012, 08:44 AM   #1
torinreality OP
metaconscious
Oddometer: 57
Left hand rear brake
Hi, all. Forum searches aren't giving me what I'm looking for:
I'd like to move the rear brake controls to the left hand position. I have a Rekluse clutch, and was thinking to merely raise the stock clutch lever out of the way. I've read about the Clake system, but I think I'd rather have two separate controls.
Who's performed this operation? Are you glad you did? Can you tell me what suppliers you used for parts? Maybe a few photos?
torinreality is offline   Reply With Quote
Old 04-01-2012, 11:15 AM   #2
brents347
Trusting my Cape...
brents347's Avatar
Oddometer: 3,735
I havent done it so I have no opinion on it, but here's some threads on the subject.
http://advrider.com/forums/showthrea...highlight=lhrb
07 Yamaha R6
07 KTM 950 Super Enduro
04 KTM 250exc- plated two-stroke
01 Kawasaki KE100
74 Honda MR50
brents347 is offline   Reply With Quote
Old 04-01-2012, 11:24 AM   #3
Peanuts
Peanuts's Avatar
Oddometer: 1,592
I have not done it on an Adv, but have done on my own 200EXC, 450SXS, 520EXC, 250EXCF. So much better control over the rear brake. Going down steep hills, skid steering, walking alongside over bogs etc, its all good.
I use a combination LHRB and footbrake by adapting the rear master cylinder to get fluid fed through it from the LHRB.
For the actual LHRB on the bars I use a scooter rear brake or the Brembo clutch master cylinder as fitted to later KTM EXC/SX models.
I have fitted dozens of Rekluses and LHRB since 2002.
Peanuts is offline   Reply With Quote
Old 04-01-2012, 07:33 PM   #4
torinreality OP
metaconscious
Oddometer: 57
Thanks for the replies, Brents347, Peanuts. I think I have enough information now to give this a shot.
Old 02-14-2013, 09:12 PM   #5
biggus
biggus's Avatar
Oddometer: 378
Do you have any updates on your Left Hand Rear Brake? Was it a go or a no go?
biggus is offline   Reply With Quote
Old 02-15-2013, 08:39 PM   #6
Tuna Helper
Rawrr!
Tuna Helper's Avatar
Oddometer: 748
A lot of stunt riders do this. You could check out stuntlife.com.
Originally Posted by dogjaw
I'm a bike slut, I love them all
Tuna Helper is offline   Reply With Quote
Old 02-16-2013, 05:55 PM   #7
eebrumfi
eebrumfi
eebrumfi's Avatar
Oddometer: 52
http://www.youtube.com/watch?feature...=14sq7uF-rIM#!
-2012 KTM 990 Adventure-
-A DRUNKEN MAN'S WORDS ARE A SOBER MAN'S THOUGHTS-
eebrumfi is offline   Reply With Quote
Old 02-22-2013, 01:13 PM   #8
ABuck99
0.0
ABuck99's Avatar
Oddometer: 594
torinreality What was your final solution?
The new Rekluse dual actuated left hand brake kit for the small bikes works pretty well, and retains the use of the foot brake. Depends on what you intend to use it for, but I wouldnt count on that as a stand alone system to stop an LC8 which weighs twice as much as the thumper it was designed for. That left hand brake kit is off a mountain bike, it uses a bicycle brake line, its not braided stainless, so under pressure it expands and you get fade. Also Im not sure that Rekluse master cylinder could develop enough system pressure to work the rear caliper enough to lock the back wheel if needed.
KTM: 06 KTM950S & 10 KTM450EXC
ABuck99 screwed with this post 02-22-2013 at 01:28 PM
ABuck99 is offline   Reply With Quote
Old 02-22-2013, 03:04 PM   #9
Patacca
Pimp my SE italian style
Patacca's Avatar
Oddometer: 563
So let's see if something good comes from this tread...
I still couldn't do this mod.
I would like to have LHRB + a very small clutch lever (1 finger) + no foot rear brake.....
I think that removing the foot rear brake get the mod easier, because you just need the master lever....a longer line to calliper and that's it.
No problem with pressure going in the reservoir of the rear foot reservoir.......
Can anyone find a good master lever for the rear brake of an eavy LC8?
Is the Magura master (changing the OR for dot instead of mineral oil) strog/big enough to brake?! The size is 10,5.
Hope we can reach a good final solution.
If you aren't sure, open to MAX!!!
www.raffaellophoto.com
check out my pimped SE @
http://www.myktm.it/viewtopic.php?f=50&t=223
Patacca is offline   Reply With Quote
Old 02-23-2013, 12:23 PM   #10
ABuck99
0.0
ABuck99's Avatar
Oddometer: 594
You might try this product- excellent quality: http://www.accossatousa.com/index_files/Page442.htm & they might be able to help you piece this together.
Old 02-23-2013, 05:32 PM   #11
DuctTape
Oddometer: 351
I'm thinking about this since I ride a Rekluse Clutched 990. http://www.ktmcyclehutt.com/ktm-part...nt=streetbikes
2013 KTM 690 (Thanks FLHRCI Buyer! )
2011 990 Adventure Dakar (Thank you Honey!)
2010 Aprilia RSV4 Factory
2010 Ducati 1198S
DuctTape is offline   Reply With Quote
Old 02-25-2013, 02:44 PM   #12
Patacca
Patacca's Avatar
Oddometer: 563
yeap but there is even written that there is no solution yet for bikes with hydraulic clutch..........
Old 04-25-2014, 08:40 AM   #13
kelds
mostly right-side-up
kelds's Avatar
Oddometer: 124
I'm currently trying to work out the same thing for my bike, except I want RHRB. The information out there is pretty spotty.
I was thinking of using a Brembo radial 13mm clutch master for a brake on the left in addition to my stock clutch lever. The SE front brake master master is apparently also 13mm, so it should have good feel as a front brake. I'm guessing it would also work fine for a rear...it's also available in other piston diameters, which may or may not work better as a rear brake.
The radial version needs a remote reservoir which I'm ok with because I didn't want to have the reservoir in the way of setting up the lever position for good feel. I think they also have a cheaper non-radial version with a built in reservoir.
I also read somewhere that people have used mountain bike hydraulic brakes as clutch masters as they take up a lot less space (Hayes Stroker was mentioned). I didn't find anything on piston size for the 990 clutch master, so I haven't been able to work out whether or not I want to explore this further.
I'm installing my Rekluse this weekend and will be working through the controls switch over the next month or two. I'm curious where you ended up with your install?
kelds is offline   Reply With Quote
Times are GMT -7.   It's 11:54 PM.
