Old 04-24-2012, 02:20 AM   #1
Sumi OP
Sumi's Avatar
Oddometer: 1,784
No marks on rear cams?! 950ADV
Hi!
Yesterday I've done a valve check, and noticed that there are no "X" or "+" marks on the rear cylinder cams.. So I've turned the engine to TDC, locked it with the locking tool, and measured the clearances that way (so I've assumed that the dealer who fited the cams previously set the cams correctly) + marked the teeth with a marker pen.
The problem is that 3k miles before, the dealer replaced my rear cams with new ones, and I don't understand how did he know the good position for the new cams without the marks (there are no "O" marks on the outside at TDC as well).. Maybe he counted the teeth on the old cams and used that to compare it?
Because the bike is running rough at idle (hunting + sudden death), I'm thinking that one or both of the rear cams may be off one (or more) tooth?
Bike starts easily, and pulls fine, but I just can't see how to set the cams properly without the marks on them.
Has anybody seen this before?
Thanks for your ideas!
Sumi screwed with this post 04-24-2012 at 03:08 AM
Old 04-24-2012, 03:49 AM   #2
DirtyADV
DirtyADV's Avatar
Oddometer: 2,199
Was quite some time since I checked mine.
But think you might have to look for marks on the other side.
Try getting hold of a service manual, provide us with an email and I'm sure someone can help with that, at work right now so can't send anything until this evening.
/Johan
Have changed name, was previously Dirty950
www.dirtyadv.com (under construction)
DirtyADV is offline   Reply With Quote
Old 04-24-2012, 04:33 AM   #3
Sumi OP
Sumi's Avatar
Oddometer: 1,784
/Johan
I have the service manual..
There are no marks on the inside of the cam (looking from the ignition cover). Not an X or a + or a circle, nothing.
There are however marks on the outside of the cam (Circles) - but they are way too off for them to be good. (cams are marked "RE" ofcourse)
Old 04-24-2012, 05:06 AM   #4
Salzig
Salzig's Avatar
Oddometer: 251
Could it be that the dealer put in some 990 cams?
The markings are different.
Actual rides:
'10 Husqvarna TE310 - '07 KTM 990 Adventure ABS (S'd) - '04 Husqvarna SM450R - '99 YAMAHA R6
"A donkey! A donkey! My kingdom for a donkey!"
Salzig is offline   Reply With Quote
Old 04-24-2012, 05:09 AM   #5
Sumi OP
Sumi's Avatar
Oddometer: 1,784
No, because the cams are not black (or dark grey), like the ones used in the 990s
Old 04-24-2012, 11:46 PM   #6
mousitsas
mousitsas's Avatar
Oddometer: 2,728
My (bought from new) SE, has black cams stock.
Old 04-25-2012, 05:37 AM   #7
Sumi OP
Sumi's Avatar
Oddometer: 1,784
But I've never seen a "not black" 990 cam.
Old 04-25-2012, 06:08 AM   #8
mousitsas
mousitsas's Avatar
Oddometer: 2,728
My SE is 950
Old 04-24-2012, 07:11 AM   #9
DirtyADV
DirtyADV's Avatar
Oddometer: 2,199
From the ktm950.info:
The other side (engine side) of the rear cylinder intake cam gear has the "X" mark indicating the proper position at TDC of the compression stroke.
/Johan
Old 04-24-2012, 11:04 AM   #10
Sumi OP
Sumi's Avatar
Oddometer: 1,784
/Johan
Yes, that's what I've wrote in #3 .. That there are no "X" or "+" on the inside (engine side, ignition side, etc.) on the cams.. That's why I've created this thread:)
Old 04-24-2012, 11:23 AM   #11
crazybrit
crazybrit's Avatar
Oddometer: 8,553
Hmmn. The rear is a "+" mark and it's below the V between two teeth (the front is an X on one of the teeth).
With the cam bridges in place it's much harder to see than the front, I usually rotate a few degrees past TDC until it comes into view and they go back.
I'm assuming your rear cam is approximately corectly positioned, pointing towards 10am if you are looking from the left side of the bike.
Pic from the HOW (with cam bridges removed):
crazybrit is offline   Reply With Quote
Old 04-24-2012, 11:28 AM   #12
Sumi OP
Sumi's Avatar
Oddometer: 1,784
Okay..
To be clear:
Even if I take out the rear cams of the cylinder head, and examine them when they are in my hands -> There are _NO_ marks on the inside (lobe side) of the rear cams. Not a single cross, or plus, or dot, or circle, nothing at all. nothing..
I know how they should look like as the old cams in the front cylinder head have these marks.. Also my old, shot cams which have been replaced and are now laying in a box on the shelf have the "X" and "+" on them.. It's just that these new cams that has been changed last year doesn't have any marks on them..
Sumi screwed with this post 04-24-2012 at 11:35 AM
Old 04-24-2012, 11:34 AM   #13
crazybrit
crazybrit's Avatar
Oddometer: 8,553
Okay..
To be clear:
When I wrote above I was certainly aware of possibility that you knew what you were doing
Sounds like you need to talk to the dealer. Ask them a) how they correctly timed them when they installed b) how you are supposed to adjust the valves.
I'd be making a case that they need replacing as otherwise you cannot perform an accurate valve adjustment.
Times are GMT -7.   It's 01:30 AM.
