05-14-2012, 03:56 PM
#1 |
ride dirty
Oddometer: 419
Average lifespan of Odyssey PC680 battery in motorcycle
I'm looking to find out what the average lifespan of the Odyssey PC680 is. I have a 1973 r75/5 that doesn't want the battery to stay charged. I'm trying to figure out if my battery needs replacing or I need to dive into the electrical of my bike. The battery is 6 years old. Was put in the bike in 2006.
2013 BMW R1200 GSW | 1973 BMW r75/5 toaster | 2011 Husky TE310 "4 wheels move the body, 2 wheels move the soul" |
05-14-2012, 04:05 PM
#2 |
Ride On
Oddometer: 1,037
Hopefully much longer than a Westco... yup, I'm gonna be "that guy"!
Cereally, I'm wondering the same thing about the PC680 i recently purchased.
Opinions are like internet connections- everybody has one. |
05-14-2012, 09:15 PM
#3 | ||
Wacky Bongo Boy
1974 BMW R75/6, 1974 BMW R90/6, 1969 BMW R60/2 hack, 1929 Ford Model A, Metal casting, Part 2/Part 1 among others.. |
05-15-2012, 07:10 AM
#4 |
Beemerholics Anonymous
Oddometer: 7,354
Remove the negative lead from the battery. Set the meter to amps. Attach the positive (red) lead to the battery negative terminal. Attach the negative lead to the cable.
With the ignition off, the meter should read zero. Switch the meter to milliamps. It should still read zero. If not, find out what is draining the battery.
Wanted: Dead, smashed, crashed or trashed gauges BMW GAUGE REPAIRS - TACH*SPEEDO*CLOCK*VOLT METER *PODs & LIGHT BOARD* |
05-14-2012, 07:14 PM
#5 | |
Coyote's Brother
Oddometer: 3,299
Meanwhile, place the battery on a charger and see it it holds it's charge. Odyssey PC680 have a rep for long life. Westco? None for me thanks...
Hawkdude Hate rots the pocket that carries it. |
05-14-2012, 07:16 PM
#6 |
ride dirty
Oddometer: 419
What should I be reading at for certain RPM's on my voltmeter? I imagine around 13.5V and higher correct?
05-14-2012, 08:19 PM
#7 |
More tacos than you
Oddometer: 5,093
What he said. Even if it is your battery, 6 years out of a battery isn't bad.
R80ST Gets The HPN Treatment Ducati Pantah 500SL Rebuild Seattle to TDF on an airhead WTB R100R Mystic sidestand and mount. |
05-15-2012, 07:26 AM
#8 |
BMW Airhead
Oddometer: 234
2 simple tests
Assuming you have a volt meter.
1. check battery voltage (after charging) static bike off should be about 12.5 volts. Then wait a couple of hours ( go have coffee or a beer) check again should still be 12.5 volts it it has dropped then bike is drawing power when off or battery is bad. Disconnect battery and repeat above test this will test just the battery. 2. With bike running check voltage at battery should read ~13 volts more as RPM increase if not check bike charging system. This is a way of isolating the probem to either battery or bike. I have had a PC680 in my 74 R75/6 for 4 years no problem great battery. Uses half the space as original and I can remove it without dropping subframe. Only problem is the price of a new one I see they are about $150 now.
Airhead ![]() 1974 R75/6 & 1989 R100GS |
05-15-2012, 10:58 AM
#9 |
Albuquerque
Oddometer: 844
These are "storage" batteries and bigger = more storage.
But, in motorcycles they are small and don't store much. Your approach should be: if the motor's not running, a battery charger should be attached. This is a fact of life of motorcycle ownership.
Kent Christensen Albuquerque '12 R1200RT, '02 R1100S, '84 R80G/S |
05-15-2012, 11:42 AM
#10 |
Oddometer: 250
I got 7 years out of my 680-
05-16-2012, 09:20 AM
#11 |
Oddometer: 201
I was going through a simular problems a few years ago.... Here is what I did and found out: I took the battery out and took it to Auto Zone and had it tested. Did not know what the cold cranks were so I told them about maybe 400.... they tested it twice and it came back both times as good. Then I emailed Odyssey to find out some info. They told me that the cold crank is only 220 and if it tested good at 400 twice the battery was as good as new. The battery was 6 years old at the time and I heard about abrupt battery failures... well that was 4 years ago and the battery is still in the bike and is working wonderfully. Odyssey told me that the average life of the battery is anywhere inbetween 7 and 12 years. After some further investigation it turned out that the diode board had a bad ground. It was repaired and no problems since. Hope that helps.
05-16-2012, 10:19 PM
#12 |
Chronic Noob
Oddometer: 2,292
I killed my 320 at 3 years +
I put chokes on the bike and tidied up the charging system then slotted the 680 back in. It was 2 years old when I benched it for the 320 and it seems to be holding up well. Conclusion. you can kill these things but you have to try really hard.
If the Earth is flat why are my tyres round? |
