Old 06-28-2012, 11:52 AM   #1
stainlesscycle OP
stainlesscycle's Avatar
Oddometer: 1,639
plug reading help.
getting conflicting ideas about what's going on in this motor.
2 sets of pics, 1st set of pics is br9eix run for about 1.5 hours. 2nd set is br8eg run for 5 minutes just putting around to get some color on it. both are identical jetting, ambient temperature/elevation. on the first set of pics, the float level was bit low. also, timing was more retarded (just 1 degree less advance).
i'm thinking the first plug (which still ran fine) was a bit too cold, and a little rich. i'm assuming the carbon deposits all over is just due to plug too cold. there are no seal leaks.
2nd set of pics still a little rch somewhere, maybe hot enough of a plug now to burn deposits off.
1st plug.
2nd plug
current bikes
stainlesscycle is offline   Reply With Quote
Old 06-28-2012, 05:07 PM   #2
willis 2000
neo-quixote
Oddometer: 1,033
The second set of photos looks like I'd expect if you just poked around for five minutes. Which one of your bikes is it?
willis 2000 is offline   Reply With Quote
Old 06-28-2012, 06:00 PM   #3
stainlesscycle OP
Oddometer: 1,639
it's a puch 175mx. the jetting is pretty good right now, pulls fine with no stuttering or lean indicators, has as much power as could be expected, and pretty instantaneous.... i guess the question is - even though i was on the pipe 99% of the time on that 1st plug, it didn't clean up. so is this just too cold of a plug doing this, or maybe a combination of too cold of a plug + something else.. it's a non resistor boot, resistor plug, electronic ignition. maybe go non resistor all over to get a little better spark.
current bikes
Old 06-28-2012, 05:20 PM   #4
sieg
sieg's Avatar
Oddometer: 1,389
Can't tell shit about jetting the way you're doing it anyway. Run WFO for along distance, kill engine and stop with clutch in. Now read the plug.
I'm not saying there should be capital punishment for stupidity, but let's take the safety labels off of everything and let the problem solve itself.
Current bikes: '12 WR250R, '10 F800GS, '08 Versys, '07 WR250F, '85 RZ350,
Wife's bikes: '10 F650GS, '09 XT250,'03 WR250F
sieg is offline   Reply With Quote
Old 06-28-2012, 05:57 PM   #5
stainlesscycle OP
Oddometer: 1,639
yes, i'm completely aware of that. it's not a jetting issue i'm trying to figure out. i'm more worried about the carbon deposits - the first plug was run hard - should be no deposits - unless that's what a cold plug will do...
current bikes
Old 06-28-2012, 09:23 PM   #6
willis 2000
neo-quixote
Oddometer: 1,033
2-stroke plugs typically won't burn their carbon deposits off. The NGK 8 heat range should be about right. OK, we all have our gas/oil favorites, but for air-cooled bikes, I had the best results with regular grade gas mixed 32:1 with Golden Spectro. If I was never going to ride hard, an NGK 7 heat range would be ok.
Old 06-29-2012, 05:27 AM   #7
anotherguy
anotherguy's Avatar
Oddometer: 4,314
I disagree,with a heavy load of modern oil,premium pump gas and correct jetting this is what some old plugs (5K miles or so) from my '84 RZ 350 look like. A healthy spark is required though.
When injustice becomes law,resistance becomes duty.
Thomas Jefferson
Old 07-06-2012, 03:00 PM   #8
caryder
caryder's Avatar
Oddometer: 174
Plug color
Are those NGK8 heat range? They look fantastic for 5K miles. However, pre-mix air cooled motors will most likely need to run rich if run hard and that will also create more deposits even with good oil and gas.
To the OP, for 1.5 hours, that does look like a terrible amount of carbon deposits. I would try a hotter plug and pull the head and inspect the piston after a hard run. If all is well, then run with the hotter plug. Your diagnosis seems correct.
But of course this advice comes from some random guy on the internet.
Chuck
2012 Honda NC700X
2006 Gas Gas 300 Pro
2003 Kawasaki KDX220R
1976 Yamaha RD400C
caryder is offline   Reply With Quote
Old 07-09-2012, 07:41 AM   #9
AC Swank
Ignored & forgotten
AC Swank's Avatar
Oddometer: 9,592
Those look ideal!
AC Swank is offline   Reply With Quote
Old 06-29-2012, 03:56 AM   #10
Low Budget
Veteran "Have Not"
Low Budget's Avatar
Oddometer: 322
Thats alot of junk built up on the 9 for only 1.5 hours......especially if you were on the pipe alot and you say it wasnt stuttering and seemed to run good.
On that setup, did it four stroke or foul at low RPM or idle ? What kind of fuel are you running. What kind of oil and what ratio ?
Second plug is looking fairly good, but, I woulda guessed you had a hour of run time by its looks.
Low Budget is offline   Reply With Quote
Old 06-29-2012, 04:07 AM   #11
stainlesscycle OP
Oddometer: 1,639
yeah, i'm not used to seeing plugs with that much stuff on them. it looks way worse in pics than the naked eye.did not foul or 4 stroke at all. idles fine. starts first kick without tickler when hot. needs tickled when cold. runs great at all throttle positions, no bog/stutter anywhere. on the pipe all the time. bike can't get out of it's own way until 6000rpm+.... running 93/112 50/50 ratio. 40:1 amsoil dominator.
i generally jet using the put it in third gear, cruise around, then wack throttle to the throttle position i'm jetting. see if it reacts properly, gets on the pipe right, pulls through transitions properly.. i also extensively check jetting uphill in wrong gear to make sure it pulls hard and doesn't 4 stroke/bog out under load.
i'm thinking b8es might spark better - i think i'm in the right heat range and timing now - the threads/strap are discoloring about right..
current bikes
stainlesscycle screwed with this post 06-29-2012 at 06:35 AM
Old 06-29-2012, 06:31 AM   #12
stainlesscycle OP
Oddometer: 1,639
yeah, but piston port versus reed valve definitely makes a difference on plug life.. either way i don't believe my first plug should look like that.
current bikes
stainlesscycle screwed with this post 06-29-2012 at 04:33 PM
Old 07-08-2012, 06:41 PM   #13
bondbmw
Oddometer: 50
Last time I had a plug like that the deposits were molten aluminum from the piston. Sure you're not detonating? Bit lean?
'11 K1300S
'06 DR-Z 400
'84 RZ350
'81 TS100
'61 MGA
bondbmw is offline   Reply With Quote
Old 07-09-2012, 03:00 AM   #14
stainlesscycle OP
Oddometer: 1,639
naw, i pullled the head and piston looks fine. the deposits look like carbon, not aluminum
current bikes
Old 07-09-2012, 05:15 AM   #15
anotherguy
anotherguy's Avatar
Oddometer: 4,314
If the jetting is correct and the plug won't clean itself the heat range is off. Or the ignition is weak. Tread lightly here.
Thomas Jefferson
Times are GMT -7.   It's 12:00 AM.
