Old 08-07-2012, 01:39 PM   #1
Crashtestdummy7 OP
Oddometer: 5
Wink 990 Adv KTM Auxillary lights
Official 990 Adv Auxillary lights- TOP BIT OF KIT
Have recently posted this to the UK KTM forum.....hope this helps someone out there decide.....
Ok, bought the KTM powerparts auxillary lights in the end. Got a good discount through a KTM dealer.
As a complete Luddite i decided to give it a go and fit them myself. TBH, it took a while but i'm pleased with the results.
1st - Take off both sides of the top fairing, then remove the headlight "mask" - your left with a jumble of wires and connectors. Follow the KTM instructions- they arent bad
2nd - Then remove the RH starter switch/kill switch assembly and replace with the new starter/kill switch and headlight assembly kit from the lighting kit (this would have been on Advs pre 2003 before the eurowonkers decreed all bikes must have permanently wired in dipped lights.
3rd- Plug in the new wiring loom from the supplied kit and attach the brackets through the front cockpit subframe. Then bolt the very slinky led lights (3 power settings on the back of each lamp)
4th- Connect all the bullet connectors, block connectors, cable tie extra wiring in, then plug the headlamp mask back into the new wiring harness and switch on- HEY PRESTO !! And then there was light !!!
When i had the headlight mask off i even upgraded my regular bulbs.
The image below is on the low setting, theres a medium and a laser burning eyeball scorching high setting too.
5th - Once happy all is working bolt side panels back on and you get this .....
Result !!
Dipped headlight is still permanently on and the main beam comes on with the LH trigger switch on the LH switch. The new engine start/ kill switch and lighting switch on the RH bar now controls the new LED lights. Off position is all off, original sidelight switch now controls the on/off LEDs when you use the LH trigger switch, (a very slight delay due to voltage drain). Dipped beam setting switches both LED lights on permanently.
Sleek, stylish, protected from damage in monr drops as inside the fairing and not outside
I can thoroughly recommend these- they even do a different kit for the SMT ( different brackets). I looked at loads of variants, some cheaper but would have meant cutting wires, installing aftermarket switches, brackets - in the end only marginally cheaper. My dealer would have installed the KTM stuff for me - but gave it a go. Instructions not bad- if you can build a lego house, you can install these beauties- just take your time.
I'm a complete luddite- if i can do it, ANYONE can !!
Crashtestdummy7 is offline   Reply With Quote
Old 08-08-2012, 04:43 AM   #2
vonotto
vonotto's Avatar
Oddometer: 250
Nice, thank's for the wright up
vonotto is offline   Reply With Quote
Old 08-08-2012, 05:37 AM   #3
mato409
Oddometer: 45
hi, im between this and the rigid dualys, do you have pics on the nigths..
the kit came witth the RH starter switch/kill switch ?
looks very clean set up.
mato409 is offline   Reply With Quote
Old 08-08-2012, 02:32 PM   #4
pebble35
pebble35's Avatar
Oddometer: 1,535
Yes it comes with the RH switch.
Got them on mine - no night time pics but they do improve visibility a lot. Quick and easy 'plug and play' fitting.
Proud to be supporting Pyndon
www.lyndonposkittracing.com
www.bikersjersey.com for all your KTM parts
A 2,400 KM ride around Egypt by Scooter - ride report here
pebble35 is offline   Reply With Quote
Old 08-09-2012, 07:59 AM   #5
mato409
Oddometer: 45
you could put a picture of night on the road
thanks
Old 08-09-2012, 08:29 AM   #6
pebble35
pebble35's Avatar
Oddometer: 1,535
thanks
Will do - next time the wife lets me out after dark
Old 08-08-2012, 11:00 AM   #7
stevodadevo
What happened?
stevodadevo's Avatar
Oddometer: 177
Do you have the part number?
stevodadevo is offline   Reply With Quote
Old 08-08-2012, 02:28 PM   #8
pebble35
pebble35's Avatar
Oddometer: 1,535
Part number for the Adventure kit is 60114910033.
Old 08-09-2012, 05:34 AM   #9
ShadySmurf
Does Own Stunts
ShadySmurf's Avatar
Oddometer: 540
Anyone have these with a high fender installed?
ShadySmurf is offline   Reply With Quote
Old 08-09-2012, 08:29 AM   #10
pebble35
pebble35's Avatar
Oddometer: 1,535
99% sure they will not fit with a high fender unless you modify the mounting positions.
Old 08-10-2012, 02:30 PM   #11
pebble35
pebble35's Avatar
Oddometer: 1,535
A couple of pics
Dip beam only
Main beam
Main beam with aux lights
Hope these give an idea of how bright the lights are
Old 08-11-2012, 05:20 AM   #12
sanjoh
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,126
Looks like a pair of Trailtech 35mm LEDs.
Old 08-11-2012, 01:25 PM   #13
pebble35
pebble35's Avatar
Oddometer: 1,535
that does look very similar. But at US ? $123 per side that works out at about 160 for the pair - plus UK VAT/shipping/import duty.
The KTM kit is 190 plus VAT -and that includes mounting brackets for the lights, plug and play loom, and neat switch solution. I reckon it makes the KTM kit excellent value for money !
Old 08-12-2012, 04:44 AM   #14
cat
cat's Avatar
Oddometer: 1,323
Where did you get it for 190 pounds? I've just searched and i'm seeing $395 and $330.
cat is offline   Reply With Quote
Old 08-12-2012, 11:57 AM   #15
Peanuts
Peanuts's Avatar
Oddometer: 1,634
60114910033 AUX LED LIGHT KIT 221.93 inc VAT or 188.64 after 15% discount from a friendly UK mainland dealer
But if you just want the two lights and brackets it's cheaper
60114910000 ADD. LED LIGHT 164.17 inc VAT or 139.54 after 15% discount
Peanuts is offline   Reply With Quote
Times are GMT -7.   It's 07:08 PM.
