Old 08-15-2012, 05:52 PM   #1
Canuman OP
Crusty & Unobliging
Canuman's Avatar
Oddometer: 4,663
Give Me A Sanity Check -- KDX200
I've been through the gamut. I started on road bikes and scooters, caught the dual-sport bug bought a KLR, then a DRZ400E. I am currently lusting for a little bike -- a true trails bike. I am too old and fat for a motocrosser, and frankly, MX doesn't interest me. What I've been looking for is something small and light to ride on the trails close to home. I have an XT250 project in the pipe, but it's an old and slightly stodgy machine whose suspension won't ever approach modern standards.
An inmate and friend has offered me his KDX200. I think it's an '03, but I could be mistaken. He's reluctant to let it go, but needs the cash to build his business. He's an ultra-anal bastige, and takes superb care of all his machines. He also rides them hard, so the bike's not a virgin.
Am I about to get a butt-whuppin? The thing makes 37 hp from a bike that's about 270 pounds wet. Except for the family's Vespa scooters, I've not ridden a two-stroke in many years. I have the check in hand, because I like the look of the thing and think it could be a tremendous hoot.
I have the Kool-aid glass in my hand as I write this. Should I swallow?
The Rock 2013 RR
http://advrider.com/forums/showthread.php?t=915172
Dual Sport Luggage Racks: http://www.moto-racks.com
hONORARY mEMBER fIRST aMERICAN cHAPTER tEAM nONGA (pROVISIONAL wING)
Canuman screwed with this post 08-16-2012 at 10:00 PM
Canuman is offline   Reply With Quote
Old 08-15-2012, 05:59 PM   #2
lewismedlock
lewismedlock's Avatar
Oddometer: 13,516
A buddy of mine had one. We traded bikes on the trail one day, and I dropped it in the first corner. It didn't have the compression braking of my 4-stroke! I was impressed with it. Once I remembered how to use the back brake, I enjoyed riding it. Light, and with plenty of power, I'd like to have one.
lewismedlock is offline   Reply With Quote
Old 08-15-2012, 06:10 PM   #3
Canuman OP
Crusty & Unobliging
Canuman's Avatar
Oddometer: 4,663
That was the impression I got. I'll need to adjust my riding style significantly. I am a compression-braking whore. My first real bike was an airhead BMW. I rarely used the brakes. I'd just kick her down a cog and things would slow down. The brakes weren't really that good anyway. The compression braking was superb.
The Rock 2013 RR
Canuman screwed with this post 08-15-2012 at 06:39 PM
Old 08-15-2012, 06:31 PM   #4
stainlesscycle
stainlesscycle's Avatar
Oddometer: 2,280
you'll get used to it. i can't ride a 4 stroke in the woods anymore to save my life. modern 2 stroke is a lot of fun in the woods. just ride a gear higher than you would normally and it'll smooth it all out for you. throttle control is everything. use the brakes to your advantage. can't brake slide with compression braking learn to love the clutch to get on the pipe.
current bikes
stainlesscycle is offline   Reply With Quote
Old 08-15-2012, 06:35 PM   #5
Harvey Krumpet
Oddometer: 912
I like them. Had a KDX 250 for awhile which was a bit of a beast with a race pipe. The 200's are very highly regarded down here as a do it all trail bike but not intimidating. Plenty are still being ridden in Clubmans enduros & trail rides.
I have a DT 230 in the garage which makes more power, is heavier, has less suspension & it's an absolute blast.on trails.
If it's a good bike buy it, heaps of fun.
Harvey Krumpet is offline   Reply With Quote
Old 08-15-2012, 08:43 PM   #6
dpforth
no inline fours
dpforth's Avatar
Oddometer: 331
Are you sure about that weight, seems awful heavy? I looked and found 222lbs dry, which seems close, maybe a bit low.
This species has amused itself to death
dpforth is offline   Reply With Quote
Old 08-16-2012, 02:11 AM   #7
stainlesscycle
Oddometer: 2,280
almost all the manufactures are pretty optimistic when it comes to 'spec weight'. it's probably close to 260-270 wet. but since all the manufacturers do it, the lighter bikes all feel light comparatively,
again, this spec is for a brand new bike. it could still be making that (or maybe more depending on what's been done to it). don't let that hp scare ya - it's all how it delivers the power. it's a kdx, not a mx bike, so it's not gonna rip your arms off....
the kdx is a great trail bike, very forgiving. and enough power when you need it.
current bikes
Old 08-16-2012, 05:30 AM   #8
Canuman OP
Crusty & Unobliging
Canuman's Avatar
Oddometer: 4,663
My friend has done the top end, if the Wiseco Pistons sticker means a thing. He's not a guy to slap stickers on at random. I'm pretty sure it will be near rated power.
At 200 lbs less than my KLR in running trim and probably at least 60 lbs less than the DRZ, it's going to be a significant difference in weight.
Anyone used a "gnarly woods pipe" on one of these? Worth the biscuit?
The Rock 2013 RR
Old 08-16-2012, 09:35 AM   #9
JWhitmore44
pistolero
JWhitmore44's Avatar
Oddometer: 1,624
Great place for KDX info http://www.dirtrider.net/forums3/forumdisplay.php?f=6
My son has a 01 KDX220, it's kind of like the 2 stroke version of the XR400. Nice lower end torque for a 2 stroke, just as said before, not as much compression breaking. You can't be quite as lazy as you can on a 4 stroke but they lug pretty good. Most info that I read says to use the woods pipe on the 200 as the 200 doesn't have quite as much low end as the 220. XR400 springs in the forks supposed to help the front, the rear shock isn't too bad unless you are really heavy. It's a nice light trail bike, easy to pick up when you dump it. Easy to wrestle around on tight trails. It was made for trails :)
84 Honda Goldwing (GL1200)
03 XR650L
JWhitmore44 is offline   Reply With Quote
Old 10-13-2012, 08:32 AM   #10
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,867
222 is lighter then a KTM200 dry. KDX's tend to weight 20 lbs more at least over a KTM. The older KDX's were REALLY heavy,like back in the 80's/90's.
They make a great bike for someone getting into the 2 stroke game in the woods,easy to ride,last a long time.
Ride one for a while then try a KTM200,any year will do. So much skinnier lighter faster torquier it will knock your socks off.
I know us KTM loons come off as loons,its just how it is.
They are THAT good!
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 08-15-2012, 08:52 PM   #11
Harvey Krumpet
Oddometer: 912
Prolly about right wet. HERE.
13 ltrs of go fluids, a bit of brake fluid & coolant. Sounds spot on.
Old 08-16-2012, 09:31 AM   #12
Shocktower
Shocktower's Avatar
Oddometer: 9,485
I think you need it, and the weight is a little high, my KTM 530 only weighs 247, enjoy the ride
Alexa Drew Nov 9 1995- Oct 28th 2004 Miss you baby
'08 KTM 530 EXC
79 RD 400 Daytona
Shocktower is offline   Reply With Quote
Old 08-16-2012, 04:06 PM   #13
Canuman OP
Crusty & Unobliging
Canuman's Avatar
Oddometer: 4,663
I now own it. Paid for it today. My buddy inmate Jackpiner57 (rack fabricator extraordinaire) filled me in a little more. It's an '02, with the top end job done not so many running hours ago by some KDX guru in Indiana, trick reeds, and a pipe. It's not the woods pipe. He also has the stock pipe. I'll need to re-spring the shock, as he weighs quite a bit less than I. The forks feel fine. The bike is relatively minty for a dirt bike, and has been plated in VT. Gotta love it. It has a few scratches, but hasn't been thrown away into too many New England granite walls. It's the appropriate green.
The Rock 2013 RR
Old 08-16-2012, 04:12 PM   #14
Harvey Krumpet
Oddometer: 912
I'm looking forward to reading your thoughts & observations when you have had some time to live with it. Congratulations
Old 08-16-2012, 10:36 PM   #15
PistonPants
Crankcase Scavenger
PistonPants's Avatar
Oddometer: 453
Enjoy the KDX. It is, hands down, the finest small bore enduro bike EVER to come out of Japan. Learn to shift a lot. You got a six speed on a bike that will barely do 50. If you want engine braking, grab second.
Peace
Piston
PistonPants is offline   Reply With Quote
Times are GMT -7.   It's 12:12 PM.
