Old 08-27-2012, 06:43 AM   #1
machinebuilder OP
Oddometer: 1,136
F800GS Suspension Upgrade
I just finished my suspension upgrades,
After reading countless posts about the crappiness of the stock suspension and getting more experience on the bike and dirt/gravel/rocky roads, I started thinking all the more knowledgeable riders were not happy with there stock suspension and had gone through some sort of upgrade, especially the forks. The eyeopener came when I went on a dualsport ride with the BMW Riders of Knoxville, and realized while they weren't going really fast I was struggling to keep up. Most of my riding I am alone and tend to poke along and sightsee alot.
after spending even more time reading threads and learning I knew nothing about suspensions, I bought Ned's suspension Ebook, and learned enough to have an idea what people were talking about.
I got prices from Ohlins and Traxxion Dynamics for the forks (racetech never replied back) and decided the $600 more for Ohlins couldn't be worth it.
I pullled my forks off and sent them to Traxxion Dynamics to have them install the kit (I really didn't have the time with working 50-60hrs/week). it was a 8 day turnaround, and I had them 10 days later.
After a quick test ride, I was like what an unbelieveable difference, when I went from pavement to dirt I didn't realize and I was riding about 15mph faster. then I realized the shock sucks, and I was bouncing around.
I had decided going into this that I wasn't going 1/2 way, so I already had a Wilbers shock on order, they were a bit backed up and it took 4 weeks to get it, I picked it up on thursday and got it installed by Friday evening. (don't follow everything in the Haynes book, why would you take the muffler off?)
Saturday I got woke up and left to ride some of my favorite dualsport roads near Tellico Plains.
The fork upgrade deffinatly made MUCH more change, but the shock really settled things in. I hit everything from nice smooth pavement to wased out rutted dirt/gravel. It was the best Saturday I've had in quite a while.
If someone had told me how much difference this would make I would not have believed or understood. NOW I understand when told that a suspension is the most bang for the buck. It really feels like a completely different bike, on and offroad.
Costs are not cheap.
Traxxion Dynamics AK-20 $1200+$200 installation (I got the "hardcore" offroad setup)
Wilbers shock + remote preload = high/low speed compression adjusters $1200
BIgger GRIN priceless
EDIT: I finally got enough courage to start playing with adjustments, and then decided a bigger adjustment was needed to really see what was changing, I turned both fork adjustments out about 2 1/2 turns and the shock adjustments out about 1/2 turn, this is taking the jolt out of the potholes and square ledge type hits.
the best thing to buy for your bike is gas.....Neduro
Remote is not found on the coffee table
machinebuilder screwed with this post 07-07-2013 at 06:41 PM
machinebuilder is offline   Reply With Quote
Old 01-07-2013, 12:27 PM   #2
biodieselandon
biodieselandon's Avatar
Oddometer: 358
Is this the same company that is producing the new rear shocks for Touratech? Are your forks adjustable now?
2013 BMW F800GS, Cordoba Blue, ASC, ESA, ABS
2012 BMW G650GS - 13,000 miles ***SOLD***
"If you're not mixing gas, you're not hauling ass!"
"A clean GS is a dirty shame."
biodieselandon is offline   Reply With Quote
Old 01-07-2013, 02:31 PM   #3
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,754
Almost right on the name; the Touratech shocks are made my Tractive not Traxxion
Loutre is online now   Reply With Quote
Old 01-07-2013, 02:41 PM   #4
biodieselandon
Oddometer: 358
Oh yeah that's right. So are yours adjustable?
Old 01-07-2013, 05:36 PM   #5
machinebuilder OP
Oddometer: 1,136
Yes they are adjustable for preload, and have rebound in 1 leg and compression in the other.
Old 01-07-2013, 07:43 PM   #6
biodieselandon
Oddometer: 358
Maybe that is the route I will go instead of Ohlins.
Old 01-08-2013, 03:02 AM   #7
machinebuilder OP
Oddometer: 1,136
And save yourself a lot of $$$$
Old 01-08-2013, 12:38 PM   #8
picard
engage!
picard's Avatar
Oddometer: 1,300
I have the Traxxion setup and really like it. It's fully adjustable, preload / compression / rebound. I also have an Elka in the back and like it even better. So much for saving $...
"Rumors of my assimilation are greatly exaggerated." (Capt. Picard)
picard is offline   Reply With Quote
Old 01-08-2013, 04:06 PM   #9
machinebuilder OP
Oddometer: 1,136
The money savings is the price difference between Ohlins and Traxxion. Its about 1/2 the cost of my Wilbers shock.
Old 01-08-2013, 05:58 PM   #10
DoWorkSon
Oddometer: 270
How hard is it to install the traxxion kit?
DoWorkSon is offline   Reply With Quote
Old 01-09-2013, 03:01 AM   #11
machinebuilder OP
Oddometer: 1,136
I did it the easy way and sent them my forks. I really didn't have the time to do it.
Indyunlimited has installed several sets.
They are a drop in replacement for up to 2012, no machining involved.
Old 01-09-2013, 03:44 PM   #12
Indy Unlimited
Indy Unlimited's Avatar
Oddometer: 1,405
Yeah they are easy to do.
You need an impact gun to loosen the stock cartridges and tighten the new ones in.
Traxxion sells a special thin 17mm wrench for tightening the fork caps to the cartridge.
Install with 7.5 W oil in each fork at around 100 mm from the top of the collapesd fork.
It measures close to 500ml / fork.
I think they charge $120 to do the work.
Current Stable:
2013 Ducati Hypermotard SP, 2011 Husaberg FE570S, 2011 BMW S1000RR, 2010 BMW F800GS
2007 Husqvarna TE610 , 2003 KTM 525 MXC
Indy Unlimited is offline   Reply With Quote
Old 02-10-2013, 12:36 PM   #13
xsf18cdf
Oddometer: 94
If anyone has a 2013- your front forks are not the same as '12 and earlier. Ohlins and Konflict are working on setups for the WP forks that come on the new bikes. Waiting to get mine done with whoever gets their kit done first since both places are highly regarded.
Gary
xsf18cdf is offline   Reply With Quote
Old 02-10-2013, 08:54 PM   #14
Indy Unlimited
Oddometer: 1,405
Why wait, Send your forks to Traxxion they can custom install on any forks.
I had that done for a custom Versys with 8" of suspension travel.
they can turn it in about 3 weeks.
Current Stable:
Old 02-11-2013, 11:42 AM   #15
AMusedRider
AMusedRider's Avatar
Oddometer: 16
suspension ebook?
machinebuilder,
What book is this? Is it specific to a certain class of motorcycles or generic?
Do you have a link to it?
AMusedRider is offline   Reply With Quote
Times are GMT -7.   It's 11:31 AM.
