Old 09-26-2012, 10:36 PM   #1
maigashi OP
maigashi's Avatar
Oddometer: 116
Preparing a bike for winter
Just getting ready to put the bike in the garage for winter. Anything I should know for prepping her for a few months slumber other than a little fuel stabilizer and a trickle charger?
maigashi is offline   Reply With Quote
Old 09-26-2012, 10:41 PM   #2
Rinty
Rinty's Avatar
Oddometer: 543
Change the oil, perhaps, and put it away. I wouldn't worry about fuel stabilizer. And Saskatoon's nice and dry, so you won't have any corrosion.
Rinty is offline   Reply With Quote
Old 09-27-2012, 03:39 AM   #3
Kiwi Tinkerer
Ross
Kiwi Tinkerer's Avatar
Oddometer: 383
Hot grips
Prep for winter. make sure the hot grips and heated vest are working.
Does not get so cold here.
Kiwi Tinkerer is offline   Reply With Quote
Old 09-27-2012, 04:06 AM   #4
machinebuilder
Oddometer: 1,090
Snow tires
I don't have much "winter" my riding picks up after the hot summer
the best thing to buy for your bike is gas.....Neduro
Remote is not found on the coffee table
machinebuilder is offline   Reply With Quote
Old 09-27-2012, 05:47 AM   #5
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,607
Originally Posted by machinebuilder View Post
Snow tires
yeah get some chains on them
Keep the smile on your face!
Originally Posted by Reaver View Post
You can be imitated but not replaced. You're such a special blend the recipe is guarded like KFC's 11 herbs and spices.
Homeless Otter on the road – One month to find the rising sun
Loutre is offline   Reply With Quote
Old 09-27-2012, 08:50 AM   #6
maigashi OP
maigashi's Avatar
Oddometer: 116
Surely you jest but there is a guy across the street from me with a KLR he rides through the winter. Think he runs studs. Think my GS might be a little poky for that. And I've already broken my ribs this year. Fortune has not done me well do far. Lol
Old 09-27-2012, 10:06 AM   #7
Rinty
Rinty's Avatar
Oddometer: 543
When I was a kid, I used to ride year round on my Cushman and later, a Lambretta. I used them to carry newspapers to my paper route. It was no fun at 30 below. But at least those machines had a low centre of gravity.
Riding a KLR in a Saskatoon winter; I can't imagine that.
...fuel stabilizer...
None of my 4 stroke powered machines are fussed about running on old gas, but my 2 stroke machines could be cranky. However, a couple of years ago I started using Opti oils, and no more crankiness. In fact, my Stihl weed whip runs just fine on three year old gas. With Opti, you can mix it 100:1, and I am now running my Toro snowblower on 80:1 mix with the Opti.
Rinty screwed with this post 09-27-2012 at 04:05 PM
Old 09-28-2012, 07:14 AM   #8
Reaver
Outta Here
Reaver's Avatar
Oddometer: 3,080
My biggest issue with winter storage is mice! They love the snorkel's secret passageways and the air filter is a great place to build a nest. Under the back of the seat where alarm would go is a great place too. Had to do a wiring repair one day. I jam rags into the air intake holes and take the seat off for storage. That and Rat Poison.
As for fuel stabilizer, I never use it. I know it's much warmer in Southern Ontario and I usually get to ride at least once every winter month so I don't bother. The Dealership I worked at part time never did either. The used bikes were filled with premium gas and the batteries charged once a month. I've seen a few used bikes sit in the showroom for 3 yrs that start right up and run fine. The new bikes are treated the same and often sit for 6 months.
Putting the bike on the centre stand removes the weight from the rear tire/suspension and helps prevent flat spots but that's not a real issue. Change the oil if it's due but modern engines don't pollute the oil anywhere near as much as the old carbureted ones did so acid corrosion isn't an issue either.
Spending too many winter hours reading RR's and ordering farkles is the real problem!
Life is a Rollercoaster and I'm not strapped in!
Leaving it all behind 2014
Reaver is offline   Reply With Quote
Old 11-23-2012, 10:25 PM   #9
eddyturn
Wannabe
Oddometer: 1,896
Boy, no shit.
All things being equal... fat people use more soap
eddyturn is offline   Reply With Quote
Old 09-28-2012, 12:07 PM   #10
deguoren
该出手时就出手
deguoren's Avatar
Oddometer: 161
There are different opinions around regarding petrol in the tank.
An old school steel tank would be best filled up to the rim for storing the bike.
A plastic tank like the GS should be empty (so people say).
Mine was full with E10 petrol last winter, dint do any noticeable harm. Petrol with a higher ethanol content might be an advantage as this kind of petrol does not separate so easily. It keeps the water in solution.
Due to condensation water will accumulate in the tank.
(bitty knowledge)
Do what you love, and do it often. If you don’t like something, change it. If you don’t like your job, quit. Travel often; getting lost will help you find yourself. Some opportunities only come once; seize them. Life is about the people you meet and the things you create with them, so go out and start creating. Live your dream, and wear your passion. Life is short."
deguoren is offline   Reply With Quote
Old 09-28-2012, 03:46 PM   #11
CheckerdD
CheckerdD's Avatar
Oddometer: 1,280
Winter Ride Par Excellence
I can still remember January 1976. They guy who later became the owner of Trails End BMW in Fairbanks rode an R60 BMW from Fairbanks to Prudhoe Bay Alaska and back, then south down the Alcan. I was living in Fairbanks that year and he was the talk of the town. Aside from the usual mechanical things to keep the bike running in temperatures of 60 below, dry gas and lighter oil, he kept his face shield from fogging by adapting a skin divers snorkel to vent into the back of his coat so he could breath through it. I think he plugged up his nose. He also over inflated his tires so they would not crack from flexing at minus 60. I still consider that to be one of the ten most epic BMW rides ever.
As for the question presented. Change the oil because it becomes acid with use and charge the battery periodically. Most agree fill the gas tank completely to reduce condensation and use Stable in the gas. Dave
Pavement! We don't need no stinkin pavement.
CheckerdD is offline   Reply With Quote
Old 11-19-2012, 11:19 AM   #12
EPMD
EPMD's Avatar
Oddometer: 168
easy prep
Easiest method is to do nothing and ride year round.
(Get heated gear.)
EPMD is offline   Reply With Quote
Old 11-21-2012, 06:20 PM   #13
Kiwi Tinkerer
Ross
Oddometer: 383
Like this guy
Old 11-24-2012, 09:45 AM   #14
maigashi OP
maigashi's Avatar
Oddometer: 116
Riding year round is less fun at -40. But if it thrills you.....
Old 11-24-2012, 12:31 PM   #15
8thdwarf
perfect,just perfect
8thdwarf's Avatar
Oddometer: 129
move to SoCal. then you don't have to worry about stashing the beast for the winter.... cuz there is no winter here
8thdwarf is offline   Reply With Quote
Times are GMT -7.   It's 01:35 AM.
