Old 09-27-2012, 08:23 AM   #1
Roughseas OP
Roughseas's Avatar
Oddometer: 57
140 or 160 tyre on a R1150GS?
Cant find any 150/70 size in the market here and was wondering if anyone tried a 160/60 for the rear? The tourance I have on has the tread depth but has become brittle and breaking off in chunks
Roughseas is offline   Reply With Quote
Old 10-06-2012, 05:53 AM   #2
Roughseas OP
Roughseas's Avatar
Oddometer: 57
Anyone? 140/70 or 160/60
Old 10-08-2012, 03:17 AM   #3
OzRob
OzRob's Avatar
Oddometer: 638
I used to run 140's Heindenau K60's with no problem and a mate of mine runs E07's as they are cheaper than the 150's
I recently read a post where a bloke on a trip around Oz fitted a 160/60 road bike tyre on his GSA 1150 so he could get home.
OzRob is offline   Reply With Quote
Old 10-06-2012, 05:58 AM   #4
jdub
Dawg bytes reel gud
jdub's Avatar
Oddometer: 1,385
Haven't done it myself, but there are numerous threads here where inmates have successfully installed and run 140 width tires on their GS/GSA.
'07 R1200GS Adv. & '00 DRZ400S
Step-by-Step R1200GSA Gearbox Removal and Clutch Spline Lube Process
Another 100,000 Mile R1200GS Adv.
R.I.P., my faithful dog Ripley (ref. my avatar). April 2001 - April 2013
jdub is offline   Reply With Quote
Old 10-06-2012, 07:25 AM   #5
mcstark
Oilhead convert
mcstark's Avatar
Oddometer: 930
I have not run anything other than a 150mm Tourance, but looking at the Metzeler spec chart I think a 140 would be a tight fit. The 150-section tire has a max diameter of 650mm, but the 140-section tire has a max diameter of 667mm. That's .67 in, which eats up half the clearance between the rear tire and the lower shock mount.
Too tight for my liking. What tire were you looking at in 160mm-section?
Regards,
Mark
2003 BMW R1150GS
mcstark screwed with this post 10-06-2012 at 07:31 AM
mcstark is offline   Reply With Quote
Old 10-06-2012, 08:00 AM   #6
mousitsas
Oddometer: 2,148
The 140 dimension is a far better choice for the 4" rim size, than the 160.
Old 10-06-2012, 09:56 AM   #7
Ua the Destroyer
Ua the Destroyer's Avatar
Oddometer: 162
Lots of people ran the 140/80-17 mitas e09 and heidenaus on their gs's in the past before the correct size was available
some pictures and measurements in this thread
http://advrider.com/forums/showthread.php?t=614147
Ua the Destroyer is offline   Reply With Quote
Old 10-06-2012, 10:33 AM   #8
Beezer
Oddometer: 4,442
depends on the tire... I've seen 120 tire that were wider than 130 and 130 that were wider than 140.
P.S. I have run a 130 TKC on my 1150 & it worked fine
Beezer is offline   Reply With Quote
Old 10-06-2012, 12:02 PM   #9
Roughseas OP
Roughseas's Avatar
Oddometer: 57
Thats the reply I wanted
I am looking at a Conti-go 140/70 for the rear. The 150/70 is almost non existent in the Indian market and the only options I have are the 140/70 Pirelli SD or the Conti-go. Thanks all!
Old 10-06-2012, 01:02 PM   #10
Ua the Destroyer
Oddometer: 162
Well a 140/70 has a smaller diameter (14mm smaller) than a 150/70, but should work fine. your speedo will read a couple kph faster than your speed with that size tire, but not enough to be a big deal.
Old 10-07-2012, 01:51 AM   #11
Zoef zoef
Oddometer: 255
Sir, the speedo on a R1150GS works on the front wheel, and if I'm not mistaken we are talking about the back wheel here?
Zoef zoef is offline   Reply With Quote
Old 10-07-2012, 04:57 AM   #12
SR1
I'm a Seoul Man...
SR1's Avatar
Oddometer: 3,800
Send a message via Skype™ to SR1
I just put a 140 Heidenau on my GS. It's rubbing the Maier hugger a little offroad, but it doesn't look bad so far. I like the height and the feel. We'll see!
BMW GS and Yamaha WR250X/R (split personality)
Save $5 on a Smugmug account, use this code:
hVs9vtN9NsQRQ
SR1 is online now   Reply With Quote
Old 10-08-2012, 10:53 PM   #13
Ua the Destroyer
Oddometer: 162
Laugh
Duh brain fart
Old 10-06-2012, 02:02 PM   #14
mcstark
Oilhead convert
mcstark's Avatar
Oddometer: 930
The Tourance is a 140/80, which makes the difference. A 140/70 should be fine.
Regards,
Mark
2003 BMW R1150GS
Old 10-11-2012, 06:01 PM   #15
BostonGS
Oddometer: 267
140's
I used a 140 Mitas e09 on my 1200gsa recently...best dirt tire for the GS/A in my opinion. I don't like the K60 (comparing it to the TKC 80).
BostonGS is offline   Reply With Quote
Times are GMT -7.   It's 09:27 PM.
