Old 09-28-2012, 11:13 AM   #1
MotoJ OP
Mobtown Hacker
MotoJ's Avatar
Oddometer: 1,175
Pipe frame?
I see this debate on 4x4 sites, where it pits brother against brother, but haven't come across it here, so I thought I'd inquire and see what the hack builders thought:
Is 1-5/8" ID A500b schedule 40 pipe (which is rated as structural, used for railings and such) OK to fab a sidecar frame from, or is that suicidal, and only 1-3/4" x .12 DOM tube should be used?
The ladies used to check me out...now they just keep an eye on me.
MotoJ is offline   Reply With Quote
Old 09-28-2012, 02:46 PM   #2
YOUNZ
Oddometer: 324
It would depend on the design. I used the square tubing from unwanted work-out machines for my sidecar frame and it works great. Not the traditional design, though.
YOUNZ is offline   Reply With Quote
Old 09-28-2012, 05:18 PM   #3
leejosepho
Sure, I can do that!
leejosepho's Avatar
Oddometer: 490
Maybe you mean 1-1/2" ID?
In any case, I matched the frame of my bike by using round 1-1/4" OD x .120 DOM tubing, and I cannot imagine needing anything any larger or heavier than that.
He who so shall, so shall he who.
leejosepho is offline   Reply With Quote
Old 09-28-2012, 05:35 PM   #4
Strong Bad
n00balicious
Strong Bad's Avatar
Oddometer: 4,192
Why do you ask?
Either one could fit into a design criteria. Most fabricators don't build vehicles out of pipe, more commonly tubing is used, but not always.
Why simple DOM, why not 4130??
Again, why do you ask? You got a bunch of pipe laying around you want to build a sidecar frame with?
BTW, most pipe charts show what you call 1 5/8 ID A500b Schedule 40 pipe is what is commonly called 1 1/2" pipe, it nominally measures out to 1.90" OD and 1.61" ID.
"I couldn't wait for success, so I went ahead without it."
Strong Bad is online now   Reply With Quote
Old 09-28-2012, 05:52 PM   #5
MotoJ OP
Mobtown Hacker
MotoJ's Avatar
Oddometer: 1,175
Originally Posted by Strong Bad View Post
Why do you ask?
As a matter of fact, yeah, there is a bunch of pipe lying around I could get cheap. Don't know about pipe either, I saw the labels and started investigating, and I didn't consult any charts, I just stuck a tape measure against the end.
What's with the attitude anyway?
Old 09-28-2012, 06:21 PM   #6
Strong Bad
n00balicious
Strong Bad's Avatar
Oddometer: 4,192
Attitude?? Gee.....I thought I was providing you with technical information you could use. Having been a weldor/fabricator in a past life, the numbers (and the way you presented them) were kind of squirrely and I had to consult a chart to try to figure out what you were trying to talk about. The information I provided could allow you to to present yourself more intelligent manor if you are so inclined.
Why you getting your panties in a bunch?
Old 09-28-2012, 06:47 PM   #7
MotoJ OP
Mobtown Hacker
MotoJ's Avatar
Oddometer: 1,175
Sorry, guess I misunderstood your own "intelligent manor". Maybe you should consult a dictionary.
Old 09-29-2012, 03:41 AM   #8
BeeMaa
Hack Pilot
BeeMaa's Avatar
Oddometer: 1,098
Easy there Strong Bad.
You did the same as I would have done.
Nothing to get worked up about here.
Cheers.
Eric B
'06 R12GSA/Hack & '10 R12GSA
An armed society is a polite society. Manners are good when one may have to back up his acts with his life. Robert A. Heinlein
BeeMaa is offline   Reply With Quote
Old 09-29-2012, 10:16 AM   #9
Strong Bad
n00balicious
Strong Bad's Avatar
Oddometer: 4,192
Cheers.
Cheers BeeMaa!
Old 09-28-2012, 05:51 PM   #10
haystack
Just ride
haystack's Avatar
Oddometer: 4,055
Just my opinion, Don't build motorcycle (or sidecar) frames with pipe. How much more will it cost to use the proper tubing?
http://chopperhandbook.com/tubing.htm
Indeed, This is a gentleman's game....
German W.O.D. Certified
2014 Winner of the Biggest Potato in Jersey
haystack is offline   Reply With Quote
Old 09-28-2012, 06:11 PM   #11
MotoJ OP
Mobtown Hacker
MotoJ's Avatar
Oddometer: 1,175
Thanks for the link, Haystack. Lots to digest.
I haven't priced tubing, but someone offered me twelve 12' pcs of the pipe for $50.
From the looks of it I figured it couldn't be any worse than the crap my Dnepr frame is made of.
Googling it led me to 4x4 forums where there's big debate about using one or the other for roll cages.
Old 09-28-2012, 06:24 PM   #12
haystack
Just ride
haystack's Avatar
Oddometer: 4,055
It is my understanding that the black pipe is very rigid/brittle and can/will break from impact or stress. There are lots of places to read about proper tubing for frame building. I sent that link because I already had it in my favorites from when I was looking for info on building a springer front end.
haystack screwed with this post 09-28-2012 at 06:31 PM
Old 09-28-2012, 09:39 PM   #13
brstar
brstar's Avatar
Oddometer: 443
Thumb Pipe
So if you have available some pipe that is almost 2" diameter with reasonably thick walls and the ability and equipment at your disposal to be able to fabricate a frame with then I cannot see why not. Notching the ends to butt together may represent a challenge as may welding and bending etc.
But that is the beauty of this site. If you work out a plan then put pictures up here as you progess there will always someone willing to comment and some even know what they are on about .
Of course frame materials are usually amongst the cheapest parts of a build. So press on and lets us all enjoy the journey with you.
PS, never mind attitudes other than your own, its the only one you control.
Cheers, Bruce
brstar is offline   Reply With Quote
Old 09-28-2012, 10:37 PM   #14
windmill
windmill's Avatar
Oddometer: 4,084
I have several old farm books showing how to make all sorts of small tractors, implements, and equipment, often using pipe for frames and structures.
I suppose it could be done, but are the savings on that amount of material worth it? You are betting your life on it.
"Take care, sir," cried Sancho. "Those over there are not giants but windmills".
windmill is offline   Reply With Quote
Old 09-28-2012, 11:09 PM   #15
M37cdn
Oddometer: 42
Pipe Sighs
Pipe...
One of my other hobbies is Four Wheeling my 1948 Willys Jeep......
My rollcage is made from 1 3/4 tubing ( .120 wall)
My Rock sliders (under the outside edges of the body are made from 1 1/2" PIPE ( the 1.9" outside diameter stuff)
the reason is I was tired of denting up my Sliders on every little 3 foot boulder that I drove over. .Pipe is waaaaay tougher than regular tubing, and as for anyone saying that it is brittle and will shatter...we are not talking about an Iron Plumbing stack from a 1920's house here...it's Steel Pipe...
To Summarize... I say use the pipe if it's regular A501... the only stuff to avoid is sprinkler tubing ( measures as pipe size but is thinner walled) ... this usually has the grooves for Victaulic fittings (heavy cast clamp around the pipe thingys)
M37cdn screwed with this post 09-28-2012 at 11:19 PM Reason: Spealing errurs
M37cdn is offline   Reply With Quote
Times are GMT -7.   It's 05:23 PM.
