Old 10-05-2012, 12:09 PM   #1
Älbler OP
Älbler's Avatar
Oddometer: 44
2009 1200GSA Build up on injectors
Couldn't get the bike to start. Took the injectors out and found white build up on them. Wiped it off and bike started without issues.
Anybody know what causes white build up on the injectors?
Thank you.
Älbler is offline   Reply With Quote
Old 10-05-2012, 09:19 PM   #2
def
Ginger th wonder dog
def's Avatar
Oddometer: 10,202
Moisture, damaged air filter, critter in the airbox.
def is offline   Reply With Quote
Old 10-06-2012, 07:29 AM   #3
Älbler OP
Älbler's Avatar
Oddometer: 44
Thank you for your reply.
I did not find any critters in the air box and the air filter is not damaged.
Are we talking about moisture in the fuel?
Somebody suggested white build up on the injectors could be caused by high alcohol content in the fuel.
Anybody else had that issue?
Old 10-06-2012, 07:48 AM   #4
The Evil Twin
Boxer Freak
The Evil Twin's Avatar
Oddometer: 474
Do you ride regularly? Normally, the continual flow of fuel (and the detergents in it) keeps injectors clean. Only time I have seen a whiteish build up was on something that sat for a while. My suspicion is moisture that has evaporated. The ethanol (alcohol) in fuel is hygroscopic, and will absorb a lot of moisture. Especially in a tank that has sat for a while.
CCS #132 Sponsors: DC-Moto.net, Amsoil, Manassas Honda Kawasaki, MARRC
2014 RCGT #1, Superbike #2 OA Mid Atlantic
2013 Amateur of the Year
2013 RCGT #6 OA Mid Atlantic
The Evil Twin is offline   Reply With Quote
Old 10-06-2012, 07:58 AM   #5
def
def's Avatar
Oddometer: 10,202
^^^^ Yes, what he said.
Old 10-06-2012, 10:09 AM   #6
Älbler OP
Älbler's Avatar
Oddometer: 44
That is probably it.
I don't know very much about the bike because I just got it. I rode it about 200 miles before it gave up the ghost.
It is a 2009 gsa with 10 kmiles ..... so the previous owner did not ride very much at all.
What I do know is that on my 1150 gsa with 40 kmiles the injectors were clean.
Thank you very much for your replies.
Old 10-06-2012, 02:50 PM   #7
ultane
sqeezin the bag
ultane's Avatar
Oddometer: 1,211
Chevron premium with Techron...
I might be wrong... Just ask my X...
Sent from my rotary dial iPhone using Tapatalk
I might be wrong, just ask my X...
If a man speaks, and there is no woman present to hear him,..
Is he still wrong?
ultane is offline   Reply With Quote
Old 10-06-2012, 11:04 PM   #8
JR356
JR356's Avatar
Oddometer: 3,835
http://www.amazon.com/Chevron-65740-...jector+cleaner
This is reputedly what BMW rebottles as their FI cleaner
Run 1/3-1/2 bottle thru for next several tanks.
Can be found online and at lots of stores.
JR356
JR356 is offline   Reply With Quote
Old 10-07-2012, 03:40 AM   #9
ultane
sqeezin the bag
ultane's Avatar
Oddometer: 1,211
Techron additive is also available at some Costco warehouses.
Is he still wrong?
Old 10-07-2012, 07:15 AM   #10
Älbler OP
Älbler's Avatar
Oddometer: 44
Great, I will do that.
Old 10-08-2012, 07:22 PM   #11
farrell caesar
Seezer
Oddometer: 408
injectors
I have been using acetone occasionally for 10 yrs. It is what's in injector cleaner, only it is $15 a gallon at napa. Add some zxylene for good measure. Should get better mileage too if you don't get heavy on the throttle from the extra power you get. Look it up under La pointe on net. He has been using it for 50 yrs. 3 OZ per 10 gallons of fuel for better mileage. Any more and you get worse mileage and maybe a burnt valve. Techron is good too. Acetone is 150 octane.
seezer
farrell caesar is offline   Reply With Quote
Old 10-09-2012, 04:50 AM   #12
ragtoplvr
Oddometer: 6,341
Inside your injectors are seals, plastics insulation. Pure acetone, not a blend but pure can damage them
I still vote for a tested injector cleaner solution in a ultrasonic bath while being pulsed.. I met the guy that made the first injector cleaner machine, and it was as much work to come up with a cleaner as it was to make the machine. Maybe more. Every time new ones hit the market, he had to verify the formula, and occasionally refine it
Rod
ragtoplvr is offline   Reply With Quote
Times are GMT -7.   It's 03:04 AM.
