Old 10-07-2012, 03:56 AM   #1
R100LT OP
Chasing 11
R100LT's Avatar
Oddometer: 631
Look what I found
Whilst dropping the oil and checking the sump a found a small pile of chewed up rubber ... Apart from that the oil was clean and not a hint of any metal.
Any ideas of where I should be looking for the culprit ???
BMW R100LT 93 BMW R100RS 91 BMW K1100LT SE 94 76 R90S
R100LT is offline   Reply With Quote
Old 10-07-2012, 04:00 AM   #2
Uncle Pollo
happy cachiporra
Uncle Pollo's Avatar
Oddometer: 48,393
Pushrod seal or old sealant.
Uncle Pollo is offline   Reply With Quote
Old 10-07-2012, 06:04 AM   #3
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 8,248
If it's hard rubber, it may be from the timing chain tensioner rail.
'73 R60/5 Toaster
Old 10-07-2012, 06:06 AM   #4
R100LT OP
Chasing 11
R100LT's Avatar
Oddometer: 631
Thanks Bill ... Yep its pretty hard rubber ... but I haven't noticed any noise from the timing chain
Old 10-07-2012, 07:36 AM   #5
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 10,012
Most likely timing chain tensioner.
---Albert Einstein
disston is online now   Reply With Quote
Old 10-07-2012, 07:46 AM   #6
R100LT OP
Chasing 11
R100LT's Avatar
Oddometer: 631
so you are thinking thats its just a bit off the end of the timing chain tensioner ??? You thinking its worth digging and replacing it if I am not getting any undue noise from the timing chain ???
Old 10-07-2012, 07:59 AM   #7
Wolfgang55
Wolfgang55's Avatar
Oddometer: 3,521
It just maybe......German chewing gum.
TASTE IT
Wolfgang55 is online now   Reply With Quote
Old 10-07-2012, 08:47 AM   #8
DoktorT
BigBrowedNeandereer
DoktorT's Avatar
Oddometer: 1,144
Just way too big a chunk to ignore. More chunks will follow. Other chunks could be floating around in the chain case. Plan to pull the timing cover this winter, inspect the chain and gears, replace the tensioner rail/s and perhaps the spring.
Don't wait for nasty noises. That would likely mean much more cost than fixing this obvious flaw BEFORE any nasty noises get started.
DoktorT is offline   Reply With Quote
Old 10-07-2012, 11:39 AM   #9
Beater
The Bavarian Butcher
Beater's Avatar
Oddometer: 3,540
PS - He's in Western Australia ... It's getting to be spring for him ;-)
Take the timing chain cover off NOW.
Fred <|> Need an Airhead Part? .... I May Have It!
'85 BMW R80RT G/Sified <|> '73 BMW R75/5 LWB <|> '94 MZ Silver Star Hack
Beater is offline   Reply With Quote
Old 10-07-2012, 09:35 AM   #10
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 10,012
How many miles on this engine?
---Albert Einstein
Old 10-07-2012, 11:14 AM   #11
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,727
I found similar chunks in the GS. Was the guide rail for the camchain, the one opposite the tensioner.
In itself not all that critical, that is if the pieces had stayed in the sump. Because it is a GS, looks like the PO dropped it on the left hand side. Some of the little pieces got in between the piston/cylinder. Wanna see the damages?
Have tools, will travel!
Old 10-07-2012, 11:36 AM   #12
Bill Harris
Oddometer: 8,248
It's probably either the tensioner or the guide rail, and suggests some mileage. The guide rail keep the chain quiet once it wears-- on the earlier duplex chain engines, the worn chain would announce itself by rattling against the timing chain cover and create noise and aluminium shavings. It isn't going to get better.
No big hurry, but don't forget about it...
'73 R60/5 Toaster
Old 10-07-2012, 02:02 PM   #13
R100LT OP
Chasing 11
R100LT's Avatar
Oddometer: 631
The bike has done 65 000 km's ... so I guess its getting about time for a new timing chain .
I just didn't want to " upset " my good work of the Enduralast system that I put in last year .
Oh well ... Timing Chain Kit is the shopping cart as we speak.
Old 10-07-2012, 02:11 PM   #14
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 10,012
I have always thought that the duplex chain is inherently better than the single row chain. After all it's twice as much chain. But the single row chains seem to be an improvement. I don't know why. Could be the tensioner system is better?
I would still do yours because of this symptom you have developed. But 65,000 KM seems an early failure.
---Albert Einstein
Old 10-07-2012, 02:23 PM   #15
100RT
100RT's Avatar
Oddometer: 779
I hope the pick up screen wasnt laying there also.
100RT is offline   Reply With Quote
Times are GMT -7.   It's 10:51 PM.
