10-17-2012, 01:32 AM
#1 |
b00b
Oddometer: 172
Grip heaters failing
My grip heaters have been acting up over the last few months.
At first, I thought it was all in my head. After today's encounter with some snow however, I know they're not right, and I have had enough. I would say they never stop working completely, just not as hot. It's intermittent, and so is the severity. Both grips are always the same. I think it has something to do with the throttle side. When the bike warms up with the heaters on, they're effin' hot when I get on. Is it a loop of wire or a slider that allows the throttle movement? I'm thinking there is a bad connection there. Does anyone know if they are wired in series or parallel? What should the current and voltages be? On my snowmobile, the ecu controls the heater output. Is that true on the F8? |
10-17-2012, 08:39 AM
#2 | |
Oddometer: 324
10-17-2012, 09:11 AM
#3 |
b00b
Oddometer: 172
10-17-2012, 09:29 AM
#4 | |
Oddometer: 3,479
It's probably an intermittent short, that will probably eventually become a permanent short. If the short is in the grip itself, though, you won't feel it the same in both grips. They're wired separately, so a short in the left grip means cold left hand, and warm right hand. So, if they're both crapping out to the same degree at the same time, the short is further up stream. With mine, I tracked it down to the grip itself, and found a break in the heater wire. I soldered it together, and dabbed a bunch of nail polish on it, velcroed it shut and that's how it's been for the past 2 years. |
10-17-2012, 05:09 PM
#5 |
Amusing Myself Again
Oddometer: 553
Alright Greenthumb, don't let them go black!
Can't answer all your questions, just a few. On the throttle end, there's just a slack wire that goes along for the ride when you twist it. No slider or slip ring thing. The switch just tells the ZFE (ECU) whether it's off/lo/hi then the grips are supplied voltage accordingly. They're wired parallel, often one fails while the other carries on. The right side will be hotter because it's somewhat insulated by being mounted on plastic with an air gap between it and the bars. The left side is solid to the a handle bar and tends to heat up that end of the bar too so it feels cooler. Not like your sled where they're both the same. Never heard of both acting up together. If that's true then there should be a code thrown. You on warranty? GS911?
Life is a rollercoaster........and I'm not strapped in!
10-17-2012, 09:13 PM
#6 | |||
b00b
Oddometer: 172
Thanks for the responses.
I did learn the the low setting is not a reduced voltage, but a pulsing of full voltage at about 1 second intervals. After everything was put back together, it worked normally, as usual. I ran the bike for about 5 minutes at about 3500 rpm, got plenty of heat from both grips. I ran out of time before I could dig deeper into the wiring. Quote:
On a good note, I installed some 55watt HID's. Why the hell didn't I do this earlier.
greenthumb screwed with this post 10-17-2012 at 09:42 PM |
10-17-2012, 10:15 PM
#7 |
Oddometer: 1,237
You can borrow my GS911 if you're in the south end here... it'll store a code when the grips shut down but doesn't trip the warning light. It will try to reactivate them when you cycle the key, if that helps. They are capable of working individually. Both sides are thermally insulated from the bars (as you likely saw already).
10-18-2012, 01:00 AM
#8 |
b00b
Oddometer: 172
Thanks. I may just take you up on that. I will try cycling the key next time they act up.
I rode through snow on the coquihalla yesterday, so at this rate my time may be better spent prepping the sled
10-18-2012, 01:03 AM
#9 |
ADV Monkey
Oddometer: 53
I'd also suspect something in the line before the grips themselves. I had one fail and it was very clearly dead on the left while the right still glowed IR nicely. That was at about 15 months and 15k miles so BMW happily swapped me out a replacement. 2 years and 25k later I haven't had any problems with either since then.
ad·ven·ture 1.an exciting or very unusual experience. What a great 40,000 mile adventure on the trusty F800GS. Looking forward to the next 40k. Minnesota Parallel "Twin" Cities GS Riders Daniel Betlock Adventure Rider
