Old 10-26-2012, 09:56 AM   #1
5 speed OP
Oddometer: 949
Off throttle backfire
Hi there. So It took my bike in for a valve adjustment. Generally do everything myself but havent adjusted the valves and figured I would have it done professionally. The bike was at the shop for 4 weeks as I had springs ordered for the front end and also sent my seat out to be redone. I figured the gas may have gone bad but I did have the Marine Stabilizer in it. I sprayed seafoam in the carbs and also ran some through the gas and then rode it about 500 miles. My conclusion because, it idles fine and performs well is that there is an airleak. It backfiring and spitting when the throttle is chopped. I remember putting the carbs in myself once and thought they seated but then took the tanks off and could see through the access panels that they weren't quite right.
So, before I pull the tanks, any ideas of how I might tell where the airleak is coming from (with suspect that it may have to do with the dis/reassembly from the valve job). your thoughts would be appreciated.
5 speed is offline   Reply With Quote
Old 10-26-2012, 11:01 AM   #2
snowhawk jockey
Slack Jaw Gaper
snowhawk jockey's Avatar
Location: The other Center of the Universe: Bend, Oregon
Oddometer: 1,124
Did the shop fiddle with your exhaust at all? Air leak there is a sure backfire.
snowhawk jockey is offline   Reply With Quote
Old 10-26-2012, 12:30 PM   #3
TheMuffinMan
Forest Ranger Magnet
TheMuffinMan's Avatar
Oddometer: 6,233
I'd make sure the carbs are seated in the boots, and then I'd be going over the exhausts for cracks/leaks.
"To strive, to seek, to find, and not to yield."
"You don't cross the mountains, they let you through."
KTM 525 XC-W // KTM 950 Adventure
TheMuffinMan is offline   Reply With Quote
Old 10-26-2012, 01:08 PM   #4
Spiritwalker2222
Oddometer: 112
Check you exhaust header. If the bolt and nut are loose it can cause your bike to bikefire whenever you let off the throttle.
Spiritwalker2222 is offline   Reply With Quote
Old 10-26-2012, 02:45 PM   #5
5 speed OP
Oddometer: 949
Cool I will try those suggestions before I jump on the carbs and report back. Thanks much
Old 10-27-2012, 04:38 AM   #6
DirtyADV
DirtyADV's Avatar
Oddometer: 2,360
Had bad backfiring when engine braking from like 4500 rpm and below.
Carbs were not touched when the bike developed this, found it to be an air leak on one of the hoses on the intake below the carbs that are used when syncing the carbs (smog stuff removed).
Poorly seated or torn intake rubber could probably cause it also.
/Johan
Have changed name, was previously Dirty950
www.dirtyadv.com (under construction)
DirtyADV is online now   Reply With Quote
Old 10-27-2012, 08:05 PM   #7
5 speed OP
Oddometer: 949
I guess I got ahead of myself. I fired it up in the driveway and it ran and idled fine, no backfiring. So I put it together last night (had not gone so far as pulling the tanks) and today it ran terrific, idled perfect, but still backfires when winding down from about 4,000 RPM. It seems to be the right pipe which is the front cylinder. I checked around the head and the pipe joint and did not find a leak. as far as the carbs i did as much inspection from topside I could and the carbs seem seated (although I have been fooled before on that one). I would say its definitely an airleak.
Old 10-28-2012, 08:45 PM   #8
K2m
....58....
K2m's Avatar
Oddometer: 2,238
Originally Posted by 5 speed View Post
I guess I got ahead of myself. I fired it up in the driveway and it ran and idled fine, no backfiring. So I put it together last night (had not gone so far as pulling the tanks) and today it ran terrific, idled perfect, but still backfires when winding down from about 4,000 RPM. .
When a LC8 is perfectly tuned they do this.
It may be possible to tune it out by changing the Air Leak jet on the ACV (air cut valve) it's on the pilot circuit.
If you wish to explore this option I can help further.
If I understand correctly :-
It came back from the shop popping on decel. ..... Spot on.
The News, those who are trying to control what we think, do not want us to see.
http://www.presstv.ir/live.html So good the British Gov. Banned it !!!
http://rt.com/on-air/rt-america-air/
K2m is offline   Reply With Quote
Old 10-28-2012, 09:25 PM   #9
crofrog
Oddometer: 1,455
+1 every well jetted lc8 I've been on does it, _and_ it's fun.
crofrog is offline   Reply With Quote
Old 10-29-2012, 02:46 PM   #10
kulvershtukas
Oddometer: 42
Have the same issue. Seems like the right pipe is backfiring. Also seems like it is going hot a little bit faster than the left one. As soon as I am not a real technician, have asked the guy from the service to do 15kt service and check the issues. So far:
- no leaks or cracks in pipes
- no vacuum leaks
- air filter is clean
- carbs are synced
- valves are cleaned, regulated
- Leo Vince cans are checked from the inside
All is in order, nothing wrong with the bike, but it still backfires... I guess it just has to do that
kulvershtukas is offline   Reply With Quote
Old 10-29-2012, 02:49 PM   #11
kulvershtukas
Oddometer: 42
Also spark plugs are replaced, but have not seen the bike yet
Old 10-29-2012, 03:52 PM   #12
Sumi
Sumi's Avatar
Oddometer: 1,813
If it pulls as it should and idle is fine, I'd say it's normal. They really all do that!
If your slides are not in sync (if they are way out of sync I mean), it might be a carb sync issue (way out of sync carbs will also cause backfiring - but probably not just off throttle).
But IMO if it has the power it should have, and the idle isn't hunting too badly neither hanging, then it's normal - the off throttle backfiring. Also it's a better practice to ride these bikes instead of worrying about every hickup it throws at us / repairing (what isn't really broken) it constantly:)
Old 10-30-2012, 12:01 PM   #13
fastdirt505
Oddometer: 70
Mine definitely backfires under 5k rpm with the throttle closed. I have my spark arrestors out of the FMF pipes which makes it worse. I have to decide if I want heads to turn when downshifting to a stop or not. If I don't want the attention I just pull in the clutch or you can give the throttle just a slight turn to silence the pops. The bike runs great but backfires.
Brian
Erzberg SE 950R and a KTM 250SX
http://www.youtube.com/fastdirt505
fastdirt505 is offline   Reply With Quote
Old 10-30-2012, 07:56 PM   #14
Groundhog
Groundhog's Avatar
Oddometer: 188
Just an idea. I had a lot of popping and backfiring on deceleration on my '07.
Then I (just) repacked my FMFs and almost all of it went away! Imagine that! I had about 12,000 miles on the original packing.
Groundhog
Horsepower determines how fast you hit the wall. Torque determines the size of the hole you make.
Groundhog is offline   Reply With Quote
Old 10-31-2012, 02:04 AM   #15
K2m
....58....
K2m's Avatar
Oddometer: 2,238
Exactly what I do at 2 in the morning.
I luv it as it swears at the world. Reminds me of racing car cams, feels like them to as you open it up and it springs into life......... Best part of riding this bike in traffic........ Why would you want it to feel/sound like a 1975 Honda CB250.....
Times are GMT -7.   It's 07:23 AM.
