Old 11-02-2012, 08:35 PM   #1
devilfishlane OP
Oddometer: 55
45t sprocket
Where could I buy a 45 T sprocket for a 2009 KTM 990 SMT ? Thank you
devilfishlane is offline   Reply With Quote
Old 11-03-2012, 03:08 PM   #2
cjracer
AWD please!!
cjracer's Avatar
Oddometer: 3,964
Email or Call for details.
We can get you Custom ones made.
My 2006 950S thread. 2006 950s update
New product updates here! Wordpress BLOG
click www.cjdesignsllc.com for the full line of products. FREE STUFF!!
cjracer is offline   Reply With Quote
Old 11-03-2012, 03:49 PM   #3
Lc8grrr
Vtwin madness
Lc8grrr's Avatar
Oddometer: 442
KTM for SE.
Lc8grrr is offline   Reply With Quote
Old 11-03-2012, 10:58 PM   #4
cjracer
AWD please!!
cjracer's Avatar
Oddometer: 3,964
Doesn't the "SMT" have 17" Rims?
The largest sprocket KTM offer is 42.
The 17" rims do NOT use the same sprockets as the 18" ADV or SE rims.
Old 11-06-2012, 03:42 AM   #5
Lc8grrr
Vtwin madness
Lc8grrr's Avatar
Oddometer: 442
yeh ok the SMT are different but below is the part number for the 45T that KTM make for the SE. Price is from Boltons in Australia.
Reference:20
Part number:600 10 051 045
Description:B2 REAR SPROCKET 45-T 03
Retail Price:112.20
Qty On Fiche Diagram:1
Qty In Stock:1 [?]
Qty In Shopping Basket
Want to do a 520 conversion (not recommended due to much lower life as I have experienced) use the front 520 conversion sprocket for an RC8 from the KTM Hardparts.
Old 11-04-2012, 11:55 AM   #6
cjracer
AWD please!!
cjracer's Avatar
Oddometer: 3,964
Old 11-04-2012, 04:07 PM   #7
snowhawk jockey
Slack Jaw Gaper
snowhawk jockey's Avatar
Location: The other Center of the Universe: Bend, Oregon
Oddometer: 1,115
Originally Posted by BuckMoto View Post
If you are thinking of jumping 3 teeth in the rear from a stock 42 tooth to a 45, you might consider simply dropping a tooth in front instead. The gearing would end up nearly identical plus you can alternate between 1-tooth different countershaft sprockets to suit your ride and only need a chain adjustment. Adding 3 teeth on the rear would probably require more chain links.
17/45 = 2.647:1
16/42 = 2.625:1
16/45 = 2.8125:1
15/42 = 2.8:1 (my current gearing)
>edit<
I have had no issues with the 15 tooth countershaft (especially now that I have a straight swingarm!).
That 16/42 and 17/45 are super close on the ratios. I can tell as much difference between a new tire and a worn tire in RPM/MPH/traction, as 16/42 vs 17/45. 17/45 had a tiny bit more grunt/bite than the 16/42 does. I am presently 16/42 with a 17 on the shelf for slab trips, after running the 17/45 for the last set of gears.
snowhawk jockey is offline   Reply With Quote
Old 11-04-2012, 12:01 AM   #8
snowhawk jockey
Slack Jaw Gaper
Oddometer: 1,115
17/45 gearing on a 17" rear has a nice balance.
I wish I had run into you at the KTM Rally, CJ, I really wanted to check out your 2wd!
Old 11-04-2012, 01:59 AM   #9
Peanuts
Peanuts's Avatar
Oddometer: 1,565
17/45 is pretty much same as 16/42 and both 16 and 42 sprockets are avaliable from a KTM dealer :)
Peanuts is offline   Reply With Quote
Old 11-04-2012, 08:40 AM   #10
cjracer
AWD please!!
cjracer's Avatar
Oddometer: 3,964
I prefer 17/45 combo on any setup over the 16/42, b/c there are more teeth in the system - Longer life- and you don't get the unusual Sprocket wear with an Odd set of teeth count that you do with an Even.
Old 11-04-2012, 08:58 AM   #11
Slvrtundevl
Slvrtundevl's Avatar
Oddometer: 500
Ditto.... I am running the 17/45 right now and have the 16/42 as a spare.
Come to the darkside....We have Cookies!!!
2010 KTM 990
Slvrtundevl is offline   Reply With Quote
Old 11-04-2012, 11:44 AM   #12
devilfishlane OP
Oddometer: 55
I actually have a 16T on the front.. By the way its a 990 SMT.. But I want more low end torque. Stock sprocket on the rear is 41. What are my options,,I've only found a 42T ..Will that make much difference? Thank you
Old 11-07-2012, 11:03 PM   #13
David37
David37's Avatar
Oddometer: 402
Dirt Tricks carries 45t Ironman sprockets for the KTM 950/990. Haven't used them on my KTM 950SE but they lasted a long time on my KTM 450 XCF and come with a 1 year warranty.
http://www.dirttricks.com/ordering_sprockets.htm
David37 is offline   Reply With Quote
Old 11-08-2012, 08:08 AM   #14
cjracer
AWD please!!
cjracer's Avatar
Oddometer: 3,964
This thread is going to cause much confusion for future searchers.
Reason:
-The 990 SMT has cast 17" rims from the factory.
http://www.motorcycle.com/manufactur...iew-91341.html
-The 950/990 ADV, and 950 SE sprockets many have stated and listed Above WILL NOT WORK on the 17" rims.
-The 17" OEM rims have a different Sprocket setup as well as a different Brake Rotor setup.
-Custom Sprockets can be MADE for the 17" Marchesini Rims, but KTM does NOT offer them.
Old 11-08-2012, 08:15 PM   #15
devilfishlane OP
Oddometer: 55
45T sprocket
Well.. I went ahead and bought a 15 T for the front. Not looking for top speed. Most of my riding is in the mountains in South America. Any experiences with it on a 990 SMT ? Thanks
Times are GMT -7.   It's 11:17 PM.
