Old 11-22-2012, 09:37 AM   #1
sama3033 OP
sama3033's Avatar
Oddometer: 111
990 Shock Stretch
I know, I know! there are a million threads on this topic but I've just finished stretching and revalving my forks so now it's back to the man-cave and on to the shock and there doesn't seem to be as much discussion about that and a I wondered why. If anyone knows of a shock specific thread I'd be grateful if you could point me at it. I have the necessary parts - I just want to be sure there are no pitfalls or surprises in disassembly and rebuild.
Happy Thanksgiving All
SM
sama3033 is offline   Reply With Quote
Old 11-22-2012, 04:22 PM   #2
knobbyjoe
knobbyjoe
knobbyjoe's Avatar
Oddometer: 523
http://www.superplushsuspension.com/adventure.htm
Hey Sama3033,
These guys are very good. I bet a phone call to them will help out.
KJ
KTM 400 XCRW with Thumper Racing 450 kit and 450 cam 2007
KTM 450 XCRW with Christini AWD and Plated 2008 now has 520 Thumper Racing kit
KTM 990 Adventure 2008
knobbyjoe is offline   Reply With Quote
Old 11-23-2012, 07:21 AM   #3
Bronco3738
Mike
Bronco3738's Avatar
Oddometer: 498
In case you don't realize it the shock is under high pressure nitrogen. Most people don't do their own shocks because they don't have the equipment to refill the nitrogen charge.
Good luck I'd like to see a write up of the shock rebuild.
2009 KTM 990
Honeymoon Ride Report
Crazy Europeans Tour Utah
Bronco3738 is offline   Reply With Quote
Old 11-23-2012, 08:33 AM   #4
sama3033 OP
sama3033's Avatar
Oddometer: 111
Nitrogen
Bronco
Yeah, I'm aware of that little detail but Racetech has a work-around that I'm eager to try. I'm one of those experiential learners - learn by doing and if I fuck it up I keep trying until I get it right. The forks were interesting and I learned a lot about fluid dynamics in the process - this is cool stuff in my mind. I'm taking my time and enjoying myself. I'm thinking of building CF safari tanks next. Wish me luck.
Old 11-23-2012, 11:05 AM   #5
Konflict Motorsports
KM TUNER
Konflict Motorsports's Avatar
Oddometer: 855
Sama
What is your weight, and how much do you carry and riding style? Aggressive, mild? Where are you riding the bike, and how much on road to off road?
Id be happy to give you a few tips and stacks.
Konflict Motorsports & Suspension www.KonflictMotorsports.com
Konflict Motorsports is offline   Reply With Quote
Old 11-23-2012, 11:20 AM   #6
sama3033 OP
sama3033's Avatar
Oddometer: 111
Konflict
Konflict my friend - I bought the spring for the stretch from you and have the rebound shim provided by Superplush (not sure how it differs from stock but we'll find out soon). Racetech valve and shims should be here any minute.
I'm right around 200lbs. Riding style is varied, 70% on-road, but I do ride fairly aggressive off road when I can (NJ Pine Barrens which vary between hard-packed gravel and foot deep sand) Sandblast a while back (DEEP ruts, more sand, a lot of lying on my back, insane fun!)
Grateful for any input
SM
Old 11-23-2012, 03:48 PM   #7
Bronco3738
Mike
Bronco3738's Avatar
Oddometer: 498
Glad to hear you are going forward on the shock.
I can't wait to see the thread on the tanks. Do you know what resin you are going to use that is fuel proof, and how do you plan on making the fuel cap? I've worked with carbon before but never on tanks. There is a thread on here from Pete640 who made some very nice side tanks, maybe give you some ideas.
And again Good Luck.
2009 KTM 990
Old 11-25-2012, 08:43 AM   #8
sama3033 OP
sama3033's Avatar
Oddometer: 111
Carbon
Bronco
I found this thread here too. It's a really nice primer on how to lay up not-so-easy shapes in carbon; a CF/kevlar Suzuki SV tank. Really nicely done by Tygaboy - I'm going to follow his lead.
Old 11-25-2012, 08:43 AM   #9
sama3033 OP
sama3033's Avatar
Oddometer: 111
Ha, the link might help!
http://bayarearidersforum.com/forums...d.php?t=145975
Old 11-24-2012, 07:49 PM   #10
Capt.saveaho
Capt.saveaho's Avatar
Oddometer: 302
SM
I don't know about the 990 rear shock but I know on mx bikes there is a peening on the shaft for the valve stack to prevent the nut from coming off, that would require grinding. Good for you taking on this task, once I figure out what needs changing on my forks I am going to do it myself as we'll.
Also when you mean stretch, you mean increasing the travel?
+1 talk to James at superplush, 9X0's are his specialty. He won't hesitate to tell you what you will need, and honestly you may only need a spring or a preload spacer the rear is way better setup then the front.
2007 525exc
2011 990 Adventure with 08 S suspension!!!
13hp road race 50
Capt.saveaho is offline   Reply With Quote
Old 11-25-2012, 11:27 AM   #11
sama3033 OP
sama3033's Avatar
Oddometer: 111
Capt.saveaho
I've already completed the forks and there's a tiny bit of grinding to do there before you can get to the compression shim stack but it's nothing and only requires some Locktite on the threads when rebuilding. I had a lot of fun with this by the way and learned a lot in the process. The biggest problem I had was reseating the compression valve assembly and getting it torqued to the right specs because it will just spin if you cannot get a proper grip on the rebound shaft.
The only problem I foresee with the shock is the nitrogen but it may just be a matter of getting my local shop to recharge it afterward. Live and learn.
SM
Old 11-26-2012, 12:11 AM   #12
KM TUNER
Oddometer: 855
SM
Sama,
When reinstalling the base valve into the cartiridge the stand process is to extend the cartridge rod and pull it to one side of the upper fork tube. This well eliminate the lower cartridge spinning while reinstalling the base valve.
As for the WP Adventure unit, it does not have any peening on the nut. It will make it very easy for you to swap out the pistons and valving.
Times are GMT -7.   It's 04:30 AM.
