Old 11-22-2012, 06:12 PM   #1
speedracer3232 OP
Oddometer: 6
Do the KLX250SF wheels fit on the KLX 250s
all i want to know is if the stock OEM wheels on the KLX250SF http://www.bikebandit.com/houseofmot...8761#sch638520 Will fit directly on my 2009 klx250s i know theres other modifications i will have to do like kickstand will be longer etc but i strictly want to know if the wheels will fit.
speedracer3232 is offline   Reply With Quote
Old 11-22-2012, 06:25 PM   #2
cjbiker
Nobody's Robot
cjbiker's Avatar
Oddometer: 2,636
Yes, the wheels fit perfectly.
If you're using the front brake rotor from the SF wheels, you'll need the caliper bracket too.
cjbiker is online now   Reply With Quote
Old 11-22-2012, 07:14 PM   #3
speedracer3232 OP
Oddometer: 6
can i just use my S brake pads and S disc on the SF wheels or do i need to also buy the SF brakes/Disc .. i just wanted the wheels that was it.
Old 11-22-2012, 07:26 PM   #4
cjbiker
Nobody's Robot
cjbiker's Avatar
Oddometer: 2,636
I think so, but I'm not 100% sure if the S disc will fit the SF hub. The part numbers for the hubs are not exactly the same, but I think that's because the S is silver and the SF is black. Worst case, you get the SF wheels, your disc doesn't fit, so you need to get the SF disc and caliper bracket. The caliper and brake pads will work, no need to worry about that.
I will add that the SF disc is really nice on the street. Gives the bike really powerful front brakes.
Old 11-22-2012, 07:41 PM   #5
speedracer3232 OP
Oddometer: 6
Alright Thanks alot so your 100% sure that those OEM SF wheels will fit my S correct? and do you have an SF?
Old 11-22-2012, 07:51 PM   #6
cjbiker
Nobody's Robot
cjbiker's Avatar
Oddometer: 2,636
Yes, I have an SF that I changed the forks and shock to the S model parts. I have both the S and SF wheels and I swap the wheels back and forth. The bike will be a little more squirrelly with the SF wheels. Make sure your rear shock sag is set properly, as too little sag makes it worse.
Old 11-23-2012, 05:53 AM   #7
cjbiker
Nobody's Robot
cjbiker's Avatar
Oddometer: 2,636
If there isn't enough sag in the rear suspension, the back of the bike sits up too high and makes the head tube angle too steep. That quickens the steering, couple that with the smaller front wheel, it can get unstable. Just set your sag correctly, and it's no big deal. Search the web for how to set the sag, it's easy. You want to set it at about 1/3 of the total rear wheel travel, pretty much the standard setting for dirt bikes. I only mentioned it because these bikes seem to come set up with too little sag for most riders.
The SF forks and shock have less travel. I wanted to use my bike off road with the S wheels, so I swapped the forks, shock, handlebars, cables, front fender, kickstand, etc.
Times are GMT -7.   It's 05:57 PM.
