Old 11-23-2012, 08:22 AM   #1
blanc OP
blanc's Avatar
Oddometer: 73
Yamaha it175 1980 Susoension Upgrade
Hi All,
I am building up a 1980 it175G model to race classic HH's, The stock suspension is rubbish. Can you swap the front and rear suspension from a similar era yz without too much trouble?
Lol please excuse the spelling in the title.
blanc is offline   Reply With Quote
Old 11-23-2012, 04:29 PM   #2
wfopete
Suffer Fools; Gladly!
wfopete's Avatar
Oddometer: 497
Or buy a YZ and slip that motor in it.
Suffer Fools; Gladly!....
RIDING the TAT? CHECK IT OUT: TAT SHAK
ARA - Adventure Riders of Arkansas
wfopete is offline   Reply With Quote
Old 11-23-2012, 11:15 PM   #3
theMISSIONARY
hunting and riding!!
theMISSIONARY's Avatar
Oddometer: 2,254
Originally Posted by blanc View Post
Hi All,
yes and no as some of the YZ rear shocks are fatter and wont fit without modding the mount but if you find one just messure it up
i was looking at(years ago) any of the IT/YZ/DT's with the triangle swing arm models to see what will or wont fit and as there are a number of models there will be some differences
the front end will fit but it wont have a speedo drive
Happiness is a warm barrel....i don't care if its the bikes barrel or the rifles barrel!
WR250r of Awesomeness.......now with extra added Awesomeness!
theMISSIONARY is offline   Reply With Quote
Old 11-24-2012, 03:20 PM   #4
Sic Semper Tyrannis
Oddometer: 640
Grimmboy on the board swapped yz front forks on my (then his) XT500.
SO maybe ask him for advice.
Sic Semper Tyrannis is offline   Reply With Quote
Old 12-19-2012, 07:38 AM   #5
blanc OP
blanc's Avatar
Oddometer: 73
Thanks a mill. Do you remember which yz parts fit?
Old 12-19-2012, 11:10 AM   #6
theMISSIONARY
Oddometer: 2,254
no sorry just measure the swingarm bolt(as that goes through the frame) and you "should" be able to make it fit
Old 12-22-2012, 10:38 AM   #7
Navin
Navin's Avatar
Oddometer: 8,480
I'd venture a set of Race Tech Emulators or Ricor Intiminator valves, fresh, correct rate springs and a rebuild would upgrade the stock stuff above the same era YZ parts anyway. Is the rear shock rebuildable? Race Teck Gold Valve and revalve it for your needs.
Navin is offline   Reply With Quote
Old 12-22-2012, 02:46 PM   #8
anotherguy
anotherguy's Avatar
Oddometer: 6,631
I have 43MM forks from an '82 490 on my YZ465 fitted with Race Tech Emulators/springs and bushings. Huge improvement over the stock stuff. They (R-T) make a shock for the YZ line so I imagine if that kinda $$$ is in the budget they'll fix up yer IT too.
you don't see luggage racks on a hearse..........act accordingly
Times are GMT -7.   It's 06:19 AM.
