Old 11-24-2012, 10:31 PM   #1
duckboy OP
Oddometer: 290
TPMS accuracy??
I thought my air gauge were accurate all this time until I got my '12 gs triple blk with TPMS. Now it looks like my air pressure gauges have been short (gives a value greater than the TPMS) by 2-3 psi. anyone known how accurate the TPMS is to begin with?
hp totin' geek (41cx w/ math card)
kenmore front loader w/ pedestal
zephyr typhoon 850 cfm
homedepot platinum card
duckboy is offline   Reply With Quote
Old 11-25-2012, 01:49 AM   #2
daesimps
Oddometer: 10
Remember that the TPMS gives a temperature calibrated reading. It compensates for the temperature of the air and gives you the what the pressure would be at 20 Degrees C (since these are the reference pressures/temperatures in the manual).
Your normal gauge will not do this and gives you the pressure of the tyres at the current temperature.
daesimps is offline   Reply With Quote
Old 11-25-2012, 08:49 PM   #3
duckboy OP
Oddometer: 290
twempie,
didn't know the stk tpms system was so sophisticated. i thought i just an absolute pressure. again, thanks for the helpful and relavent info.
duckboy
Old 11-25-2012, 10:05 PM   #4
Twempie
Oddometer: 203
Mine's a large skinny, no foam
Originally Posted by duckboy View Post
twempie,
duckboy
Twempie is offline   Reply With Quote
Old 11-25-2012, 04:24 AM   #5
rmarmbruster
Roba
rmarmbruster's Avatar
Oddometer: 160
Not trying to be a clever but you can check your tyre pressure gauge against the TPMS: (P1*V1/T1)=(P2*V2/T2). Obtaining the tyre temp may be the challenge but I can think of a couple of ways, loose some air onto a mercury bulb thermometer and calculate using both pressures to see if it is the same region.
I could be fun figuring this one out.
Cheers
Rob A
Roba
rmarmbruster is offline   Reply With Quote
Old 11-25-2012, 07:13 AM   #6
Ridestrong
Oddometer: 157
Ok, without going into all the scientific calculations, what is the best approach to reading your pressure, assuming you have both? I'm thinking just go with whatever the air gauge says and realize the TPMS will show temp. related calculations. My purpose would be to make sure I'm not losing air while traveling. This can be done with the TPMS, just by being able to monitor constantly, along with the alarm light, even if it doesn't agree with the standard air gauge because of temperature.
I've been strongly considering adding a TPMS to my bike. My BMW dealer caries the Orange brand. Is there any consensus which one is best or most preferred? I know there have been other threads about this but it's been awhile and some brands have discontinued motorcycle applications and/or gone out of business. Are there any that will actually show that your pressure is low before you get rolling?
Ridestrong is offline   Reply With Quote
Old 11-25-2012, 07:23 AM   #7
jzeiler
ADWrencher
jzeiler's Avatar
Oddometer: 109
Usually NO. It is the centripital force of rotation that turns on the sending units. Other wise they would be transmitting data (and consuming battery power) when parked.
I have heard good things about the Orange TPMS but thought they too had gone under, maybe just some bad info (yup bad info they are still out there). I run the older SmarTire system on both bikes but it is getting harder to find transmitters.
John
2009 R1200GS (Gone)
2005 K1200LT
2009 K300GT
K4AN
jzeiler is offline   Reply With Quote
Old 11-25-2012, 07:36 AM   #8
sbk12rs
sbk12rs's Avatar
Oddometer: 79
I think these tpm's are a silly " GADGET " for the yuppie rider that just needs gadgets .
AND to make these silly posts .
just sayin .........
Flame away yuppie riders
sbk12rs is offline   Reply With Quote
Old 11-25-2012, 08:47 AM   #9
CrustyAPO
CrustyAPO's Avatar
Oddometer: 439
I would have to disagree. Yes, they are another "gadget", but a useful one. After a 5500 mile trip out west using Orange Electronic tpms system, it was nice being able to see tire pressures at a glance. I carried my manual guage with me as well and found after a few times of double-checking the tpms that it was redundant. The Orange Electronic system display changes from blue to red when either the tire pressure or temp go outside the limits you set. Kind of like the big red "OIL" light the stock and drag car drivers use on their steering columns to warn them of low oil pressure. So I didn't have to actually have to see the numerical readout, just the color change to get my attention. I didn't have any tire troubles while on my trip but if I had a puncture or a slow leak I would have been made aware of it long before it could cause trouble (catastrophic failures tend to make themselves know immediately). So while it might seem like one of those frivilous gadgets people add onto their motorcycles, I feel it is as useful as extra driving lights, a voltmeter, or a side stand foot enlarger.
Yeah, and maybe I'm a Chinese jet pilot.
CrustyAPO is offline   Reply With Quote
Old 11-25-2012, 05:19 PM   #10
erkmania
Still Adventuring
erkmania's Avatar
Oddometer: 983
Saved my ass, once! Perhaps your ass doesn't need saving...
-Sticks and stones, love.
-Insurmountable problems exist in the imaginations of the less traveled.
2011 BMW R1200GS, 2004 KTM 950, 1996 ATK 605 ESDS
erkmania is offline   Reply With Quote
Old 11-25-2012, 08:22 PM   #11
lkchris
Albuquerque
lkchris's Avatar
Oddometer: 1,022
TPMS exists because a few years ago Ford Explorers with Firestone tires experienced an inordinate number of rollover accidents.
The response was the Federal requirement that TPMS systems be fitted on all 2007-on production cars sold in the USA.
And you can now optionally have it on some BMW motorcycles.
The purpose of the systems is to warn of dangerously low tire pressures.
Their purpose is not really to provide a readout of your tire pressure, but instead notification that it's significantly lower than desired.
Anything to do with "yuppieness" is inane at best, but then consider the source ... pee pee problems being of no interest here.
Kent Christensen
Albuquerque
'12 R1200RT, '02 R1100S, '84 R80G/S
lkchris is offline   Reply With Quote
Old 11-26-2012, 03:48 AM   #12
TuefelHunden
TuefelHunden's Avatar
Oddometer: 600
I agree and disagree. First, you can play your math games all you want, they usually don't come out right, or at least not good enough. Too many variables that are tough to get a good reading. That's why I don't trust the absolute numbers on the instrument panel. There are some rules of thumb that allow you judge the best traction by the amount of change in tire pressure as they heat up. They are difficult to figure when a compensation algorithm is playing with the numbers. That's the agree part. The disagree part is that they are not a silly gadget. I measure my air pressure and fill the tires "cold" before the bike moves. That way I know what my tire pressure actually is at under known conditions, not what some engineer thinks it should be. Why it is not a gadget is I watch the instrument reading for changes, usually loss of pressure. That is what keeps my ass intact.
Old, but not Dead
TuefelHunden is offline   Reply With Quote
Old 11-26-2012, 07:16 AM   #13
El Gato
El Gato's Avatar
Oddometer: 768
This. ^^ TPMS is not there to tell you if your tires are inflated to the correct pressure to +/- 1 PSI. Use a good tire pressure gauge before you leave the house for that. TPMS is there so save your ass if you get a slow leak while riding. Happened to my buddy a few weeks ago -- he got a warning on the dash with the front down to 25 PSI. He had a slow leak and was able to limp home by topping up the tire a few times during the ride and keeping an eye on it with the TPMS.
El Gato is offline   Reply With Quote
Old 11-27-2012, 10:08 AM   #14
seniorasi
Oddometer: 816
If you firmly believe that why not keep your opinions to yourself and bypass the posts you're not interested in? FYI: I find the TPMS valuable on highway rides for MONITORING tire pressures as a way of accident prevention from a slow leak. Why bother with fuel injection? Get a carburated Airhead, forgo the fairing, ( after all it's merely an annoyance a rider of your caliber doesn't "need" ) and ride like you ought to: In the wind...pun intended.
seniorasi is offline   Reply With Quote
Old 11-27-2012, 11:14 AM   #15
El Gato
El Gato's Avatar
Oddometer: 768
Already been answered here. No need to feed the trolls.
Originally Posted by Twempie View Post
sbk12rs got the reaction he wanted and is probably having a wank about it right now.
Times are GMT -7.   It's 04:25 AM.
