Old 12-01-2012, 05:40 PM   #1
sprouty115 OP
sprouty115's Avatar
Oddometer: 1,490
Advice on an RD 250 build
Hi All,
I need some help - about a two months ago I went looking for a first bike for my son. I found a clean '76 RD 250 with 6K miles. The story sounded good - 100% original with low miles, a clean title, and in running condition for $1,600. So I checked it out, and everything seemed perfect: It was super clean: no rust in the tank, rims were perfect, lights, gauges and signals worked, new fork seals, it even started on the second kick. I drove it around for a bit and it sounded and handled fine. We settled on $1,400 and I figured I had a keeper.
My plan was to go through it over the winter and then give it to him as a present in the spring. So I started poking around and the first thing I did was compression test. Found both cylinders around 120. Based on what I read here that sounded slightly low so I figured I'd let a local shop go over the entire bike and at least than I'd have an idea where to focus my attention.
They confirmed the compression readings, then pulled the exhaust to see if there was any scoring on the pistons (there was a little) so they started looking deeper. Got a call today: broken stator, bent crank, etc. They said they could do the work but it's essentially a full rebuild and probably close to $2K.
So my question to you guys who've been down this road: is it worth it? Does that price seem reasonable? Are there any other options?
A bit more info: I'm pretty set on having an early RD for him (it was my first road bike and I have a real soft spot for them) also I'm pretty mechanically inclined, but I'm just a bit busy, so depending on how difficult this rebuild is maybe I could do it myself? Thoughts and suggestions would be appreciated and don't hold back, I can take it...
Thanks,
Stephen
sprouty115 is online now   Reply With Quote
Old 12-01-2012, 05:42 PM   #2
spo123
Man About Town
spo123's Avatar
Oddometer: 787
Cool2
$2,000 for the motor is VERY HIGH!
spo
1973 /5 LWB Toaster
spo123 is offline   Reply With Quote
Old 12-01-2012, 06:06 PM   #3
sprouty115 OP
sprouty115's Avatar
Oddometer: 1,490
Just to be clear: the $2K is for the entire motor rebuild: new crank, rods, bearings, pistons, seals, re-bore, the stator, etc. Also pulling it from the frame and re-installing it.
So if that is high, any recommendations on where to send it would be welcome as well.
Old 12-01-2012, 07:29 PM   #4
JonnyCash
turd polisher
Oddometer: 1,591
Hello,
2k for a full engine rebuild, including taking it out and reinstalling it in the bike is actually pretty fair, I'd say. It cost me quite a bit less than that on my RD350, but I did everything except the press work on the crank, and the boring myself. While there's nothing very hard about any of it, it is a lot of work. If you want to give the bike to your son, and have it be a learn to ride experience, and not a how to work on bikes experience, it would probably be a good choice.
If it were me, I'd be on the lookout for a ratty RD that runs, and swap that engine into it. They go cheap, but still, you'd have a 40 YO engine in there. I've got a very nice, very modified RD350 that will be up for sale soon. The bottom end, I rebuilt about 2000 miles ago, and the top end had about 500 miles on it. Why am I selling it? I picked up an old Guzzi that has a long list of needs.
Is your bike really a 76? In the states, there was no RD250 in 76, just a 400. There was a 250 from 73-75. 74's were brown, 75's white, I don't remember what the 73's were.
I wouldn't bring her home to Mama, but Mama ain't home tonight.
JonnyCash is offline   Reply With Quote
Old 12-01-2012, 08:21 PM   #5
sprouty115 OP
sprouty115's Avatar
Oddometer: 1,490
Thanks Johnny. First off, yes it is a '75, it's white with red tank stripes. I looked at a
lot
of RD's, must have gotten the year mixed up. Second, I also already have lead on an engine but it sounds trashed and like you say even if it runs it's still 40 years old and a gamble. It seems there are bikes and engines around but nothing in great shape, but I'll definitely keep looking.
And...If it's as much work as you say, I probably don't have time to get it done before spring if I do it myself.
My intention was for this to be a nice stock bike that I went through so he didn't get stranded somewhere and that he could customize himself. I'm still leaning in that direction, but if you want to send me some info on yours once you decide to sell, I'd be happy to consider it.
-stephen
sprouty115 screwed with this post 12-03-2012 at 02:26 PM
Old 12-02-2012, 10:08 AM   #6
LasseNC
XSessive!
LasseNC's Avatar
Oddometer: 1,064
Replace stator, if you think it ran fine, then just keep riding it. When/If it breaks. replace it. You don't know if he will like the bike. If he does, then throw money at it.
Old 12-02-2012, 03:47 PM   #7
sprouty115 OP
sprouty115's Avatar
Oddometer: 1,490
Well it looks like the engine I had a line on turned out to be a dead end. It was originally listed as coming out of a running bike but when I started asking questions it's suddenly seized. So now I have a crank and stator from someone else I'm looking at for $120. Just need to ask some more questions. If it turns out the used crank/stator is decent then I'll see what the new bill would be and make a decision then.
Will need to think hard about this. I would really love to give him this bike but it can't be a time-bomb. Thanks.
Old 12-02-2012, 04:46 PM   #8
pdxjim
Two Stroke Terror
Oddometer: 154
Broken stator? Bent crank? On a running bike?
Sounds fishy to me. Get a second opinon.
pdxjim is offline   Reply With Quote
Old 12-02-2012, 04:52 PM   #9
sprouty115 OP
sprouty115's Avatar
Oddometer: 1,490
I'm pretty sure they're trustworthy but I'll be heading back down to see the bike this week. Just trying to sort out my options and get as educated as possible before I go down.
Old 12-02-2012, 05:26 PM   #10
stainlesscycle
stainlesscycle's Avatar
Oddometer: 2,267
2k is crazy money. typical labor on a 2t 2 cyl is about $400 + parts.
current bikes
stainlesscycle is offline   Reply With Quote
Old 12-02-2012, 06:51 PM   #11
whisperquiet
whisperquiet's Avatar
Location: 62298 in lovely corrupt/bankrupt Southern Illinois
Oddometer: 941
Go here for a lot of info.
http://www.rzrd500.com/phpBB2/index....1bcce03e4b52b7
whisperquiet is offline   Reply With Quote
Old 12-03-2012, 02:33 PM   #12
sprouty115 OP
sprouty115's Avatar
Oddometer: 1,490
Thanks for the link. Also looking at the 2strokeworld forums. There are some posts by Lyn Garland about cost, so I have some more data and I make sure of what the shop is planning on doing I'll have an idea if the cost is reasonable.
Sort of leaning towards taking a gamble with the used crank to try to minimize the cost as LasseNC suggested and see if he likes it.
Old 12-03-2012, 03:32 PM   #13
stainlesscycle
Oddometer: 2,267
still don't know what bent crank means. a crank rebuild with new rods and all bearings is another $400-500. that's assuming your 'bent' crank is completely bad.
so that's about $900-$1000 for a bottom end rebuilt if you send it out.. that's assuming the trans is good.
you could do it yourself for about $300-$400 in parts and whatever the crank rebuild would cost if you supplied the parts - starts at about $100 depending on what you want done/who you have do it...
or you could spend 2k to fix your running bike.
current bikes
Old 12-03-2012, 06:16 PM   #14
sprouty115 OP
sprouty115's Avatar
Oddometer: 1,490
I definitely hear you, it's a lot of money. I'm headed down this week to see exactly what's going on in-person. Should know more in a day or two. Just remember though the $2k is for top and bottom plus pulling and reinstalling the engine. I'll repost again when I sort it out a bit more. Thanks, appreciate your input.
Old 12-03-2012, 11:17 PM   #15
Shocktower
Shocktower's Avatar
Oddometer: 9,474
That is very high, and if the bike runs, I would question the shops Rep, here's another link for some great help 2stroke world has tons of help and parts for them bike's
Alexa Drew Nov 9 1995- Oct 28th 2004 Miss you baby
'08 KTM 530 EXC
79 RD 400 Daytona
Shocktower is offline   Reply With Quote
Times are GMT -7.   It's 10:01 AM.
