Old 12-02-2012, 11:36 AM   #1
Pepperjack OP
Oddometer: 135
Changing tyres KTM990 Adventure
Hey gang...
OK, I have a 2012 model, with ABS etc. And...I've changed/repaired many flats on my trusty old XR 600..so I'm not fearful of Tyre irons etc.
Here what I'm thinking ...:
- My bikes runs tubes, front and back right..? ie stock as I purchased it..its only done 3000km ;-)
- is there anything tricky about getting the wheels off on the trail..? Any special tools needed other than what it in the factory tool set.?
- anything tricky about breaking the beads..?
- the bike doesn't use rim locks ...how so for such a powerful mother of a beast..??? That's what leads me to think there is something 'not normal' about these wheels/tyres (pirelli scorpions) .
- once patched the tube..any tricks about pumping it up etc..? I have a hand pump...it'll take a while I know but bottles wouldn't be big enough and I don't want to carry a compressor ..ideas though???
- will it seat OK etc after..sometimes on the old XR it was challenging ..and those tyres were no where near as full on etc.
Has anyone made up a video etc..?
I did some quick searching but appols if this is well covered somewhere, if so please just post the links ;-)
e-mail : Ian@gilian.net
Mobile : 0408 52 88 00
Spot : http://ozadv.com/ian
Rides : '14 BMW R1200GSA
Pepperjack screwed with this post 12-02-2012 at 11:41 AM
Pepperjack is offline   Reply With Quote
Old 12-02-2012, 12:11 PM   #2
el queso
toda su base
el queso's Avatar
Oddometer: 710
I've only seen one 990 trailside tire repair, but it was pretty straightforward. We couldn't get the bead to set properly on the trail with a hand pump, so we got it close enough and rode to a gas station. IIRC it took about 80 psi to pop, using a little wd-40 for lube.
el queso is offline   Reply With Quote
Old 12-02-2012, 12:45 PM   #3
stickysidedown
stickysidedown's Avatar
Oddometer: 661
I (and I'm sure many others) have changed tyres numerous times on the side of the trail.
the rim is slightly unusual having a sort of ledge that the bead sits on with a secondary smaller bump on it that in normality would be behind the bead.
don't let that worry you though, changing the tyre is the same process but is a little tougher to do especially if the tyres been on for a while or its cold
I always use motion pro alloy levers and whilst I sometimes have to work the tyre for a bit it's always come off, Heidanaus, pirellis, Mefos, TKC's and Michelin Deserts
seating some of them is a pain, even with a garage compressor, don't sweat it though, max out the compressor (I often use an 8" hand pump) and ride for 2-3 minutes, it will be a lumpy ride but the tyre will warm and seat itself
stickysidedown is offline   Reply With Quote
Old 12-02-2012, 01:43 PM   #4
TcRulz
Oddometer: 289
Back tyre is a PITA to change due to that safety lip. Took about 40cm of it off with a belt sander and leveled it down till it was smooth with the rim. Did the section opposing the valve so I know where to start with the tyre irons and to help keep balance No downside so far and helps break that bead.
TcRulz is offline   Reply With Quote
Old 12-02-2012, 07:29 PM   #5
MAXVERT
Rough Rider
MAXVERT's Avatar
Oddometer: 1,043
Best way to break the rear tire bead is to place bike on center stand.
Take rear wheel off.
Put the side stand down ( I've welded a bigger foot on mine )
Place the rear tire under the side stand.
Rock the bike over on the center stand, using the side stand foot
to break the bead.
The front bead is usually easy to break with boot pressure.
It's a good idea to practice all this at home first.
Max
Da oggi la strada
senza limiti
MAXVERT is offline   Reply With Quote
Old 12-02-2012, 09:55 PM   #6
4corners14
4corners14's Avatar
Oddometer: 659
If you're by yourself.....
do this as indicated below..If you're riding with anoother bike, use their kickstand. I carry a 12V compressor from Aerostich and have no problems setting the bead. Unfortunately I've had the occaision to use it a fair number of times. It's small, light and works. I've even used it to air up car tires in a pinch. Also the aluminum Motion Pro tire irons, work for the rear axle nut and they weigh nothing.
I'd be interested to know what you all carry for Tire lube, and how you carry it (what container)
to break the bead.
Max
4corners14 is offline   Reply With Quote
Old 12-04-2012, 04:19 PM   #7
FakeName
Wile E Coyote SuperGenius
FakeName's Avatar
Oddometer: 1,819
Hotel shampoo.
2011 White 990 Adv S
2014 500EXC Black
FakeName is offline   Reply With Quote
Old 12-03-2012, 02:04 PM   #8
MotoTex
Miles of Smiles
MotoTex's Avatar
Oddometer: 1,714
to break the bead.
Max
Remember to include the bit where you tie the center stand to something up front so it doesn't fold up accidentally.
This is The Internet. Confirm for yourself anything you may see while visiting this strange and uncertain land.
MotoTex is offline   Reply With Quote
Old 12-03-2012, 10:31 PM   #9
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,071
+ on grinding off the safety bead. 40cm seems like too much, that's almost 16". Would recommend more like 8" or 18cm. Once done you can pop it off by hand. You must use lube to get it back on. Oil is not a good idea for long term, only emergencies. If you carry soap and mix it with a little water it will lube it enough to pop with only 20psi. Soap won't effect the rubber.
"Son, you can't do both"
Old 12-04-2012, 05:35 PM   #10
Cyath
Impetulant Ignoramus
Cyath's Avatar
Oddometer: 432
I carry a small bottle of RuGlyde or Simple Green. Both work well and if you let it sit on the bead for a bit, it makes popping the bead MUCH easier. I've heard some folks use Chapstick in a pinch to re-seat the tire.
"You think I can remember what you posted a year ago? I can't remember what kind of beer I drank for breakfast." -SScratch
'10 KTM 990 Adventure aka The Spork
Cyath is offline   Reply With Quote
Old 12-05-2012, 07:22 AM   #11
crofrog
Oddometer: 1,455
Why don't you take your wheels off with what you have in your tool kit and find out?
crofrog is offline   Reply With Quote
Old 12-06-2012, 11:55 AM   #12
cjracer
AWD please!!
cjracer's Avatar
Oddometer: 3,974
This was taken years ago at one of our early tech weekends.
http://www.youtube.com/watch?v=uzgHVjXZwoM
It still works today on all the tires that I have dis-mounted.
-Scorpion
-908
-K60
-TKC80
-Teraflex
It's good to have this in your bag of tricks out on the tail.
Like many have said. Practice at home, makes it easier on the trail.
My 2006 950S thread. 2006 950s update
New product updates here! Wordpress BLOG
click www.cjdesignsllc.com for the full line of products. FREE STUFF!!
cjracer is offline   Reply With Quote
Old 12-06-2012, 12:55 PM   #13
SierraJeep
It's toast
SierraJeep's Avatar
Oddometer: 630
While the sidestand (and center stand) trick works well, be very careful about NOT putting the rotor side down on the ground when you start - especially if you have a newer KTM with the free floating rotors. You can put the sprocket side down or even better pop the sproket off and put the hub on the ground. Cardboard or a shop towel can help keep it clean in the process (if you're trailside).
The video above is done correctly.
Tod
2010 KTM 990 Adventure
2010 KTM 450 EXC
SierraJeep is offline   Reply With Quote
Old 12-06-2012, 01:20 PM   #14
cjracer
AWD please!!
cjracer's Avatar
Oddometer: 3,974
There is a 1 x1" block I use in the shop to rest the rim on (sidestand side) to get the hub up off the ground. (shown in video)
On the trail I'll look for a branch or dig a small ditch if need be. (to keep the rotor off the ground. Gotta do what can when on the side of the road.
If you looking for a cheap, strong drop cloth for the trails. You can wrap your tire irons in a USPS shipping bag. They are "Tyvek".
Strong, light weight, and Free.
Old 12-06-2012, 02:28 PM   #15
Yardstick
Hydrophobic
Yardstick's Avatar
Oddometer: 3,075
Looks like a good time to post this image again:
The short story: Riding 2-up in the middle of the desert we got a screw in the rear tire. The safety bead didn't hold so the tire was already loose. I was transferring tire irons between this 950 Adventure and my 950 SE and hadn't put them back on the Adventure for the ride. I got the idea to try using the short axle tools as tire irons and due to the Adv's large drop center wheel it was easy to dismount one side of the tire and replace the tube. I got the tire back on with my foot (in boots) only -no tools at all. Pumped it up with a small electric slime pump and rode home.
Longer story is here.
Yardstick is online now   Reply With Quote
Times are GMT -7.   It's 09:41 AM.
