Old 12-06-2012, 10:46 AM   #1
Deepc OP
Oddometer: 299
Need help with heated grip fuse
05.5 950A. I installed my heated grips to acc2 and they worked for awhile then stopped. I tried plugging them into acc1 and they work great. My phone charges on acc2 just fine. Put a multimeter on both. Acc1 puts out slightly more power than acc2. What at Im I missing here. All fuses look good. Where is this 5 amp fuse? Is there a hidden switch? Good t the bike ripped apart and I'm leaving on a 1600 mile ride tomorrow. I know I could just leave it on acc1 but that would almost guarentee a dead battery
Deepc is offline   Reply With Quote
Old 12-06-2012, 11:43 AM   #2
Deepc OP
Oddometer: 299
They are the kimpex grip set draws 2 amp on low, 3 on high. Awesome option, if i could just get them to work on acc2. I also have a brand new shorai that works awesome, so its not battery related acc1 puts out 13v and accs puts out 12.5v on the multimeter
Old 12-06-2012, 03:12 PM   #3
Frog uk
Oddometer: 287
Acc2 fuse in the fuse box in the glove compartment.
On my 950 the carb heaters are in the Acc2 circuit as well, grips work fine unless the temperature drops enough for the carb heaters come on, and the fuse blows.
Changed fuse to a 7.5 amp, no problems for 2 years now.
Frog uk is offline   Reply With Quote
Old 12-06-2012, 05:02 PM   #4
spafxer
spafxer's Avatar
Oddometer: 2,649
My Acc 1 and 2 fuses are both 10 amp stock.. 06 950 Adventure.
Hard to say if it is ok to put a 10 amp fuse in without knowing the wire gauge used in your harness.
spafxer is offline   Reply With Quote
Old 12-07-2012, 07:24 AM   #5
Deepc OP
Oddometer: 299
Thanks for the input. Ripped everything apart, cleaned, and made sure it went back together correctly. Now it works on acc2 but we'll see for how long.
Old 12-07-2012, 01:14 PM   #6
DSM8
Where fun goes to die....
DSM8's Avatar
Oddometer: 4,009
A suggestion
Put a relay under the headlight mask that is connected straight to the battery.
Connect your grips to that, have the relay trigger by acc2 ( that is the switched one IIRC, only powered when the bike is running).
This will eliminate the load from the stock harness, your grips will perform better since they will draw straight from the batt. I used a 12ga wire for the relay so there is as little resistance as possible. I also power my LED driving lights off the same circuit.
You can see it on the left side in the picture with the blue wires. The bundle is bulky due to the connectors for the LED's
DSM8 - A different kind of mean
SQL > SELECT finger FROM hand WHERE id=3
http://share.findmespot.com/shared/f...d5LbKWMz6cHxaH
DSM8 is offline   Reply With Quote
Times are GMT -7.   It's 04:00 PM.
