Old 12-09-2012, 03:12 PM   #1
Scotty4x4 OP
Oddometer: 132
Arai XD-4 helmet whistling.
Hey everyone
I just brought a arai XD-4 adventure helmet, anyway I get it home take it for a ride and find that any speed over 40 it whistles like a vortex throwing ball thing. Rang arai got some recommendations and he said check for leaks around the visor and just locate the noise. The noise comes from the sun visor/peak of the helmet. I took it back after a week to shop I brought it off and I was told it was normal for a arai helmet to whistle. And she said to get use to it.
The thing that annoys me is the fact I brought a $800 dollar helmet that is worse than my old $200 dirt bike helmet.
So my question is does anyone else have a arai XD-4 and do they find they whistle? Not just wind noise, but whistle like one of those vortex throwing balls
Scotty4x4 is offline   Reply With Quote
Old 12-09-2012, 03:25 PM   #2
Dr AT
(KTM quack)
Oddometer: 2,119
MIne doesn't whistle, but apparenlty on some bikes the intake vents on the visor can whistle if left open . If closing them improves the whistle you cold consider using one of the xd 3 or older visors which didn't have the vents?
Dr AT is offline   Reply With Quote
Old 12-09-2012, 03:34 PM   #3
Wasca
Adventurized!
Wasca's Avatar
Oddometer: 600
Originally Posted by Scotty4x4 View Post
Hey everyone
I've got one and can't report hearing any defined whistling noise. You do get your normal wind noise but that's about it. Overall I'm very happy with my Arai XD4. Any chance you can get it exchanged as defective? Would be happy to vouch for you that the whistling noise is not normal.
Wasca is offline   Reply With Quote
Old 12-09-2012, 03:41 PM   #4
Hendo66
Hendo66
Hendo66's Avatar
Oddometer: 188
No whistling from outside, only from me inside because I am happy :) best helmet yet.
I'm sure you've tried placing your hands up around the visor to try & pin point the area making the noise?
I would also try another bike to check its not turbulence related from bike????
After that take it back and request trying another helmet.
Hendo66
2008 BMW F800GS 2011 BMW R1200GS
Hendo66 is offline   Reply With Quote
Old 12-09-2012, 03:54 PM   #5
DR-DRZ
Oddometer: 416
[QUOTE=Hendo66;20213081]
+/QUOTE]
+1 on this, if you have a fairing of some sort, it might be directing air at the peak causing the whistle.
You could even just try standing up and get into some clean air.
Benellli Tre-K 1130
DR-DRZ is offline   Reply With Quote
Old 12-09-2012, 05:33 PM   #6
Wallaby_Ted
You call that a bullbar?
Wallaby_Ted's Avatar
Oddometer: 120
Had the same problem. For me it was generated at the back of the peak (or tailing edge). I stuck a bit of foam (about 2-3mm thick) on the underside of the peak at the back to disturb the airflow and that has worked. When I get a chance I'll post a pic.
Left or right???
www.checkingtheboundaryfence.com - The upside, down-under tour of Australia. August to September 2009
Wallaby_Ted is offline   Reply With Quote
Old 12-09-2012, 05:35 PM   #7
Wallaby_Ted
Oddometer: 120
Ps - mIne did it standing, sitting and everything in between so I concluded it wasn't bike related
Left or right???
Old 12-09-2012, 05:41 PM   #8
mcguyver
mcguyver's Avatar
Oddometer: 1,278
Mines heaps quieter than my Old XD3. Is the airflow coming off your bike causing it perhaps?
mcguyver is offline   Reply With Quote
Old 12-14-2012, 03:12 PM   #9
Wallaby_Ted
Oddometer: 120
Did you try this yet? Here's a photo of what i have done.
Left or right???
Old 12-14-2012, 09:50 PM   #10
Scotty4x4 OP
Oddometer: 132
i will try that next. thanks for the photo!
no all the vents were still open the same.. it was only drizzeling...
Old 12-09-2012, 08:53 PM   #11
Clancy
Clancy's Avatar
Oddometer: 5,941
I've got one and it doesn't whistle. Like someione else has said, it may depend on air flow over the front of your bike and the direction it hits your helmet from. Mine's a lot quieter then the previous model.
And he sees the vision splendid of the sunlit plains extended,
And at night the wondrous glory of the everlasting stars.
Clancy is offline   Reply With Quote
Old 12-09-2012, 09:16 PM   #12
R&R4adv
R&R4adv's Avatar
Oddometer: 341
Mines not whisling but found if i closed the brow vents in the visor the wind noise is alot less.
R&R4adv aka Reon
04 950 Adventure
past bikes
04 950 Adventure 03 640 Adventure 99 XR400
R&R4adv is offline   Reply With Quote
Old 12-09-2012, 09:36 PM   #13
Andy_P
Oddometer: 452
Mine does not whistle either, but it did when I broke one of the pinlock pins. Now has a piece of tape over the pinlock hole and problem gone.
Andy_P is offline   Reply With Quote
Old 12-09-2012, 09:46 PM   #14
philth
philth
philth's Avatar
Oddometer: 6,265
why do lady parachutists wear parachute pants?
so they dont whistle on the way down
i must not post hairy buttocks
philth is offline   Reply With Quote
Old 12-09-2012, 11:08 PM   #15
GodSilla
I did that.
GodSilla's Avatar
Oddometer: 7,880
What tune is the helmet whistling? This is important, as different tunes signify different things.
For instance, if it's whistling Dixie you need to join the Rebels and get the confederate rockers on your jacket. If it's whistling I Should Be So Lucky, then wear a little skirt and go acting. If it's whistling like a kettle, bring a tea bag......you get the idea.
Death to Turnips.
GodSilla is offline   Reply With Quote
Times are GMT -7.   It's 11:33 PM.
