Old 12-25-2012, 08:52 AM   #1
mcmann OP
Motorcycle Maniac
mcmann's Avatar
Oddometer: 2,093
Can we join OC if we have spoked 19" X 17" wheels on our SM?
Can we join OC if we update our SM with Canyon/Adventure spoked wheels?
I sold my SE and got a SM because I was riding mostly street and was unhappy with the single front SE brake and no crash bar options etc.
I miss Orange Crush . . . . And would be willing to update my SM with spoked wheels if I could return to OC etc.
I understand Woodys is working on SM Canyon Dancers wheel sets.
I have already converted my SM to SMT:
Here are a couple inmates that have gone to spoked 19" X 17" wheels on their SM:
For comparison(1190R) w/19" front wheel. I prefer my SM carbs over high-tech Gismo's
"In the end, it's not going to matter how many breaths you took, but how many moments took your breath away"
mcmann screwed with this post 12-25-2012 at 09:26 AM
mcmann is offline   Reply With Quote
Old 12-26-2012, 12:08 AM   #2
LocuL
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,385
My opinion: Bring it
KTM 950(1190) Adv-s, Soon to be Project 1190
KTM 530 EXC-R 08
LocuL is offline   Reply With Quote
Old 12-27-2012, 01:20 AM   #3
Blackbert
Factory Rambler
Blackbert's Avatar
Oddometer: 1,059
Locul even went for 21" and 18" wired wheels in an RC8 to get an entry.
Honestly, have you ever heard of somebody looking back on his life thinking: "Oh, I should have travelled less and mowed the lawn more often"? (Pumpy)
want to save on Smugmug? use this code (VoUO8M1ukmnMY)
Blackbert is offline   Reply With Quote
Old 12-27-2012, 02:41 AM   #4
LocuL
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,385
Haha merry something for everyone.
KTM 530 EXC-R 08
Old 01-06-2013, 04:38 AM   #5
mcmann OP
Motorcycle Maniac
mcmann's Avatar
Oddometer: 2,093
Please confirm front hub spec
Please confirm what you did on the front 19" hub: did you use the 990A hub/rotors with 5mm less bite in the SM calipers, or did you use a 690 SMC hub with spacers in between the rotors and hub. If so, what are the specs on the spacers?
Nice bike! Looks like a KTM Off-Road V-Twin to me:
Old 01-06-2013, 10:32 AM   #6
brents347
Trusting my Cape...
brents347's Avatar
Oddometer: 3,914
That was a stock 950 Adv. hub. I don't recall waht I did for rotor width spacing, but I made custom axle spacers and then used some little spacers under the stock SM non-foating calipers to make the stock SM rotors fit with full brake pad bite. As I recall, these spacers were just 3mm thick.
So, stock 950 Adv. 19" wheel, stock 950SM brakes and rotors with some minor spacers.
07 Yamaha R6
07 KTM 950 Super Enduro
04 KTM 250exc- plated two-stroke
01 Kawasaki KE100
74 Honda MR50
brents347 is offline   Reply With Quote
Old 01-06-2013, 10:40 AM   #7
mcmann OP
Motorcycle Maniac
mcmann's Avatar
Oddometer: 2,093
Thanks for the info . . .I though the 950SM rotor bolt pattern was diiferent than the 950A rotor.
mcmann screwed with this post 01-06-2013 at 12:21 PM
Old 01-06-2013, 11:26 AM   #8
brents347
Trusting my Cape...
brents347's Avatar
Oddometer: 3,914
Originally Posted by mcmann View Post
Thanks for the info . . .I though the 950SM rotor bolt pattern was diiferent than the 950 rotor.
Nope. Same. Here is a picture thar shows the caliper spacers, just under the word Brembo.
[IMG][/IMG]
And I remember now, the width of the SM rotor spacing was larger so I machined some full spacer rings for each rotor.
07 Yamaha R6
01 Kawasaki KE100
74 Honda MR50
Old 01-06-2013, 03:04 PM   #9
Peanuts
Peanuts's Avatar
Location: Beautiful but often rainy North Yorkshire, UK
Oddometer: 1,731
[IMG][/IMG]
They look like 950 Adv discs?
Peanuts is offline   Reply With Quote
Old 01-06-2013, 07:20 PM   #10
brents347
Trusting my Cape...
brents347's Avatar
Oddometer: 3,914
Hmm, they DO look like Adv discs! And since SM discs would have been flaoting, I think they must be.. But I remember spacing the calipers (and you can see the spacers in the pic), so the Adv. disc is bigger than the SM?
I'll check...
Yep, adv discs are 300mm and SM's are 305mm so know I honestly don't know. Damn my memory sucks.
07 Yamaha R6
01 Kawasaki KE100
74 Honda MR50
Old 01-06-2013, 07:25 PM   #11
brents347
Trusting my Cape...
brents347's Avatar
Oddometer: 3,914
Yes, SM rotor spacing is COMPLETELY different. Don't kno what I was thinking.
07 Yamaha R6
01 Kawasaki KE100
74 Honda MR50
Old 01-06-2013, 11:20 AM   #12
Peanuts
Peanuts's Avatar
Oddometer: 1,731
Thats the handy thing with radial calipers. Only requires a quick swap of spacers and bolts to change disc size.
Old 01-06-2013, 12:19 PM   #13
mcmann OP
Motorcycle Maniac
mcmann's Avatar
Oddometer: 2,093
Any SM riders near Denver. Zach needs front hub specs: overall spacing, and also if the spacers are the same on both sides of the wheel, axle diameter, inside width between rotor's and rotor width.
Woody's Wheel Works LLC
Attn: Zach
2226 S. Jason St.
Denver, CO 80223
(303) 936-0232
www.woodyswheelworks.com
woodyswheelworks@gmail.com
mcmann screwed with this post 01-07-2013 at 03:55 AM
Old 01-06-2013, 07:34 PM   #14
brents347
Trusting my Cape...
brents347's Avatar
Oddometer: 3,914
Attn: Zach
2226 S. Jason St.
Denver, CO 80223
(303) 936-0232
I can answer some of these questions, I have an unbuilt SM wheel in the garage that I can look at/measure tomorrow.
Axles are the same diameter from the Adv to the SM because when I mounted SM wheeels to my Adv I used the stock Adv axle with a stock SM wheel. I can get other dimentions tomorrow, but as I recall the 2 spacers are completely different. Then again, we know about my memory...
07 Yamaha R6
01 Kawasaki KE100
74 Honda MR50
Old 02-07-2015, 10:06 AM   #15
GeordieMoore
Oddometer: 3
Spoked Wheels
Man ive been trying to figure out how to do spoked wheels on my SM what im trying to do is keep the road wheels and set up but sort it so its capable to swap them out quickly to maybe a 21 front without swapping out the forks failing that something smaller and maybe a 19 rear but not to fussed any advice would be grateful, I emailed wheeleworld and they told me they had nothing for a 950sm
GeordieMoore is offline   Reply With Quote
Times are GMT -7.   It's 11:24 AM.
