Old 12-31-2012, 09:48 PM   #1
nitrox32 OP
Oddometer: 57
rear wheel not spinning freely
I was checking on the bike this evening for a ride tommorrow. When I went to spin the rear wheel it is taking a alot of force to spin. The best way I can describe it is a compression stroke when I spin the wheel. It is real hard to turn for a few degrees then it is easier to turn for a few degrees. There is no play side to side. The brake pads and rotor looks good and not warped.. Any ideas ?
07 BMW R1200 GSA
01 Aprilia Futura
nitrox32 is offline   Reply With Quote
Old 12-31-2012, 10:12 PM   #2
Multiplicity
Oddometer: 172
FD Bearings, brakes or what sounds like a possible U-Joint/drive shaft bearing issue
Multiplicity is offline   Reply With Quote
Old 12-31-2012, 10:39 PM   #3
def
Ginger th wonder dog
def's Avatar
Oddometer: 10,195
take it out of gear.
def is online now   Reply With Quote
Old 12-31-2012, 11:35 PM   #4
AndyM
Oddometer: 341
Drive shaft, u-joints
AndyM is offline   Reply With Quote
Old 12-31-2012, 11:36 PM   #5
BKFoster
Oddometer: 168
U-joint. Mine was just like that. It would bind then loosen up then bind again every rotation.
Mine was the front u-joint @ 42,000 miles.
BKFoster is offline   Reply With Quote
Old 01-01-2013, 03:30 AM   #6
Jim Moore
Jim Moore's Avatar
Oddometer: 13,692
Is it also making a "Clunk-clunk, clunk-clunk" noise? That's probably a u-joint on the driveshaft. How many miles on the bike?
Jim Moore
Jax, FL
Pay the lady, PirateJohn, you thieving piece of garbage.
http://advrider.com/forums/showthread.php?t=949341
Jim Moore is offline   Reply With Quote
Old 01-01-2013, 06:42 AM   #7
bemiiten
League of Adventures
bemiiten's Avatar
Oddometer: 4,947
What others have said, you have a bad u joint, most likely the front. Definitely do not ride the bike until it's repaired. How many miles? Sure would like to see the NHSTA get involved and force a recall.
bemiiten screwed with this post 01-01-2013 at 06:51 AM
bemiiten is offline   Reply With Quote
Old 01-01-2013, 08:00 AM   #8
kimokk
kimokk's Avatar
Oddometer: 103
What's the recall for? There's no safety issue and the bike has 37k miles, Sounds like normal wear and tear to me. Replace it and keep riding!
'09 BMW R1200GSA Adventure! (gone)
IBA #49426
kimokk is offline   Reply With Quote
Old 01-01-2013, 08:05 AM   #9
Multiplicity
Oddometer: 172
I don't know about a recall, but U-Joints shouldn't fail at 37K, IMO. RWD automotive applications will last over 150K
Old 01-01-2013, 08:23 AM   #10
bemiiten
bemiiten's Avatar
Oddometer: 4,947
No safety issue, are you kidding?
Old 01-01-2013, 08:44 AM   #11
lhendrik
Truffle Rustler
lhendrik's Avatar
Oddometer: 2,371
I have a hangover, so maybe we could stay on topic? This isn't a recall thread. It's about finding out what is wrong with this guys drivetrain. I would like to know before my 09 blows up in BFE.
Normal is just a setting on the dryer.
2009 R1200GS A, 2008 K1200GT
lhendrik is offline   Reply With Quote
Old 01-01-2013, 09:37 AM   #12
kimokk
kimokk's Avatar
Oddometer: 103
No, not kidding. I think the symptoms of imminent failure will be evident way before it breaks. This should give you more than ample time to get it replaced or repaired. Sorry OP for your current problems!
IBA #49426
Old 01-01-2013, 09:43 AM   #13
whisperquiet
whisperquiet's Avatar
Location: 62298 in lovely corrupt/bankrupt Southern Illinois
Oddometer: 941
What's the recall for? There's no safety issue and the bike has 37k miles, Sounds like normal wear and tear to me on a BMW R1200 series bike.. Replace it and keep riding!
Fixed.
whisperquiet is offline   Reply With Quote
Old 01-01-2013, 06:52 AM   #14
nitrox32 OP
Oddometer: 57
I have 37K on the bike. I do hear some clunking. Thanks for the input.
07 BMW R1200 GSA
01 Aprilia Futura
Old 01-01-2013, 12:06 PM   #15
nitrox32 OP
Oddometer: 57
Bike is out of warranty but this was one of the few times I bought an extended warranty.
The wheel not even spin with the bike running in neutral on the center stand.
07 BMW R1200 GSA
01 Aprilia Futura
Times are GMT -7.   It's 08:31 PM.
