Old 01-05-2013, 04:11 PM   #1
JimVonBaden OP
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 52,929
R1200GS Cheap Farkling!
On my last R1200GS, that I bought new, I farkled like crazy, adding top of the line everything I could find that I even thought I needed. However, since I got this bike with 120K miles on it for a very good price, and I am going to buy a Wethead next year, I decided to farkle this one on the cheap.
Now, some things you can't cheap out on, like I changed out the quick disconnects and added the flange clamps, but most really can be done at a reasonable price.
This thread will show how I did it. I plan on adding more as I go along, and I encourage others to add their cheap farkles!
First, I took a pair of old foot pegs, and combined them with the ones on the bike, and now I have a version of adventure pegs:
This could be done with bolts instead of welding if you don't weld.
Cost, free to me. Many have these lying around and would give them away.
Next, my old grips were worn out, but the heating still worked. I could have just replaced the grips with aftermarket like some have done, but I like my grips a bit bigger, so Grip Puppies it is:
Old grip
Remove hand guard, T55 and T25.
Lube (I used tire lube, but dish soap and water works) the new and old grips and slide the new ones on. It can be hard, so I gently used some pliers to pull them on. The lube will dry and help them stick.
Installed, took about half an hour.
Cost $10 + $3 shipping.
Next, mine came with an aftermarket screen, Givi. Great for winter, too big for summer. I found this one online cheap, but it had a pretty bad scratch. So I fixed it.
I used sandpaper from 220 grit to 2000 grit. Wet sand carefully each grade, and watch the results. I used a sanding board, which helped keep the sandpaper only on the edge.
The following is a series of shots after each grade:
220
400
600
1500
2000
Then I polished with Meguires Ultra polish.
There were a couple of leftover deep gouges right at the edge, but they now barely show. The screen looks like new. New is $175.
Cost $35.
I had ROX Risers on my old GS, and I really liked them. But, in keeping with the cheap theme, I found a pair of risers that looked appropriate on the flea market, and cleaned them up.
My trippletree is black, so I painted them.
Old ones, rust included.
Old removed clamps.
I had to put the cables and hoses behind the forks. I have shown this before.
Installed.
This took a couple hours, paint dry time.
Cost, $35 shipped, and trim paint I already had.
Finally, for today, I wanted a fat foot, but didn't want to pay for it, so I made one.
Backside of an old sign, with very thick aluminum.
Trimmed with a grinder.
Lots of grinding and drilling later, a few countersunk screws and nylocks, and I have a fatfoot.
I have a lot more to do, and I will post it up as I go.
Again, please feel free to add your own.
Jim
Old 01-05-2013, 05:12 PM   #2
mtrdrms
Oddometer: 401
Fantastic! Great job Jim and nice looking bike!
Everyday. No excuses.
2007 BMW R1200GS
2013 KTM 450 XC-F
mtrdrms is offline   Reply With Quote
Old 01-05-2013, 06:28 PM   #3
Lobby
Viel Spass, Vato!
Lobby's Avatar
Oddometer: 28,407
Good thread, Jim. Good work, too.
Gracie's Gold
Lobby is online now   Reply With Quote
Old 01-05-2013, 06:53 PM   #4
motomandan
motomandan's Avatar
Oddometer: 444
Great job!
motomandan is offline   Reply With Quote
Old 01-05-2013, 08:06 PM   #5
LaurelPerryOnLand
Oddometer: 3,480
Ladies and gentlemen,
You have just witnessed what days were like BTT*.
*Before TouraTech.
Great ingenuity and resourcefulness prevails, yet again, compliments of and compliments to the Master.
LaurelPerryOnLand screwed with this post 01-06-2013 at 08:46 AM
LaurelPerryOnLand is offline   Reply With Quote
Old 01-05-2013, 08:19 PM   #6
Jnich77
Jnich77's Avatar
Oddometer: 680
Love the pegs man!!!
Jnich77 is offline   Reply With Quote
Old 01-05-2013, 08:30 PM   #7
JimVonBaden OP
"Cool" Aid!
Oddometer: 52,929
I did this a few days ago. Got this new from a friend.
This is it installed.
I took the trim off and painted it black, and replaced the white paper under the reflector with reflective tape.
Here you can see, left to right, the white paper, no paper or tape, and the reflective tape.
Done.
Mount bolted directly to the rack. My old JCWhitney top case went 40K miles this way. I figure this one will too.
Cost was $47, but I got it free because it was damaged, which I fixed for free. I had the reflective tape already.
Jim
Old 01-05-2013, 08:31 PM   #8
JimVonBaden OP
"Cool" Aid!
Oddometer: 52,929
Thanks, super easy to do.
Jim
Old 01-05-2013, 09:21 PM   #9
1200gsceej
1200gsceej's Avatar
Oddometer: 1,259
the original
We should pay homage to JVB's original R1200 GS Penny Tech Mod thread from 2005.
-ceej
My bike: Yellow '05 1200GS - on the Spotwalla ADV location page as CJ3.
My solo trips: 2014 Natl Park triangle, SF-Colorado-SF 2011 and 2013, SF-LA loop, Pinnacles and Carmel Valley loop
With Ol'Badger: http://www.2guysonbikes.com
And remember: Beauty is in the behind of the holder.
1200gsceej is offline   Reply With Quote
Old 01-05-2013, 09:37 PM   #10
JimVonBaden OP
"Cool" Aid!
Oddometer: 52,929
-ceej
I forgot about that one. Turned out not so "pennytech" mostly!
Jim
Old 01-05-2013, 08:38 PM   #11
ausfahrt
mach schnell
ausfahrt's Avatar
Oddometer: 1,788
Top Box
You really can't beat the JC Whitney box from a price/ utility standpoint. I had the same box on my GS until I upgraded to a Givi. The Whitney box lives on mounted to my KLR.
Great thread, Jim.
You can always count on the Americans to do the right thing, after they have tried everything else.
-Winston Churchill
ausfahrt is offline   Reply With Quote
Old 01-05-2013, 08:46 PM   #12
JimVonBaden OP
"Cool" Aid!
Oddometer: 52,929
I also wanted to have a GPS, but not an expensive mount or dedicated GPS. I wanted to use the one from my car, but it is not waterproof.
I found this on e-bay.:
It mounts solidly to my windshield bar with a strong thumbscrew, and comes with a waterproof case to enclose the GPS. It comes off quickly for easy and safe keeping. The power comes out the bottom. I have a waterproof USB plug on order, but for now it is powered with my heated gear plug.
Cost $15 shipped.
Jim
Old 01-06-2013, 05:38 PM   #13
2712
Oddometer: 374
Cost $15 shipped.
Jim
I broke my windshield bar mounting a gps like that, it snapped of on both sides from vibration. The proces took 50k miles but it the end, i had to replace the bar witch isnt cheap. Dont ride on washboard with the gps on, thats all im saying
2712 is offline   Reply With Quote
Old 01-06-2013, 06:13 PM   #14
JimVonBaden OP
"Cool" Aid!
Oddometer: 52,929
I don't think that mount would survive 50K miles, especially on washboard. However, for $15, I am willing to take a chance.
I used to have a nuch heavier RAM mount on my old GS for about 30K miles with no issues though.
Jim
Old 01-07-2013, 10:30 AM   #15
2712
Oddometer: 374
Jim
Jim,
Sorry about my english, Im trying to refer to the windshieldbracket instaid of the gps mount
It will set you back 240euro =300dollar?
I talked about it with my dealer, i was thinking of re enforcing it by welding extra metal to it, but the dealer sait it would only cause something els to break. They gave me the advice to mount it to a diffrent place.
Times are GMT -7.   It's 12:39 PM.
