Old 01-11-2013, 08:32 AM   #1
gharnden OP
Oddometer: 101
Tires - Missoula to Inuvik to Top of the World and back
I have read almost everything on this website and am very confused on tires for my upcoming trip. I would like your suggestion in relationship to tires for my upcoming trip to the NWT and Alaska. I have a R1200GS. I have ridden for over 40 years but am far from an expert on gravel and mud. I am leaving from Missoula going to Whitehorse to Dawson to Inuvik (Dempster) to Tok (by way of the Top of the World) to Missoula.
I would like to not change tires during the trip.
I have had Tourances and Anakees and know what they can do.
I went to Alaska in 2009 but not on the Dempster, Dalton, or Top of the World - Had Tourances
I realize this all depends on road conditions due to weather when I go in July.
I realize individuals do it on HDs, Goldwings, etc. and on all types of tires, especially under perfect condition.
Weather will cause us to adjust and use a little common sense.
This is what I am currently thinking as choices. What is your best all-around recommendation:
a. TKCs
b. TKC front, Heidenau K60 rear
c. Anakee 3s, if they are available
d. Shinko 705s (this is currently my last choice)
Thanks in advance for your input.
gharnden screwed with this post 01-11-2013 at 12:12 PM Reason: left out word
gharnden is offline   Reply With Quote
Old 01-11-2013, 08:50 AM   #2
Osmin C
Oddometer: 108
Most guys will tell you that a tire choice is a very personal thing and that you should simply get a tire that you are comfortable with and will last the length of your trip(you may be pushing it on the TKC rear).
That said, are you not considering the Heidi K60 scouts? Many say its the perfect 50/50 tire and many have used it for their trips to AK with much success.
Osmin C is offline   Reply With Quote
Old 01-11-2013, 08:57 AM   #3
LaurelPerryOnLand
Oddometer: 3,481
Tires for AK...
Completed a third round trip into Alaska and YT (Whitehorse) in early June, 2012 to/from Denver. 7500 miles RT.
Had Woody's install NEW Tourances for the trip. Had about 1/2 the tread left returning to Denver.
The Tourances worked perfectly well for the Dalton....all the way to Coldfoot...where there was an avalance on the North side of Atigun. No go to PB.
Dalton was DRY...temp was 82 F when I left Fairbanks.
The only "watch out" was from a trucker at the Hotspot (5 miles North of the Yukon Bridge) who advised me that the AK DOT was putting down 'mag chloride' on the road North of this fine lunch spot.
After cresting this 400 yard downslope...you could see the 'gooey' mag chloride all the way down the slope.
Trust me you'd NEVER be able to make it back UP this slope...way too slick.
So...Tourances are great for DRY to light rain conditions.
Obviously the TKC's have more bite and would be a better choice for WET conditions. Just plan your ride accordingly.
I just don't like the thought of hearing/feeling the TKC 80 'blocks' for a couple THOUSAND miles (Missoula to TOK***),
*** You MUST eat at Fast Eddie's in TOK! You can't miss it!
Photobucket
The NEW Karoo 3's might be something you should look at. Kind of a hybrid between the TKC 80 and Tourances.
http://www.metzeler.com/site/uk/prod...e/Karoo-3.html
Should be available before you leave. Website says: "Available March,2013"
LaurelPerryOnLand screwed with this post 01-11-2013 at 09:40 AM
LaurelPerryOnLand is offline   Reply With Quote
Old 01-11-2013, 05:41 PM   #4
Dan Alexander
Ride Far - Ride Fast
Dan Alexander's Avatar
Oddometer: 7,597
Option B
Beemers Past and Present: 74 R90S, 77 R100RS, 85 K100RS, 2x 87 K100RS, 96 R1100GS (getting hacked), 99 R1100S, 2002 R1150GS, 2005 F650 Dakar, 81 GL500/Velorex
Plus the occasional Triumph, BSA, Yamaha, Honda, Suzuki and KTM but who's counting
Dan Alexander is offline   Reply With Quote
Old 01-11-2013, 06:43 PM   #5
mike54
You don't get me
mike54's Avatar
Oddometer: 13,270
I've only used TKC's or Tourance's. I don't know anything about the Heidenau K60.
I used Tourances on my 1150GS when I went in 04. We had mostly dry weather and they worked fine everywhere. When we got to Coldfoot it was raining pretty good to the north so we chose to turn back at that point. Similar to LaurelPerryOnLand. I had to change the Rear Tourance before I left AK because of wear. I usually get 8,000 out of a set but the rear was gone at 6,000. The roads up there seem to eat tires more than here in CA. Given that I wouldn't start on a set of TKC's I only get 3 - 4,000 from them. If it were to do it again, I'd start on Tourances and have a set of TKC's available that I could use for the dalton depending on the weather.
What you might do is start off on Tourances and switch to the TKCs in Dalton for the ride to Inuvik. There's some bike friendly people there than can help you make that happen. Check the AK regionals.
Put the Tourances (or Anakees if you prefer) back on when you get back to Dalton and head for Tok. Top of the world sould be no problem wet or dry.
Food for though. Most of all enjoy your trip. I need to do it again.
A genius is the one most like himself. - T. Monk via S. Lacy
Do stand up guys lie?
mike54 is offline   Reply With Quote
Old 01-12-2013, 06:43 AM   #6
LaurelPerryOnLand
Oddometer: 3,481
This is a good place where you can either buy tires or have your tires SHIPPED to and they'll mount them for you when you pass through Fairbanks. They've even got a POWER WASHER you can use to de-gunk your bike after returning from the Dalton!
http://www.advcycleworks.com/
Contact Info
Dan Armstrong
907-457-4259
dans40xc@hotmail.com
Location
362 Snowy Owl Lane
Fairbanks, AK 99712
Old 01-12-2013, 05:40 AM   #7
Spaggy
Spaggy's Avatar
Oddometer: 955
Mitas?
I'm hoping to do that trip next summer too. Think I'll go with Mitas E-07 Dakars. $280 Canadian for a set and sounds like good reviews on mileage and performance. Similar to a K-60.
http://www.mx1canada.com/mitas-e07-d...ycle-tire.html
Spaggy is offline   Reply With Quote
Old 01-12-2013, 08:13 AM   #8
gharnden OP
Oddometer: 101
Thanks for the responses. A couple referred to the Dalton and places to change tires in Fairbanks. We actually are not doing the Dalton, but the Dempster. Is there a place in Dawson where I can pre-arrange to have tires purchased and installed? I guess if there is not a place in Dawson, I can always work with the Honda shop in Whitehorse.
Old 01-12-2013, 08:33 AM   #9
LaurelPerryOnLand
Oddometer: 3,481
http://www.advrider.com/forums/showthread.php?t=553779
Post #7
2-year old thread...call NAPA to confirm they still do!
Old 01-12-2013, 08:39 AM   #10
mike54
You don't get me
mike54's Avatar
Oddometer: 13,270
I said dalton but meant Dawson. Contact 'The Dick' at the Downtown Hotel in Dawson. I know you said you're going in July but if you could push it up to June and join the Dust to Dawson ride you wouldn't be dissapointed.
Old 01-12-2013, 09:20 AM   #11
CheckerdD
CheckerdD's Avatar
Oddometer: 1,292
I used to live in Alaska. Heidenau K60's will serve you fine and you should be able to use the one tire for a round trip. In both Alaska and Canada they put a chemical on unpaved roads that can be slippery when wet. I think it's purpose is to supress dust and make the surface cohesive. Except for that the unpaved roads are like any well maintained BLM road in your state. To me the idea of switching tires in unnecessary. Dave
Pavement! We don't need no stinkin pavement.
CheckerdD is offline   Reply With Quote
Old 01-12-2013, 09:29 AM   #12
vtbob
wanderer
Oddometer: 591
K60s are the best(only) long lasting 50/50 tire. You will appreciate them on the dempster of other dirt it is wet and muddy.
One set should last you the trip.
It is a hard rubber tire..ie why it last so many miles but has reasonable bite in muddy roads. Ok on pavement evan at speeds to 100. It is NOT your tourance on wet pavement...so take it a bit easier there.
check out this month BMW owner magazine for a very good article on the K60 vs the TKC, etc
vtbob is offline   Reply With Quote
Old 01-12-2013, 10:07 AM   #13
waynem
Oddometer: 142
Tourances
Two of us did the same ride last June and both were on 1200 gs's and had no problems on the tourances, even in soup up the dempster during a rain storm and then into the N.W. territories where we were the first of about seven bike to cross the Mckenzie after the ferrie re-opened and we were faced with mile after mile of pea gravel that had been laid down on the road and had not had more than maybe 9 trucks tamp it down, a fkn really miserable way to see the territories. We did 7200 miles and pretty much ate the rear but had 6k more on the front.
at the end of the ride.
waynem is offline   Reply With Quote
Old 01-13-2013, 03:20 AM   #14
tagesk
Tuscan rider
tagesk's Avatar
Oddometer: 3,227
Sorry to digress - but why is it called "Top of the world" when Inuvik according to Google Maps is at a mere 68 degrees north?
Am I missing something?
[TaSK]
'02 R1150GS - Adds life
My Riding in Tuscany-thread is here.
Renting out motorbikes in Toscana, Italy
Proud contributor to Wisdom and GSpot FAQ and European Ride Report Index.
IBA: 33616
tagesk is offline   Reply With Quote
Old 01-13-2013, 03:31 AM   #15
mike54
You don't get me
mike54's Avatar
Oddometer: 13,270
[TaSK]
It's just a name. It's the Hwy that runs from Tok to Dawson.
Times are GMT -7.   It's 08:59 AM.
