Old 01-16-2013, 12:40 AM   #1
DDT Rider OP
Oddometer: 473
Raid Twalcom Final Drive Protector Install?
Got one of these plastic version protectors after I already scratched the FD on a simple tip over...the black plastic unit looks to have good scuff coverage, but I can't manage the install.
I can't hold the inner metal anchor in place while installing the bolt.
What's the secret?
DDT Rider is offline   Reply With Quote
Old 01-16-2013, 07:16 AM   #2
El Gato
El Gato's Avatar
Oddometer: 752
What's the secret?
I have the Hyde Racing protector, which seems to mount the same way as the Twalcom unit. It was a b&^$% to install. You have to get the rectangular nut in the slot, then turn it 90 degrees to get it into the position you want, and then pull down on the screw to hold the nut in position while you try to turn the screw... all while cursing and repeating the process multiple times as the nut slips out of position. Eventually you'll get lucky and it will stay where you want it. Having lots of beer handy helps, or at least helps ease the memory of just how irritating it was.
El Gato is offline   Reply With Quote
Old 01-16-2013, 08:25 AM   #3
trc.rhubarb
trc.rhubarb's Avatar
Oddometer: 1,997
I can't see it but going by your description, could you put some sticky grease on the nut to hold it in place?
or a dot of superglue (not a blob)
2007 BMW GS Adventure / 2000 Ducati 900ss / 2010 Harley Ultra Limited / 1975 BMW R90/6 / 2006 DRZ400S
Follow me here
trc.rhubarb is offline   Reply With Quote
Old 01-16-2013, 10:40 AM   #4
scooteraug02
Dog Rancher
scooteraug02's Avatar
Oddometer: 4,521
http://advrider.com/forums/showthread.php?t=772198
Above is some more info.
scooteraug02 is offline   Reply With Quote
Old 01-16-2013, 02:58 PM   #5
DDT Rider OP
Oddometer: 473
Originally Posted by scooteraug02 View Post
Yeah, I'm in that thread on post #20 asking more info on how folks installed. I might send some PMs to those that have...this install appears very awkward at best for something that will have to be removed each time for FD fluid change, etc...
Old 01-16-2013, 07:06 PM   #6
DDT Rider OP
Oddometer: 473
Dang...I can't PM fudgypup from that original thread as he has bee banned :(
Old 02-01-2013, 03:33 AM   #7
DDT Rider OP
Oddometer: 473
I finally got it installed!!!
Times are GMT -7.   It's 08:57 PM.
