Old 01-17-2013, 07:42 PM   #1
Leo562 OP
Oddometer: 22
Question I Have NO Experience
Hi I'm Leo and I am 18 years old.
My father has left a 1978 BMW R100S. It has been sitting in our garage for about the same amount of time that I have been alive.
But now my father has left and I am left with the exciting pleasure of restoring it. But there is a catch I am not experienced at all.
The only thing I have is the Clymer Manual and the tools my father left me and of course the BMW it self.
I have joined this community due to the fact that I see potential help. This community seems very knowledgable.
So my first question (in a probably very long series of questions) is where do I start?
P.S. I do have experience with electronics i.e. soldering wiring and the sort.
THANK YOU IN ADVANCE
I would really like to get this baby up and running it is in pretty good cosmetic condition due to the fact that it has been in the garage the whole time
Leo562 is offline   Reply With Quote
Old 01-17-2013, 07:50 PM   #2
ritetwist
ritetwist's Avatar
Oddometer: 177
Congratulations.Gotta be close to a record. 19 y.o. You gotta lot of guts,or desire, or both.
Read the manual while sitting by the bike,find everything the book talks about(no tools yet).
Stay in touch with forum and enjoy.Can you post pics? They're gonna ask!
Good luck.
I'm going to watch this one.
Afraid to sleep for fear of missing something.
ritetwist is offline   Reply With Quote
Old 01-17-2013, 07:57 PM   #3
Leo562 OP
Oddometer: 22
Thanks! That's what they tell me.
I'll take the advice and i'll keep in touch!
I'll post pictures when there is better lighting hopefully be up by saturday.
Old 01-17-2013, 08:02 PM   #4
DGW
Oddometer: 20
First thing get a new battery, drain the gas tank and the carbs, new gas, new spark plugs. It may just start up. If not chack back for the next step Good Luck
DGW is offline   Reply With Quote
Old 01-17-2013, 08:08 PM   #5
hardwaregrrl
ignore list
hardwaregrrl's Avatar
Oddometer: 7,418
First thing to do is change all fluids...then you've got to clean out the gas tank and the fuel valves. I'm certain the carbs will need a full clean, and rebuild.....but you could just clean out the jets in the mean time just to get the bike to start. Remove the spark plugs and clean them up, check gap, reinstall. Then get a battery....that's where I would start. Once you've got it running then you can fine tune.....check valve clearences, timing, bleed the brakes, clean and rebuild the carbs, then new tubes and tires and a super scrub down. Ride for a 100 miles, then change all fluids again.
Glad you found this place.....it's going to help you A LOT! Keep us in the loop.
Old 01-17-2013, 08:08 PM   #6
hoss18
hoss18's Avatar
Oddometer: 123
Good on you for trying... Im sure that you will get a lot of different advise on this forum, Remember that most of us are not "experts" just enthusists who enjoy what you are about to do. We can offer some advice but never forget in the end it is your call how far you go.
As far as your bike goes - it is a great one as your introduction to an airhead. Generally these are a solid simple bike and it may not need much to get going. If its cosmetically ok and it used to run before it was rested maybe all it needs is oil/filters/petrol/battery change - but go over all the rubber (including the tyres) bits as they tend to perish over time. Because of the length of time It might also be wise to check out if there is any corrosion in the carb float chamber before you start it.- you might have to have the carby serviced.
BMW - a love hate relationship
hoss18 is offline   Reply With Quote
Old 01-17-2013, 08:10 PM   #7
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,373
Please don't "restore" your Father's bike. Restoration is not for bikes in good original condition. The real beauty is in original machines, not restored machines. Stick around long enough and you'll understand this one.
You say this bike has not been started even for 18 years or more? Has it been covered? Or it has a lot of dust on her? It would be good if you can post some pictures of this bike. How many miles on the odometer? of course.
The first concern is probably is there gas in the tank? If there ever was it may be gone now. Could you remove the bottom float bowls of the carbs, push the bale wire to the side and the float bowl will drop. They may need a little encouragement if they are stuck. There is a cork gasket that may or may not fall apart. If it survives keep it in place. But if it falls apart don't worry you are going to get another one anyway. You want to check the float bowls for gum and varnish residue which will tell us if the bike was parked with gas in her.
Is there any liquid gas in the gas tank? If there was it may have been turned into varnish also. You are in luck the vintage bike you have is much easier to remove the tank than something more modern. Get in the habit of appreciating this fact. These bikes are built to be maintained by their owners. The fuel lines on an Airhead do not have clamps on them if the correct size fuel hose was used. If you twist the rubber hose it should be easy to pull it off. Open the seat and you will see two plastic knobbie things holding the tank on. Twist these off and with the rubber fuel lines off both sides the tank will lift off.
You can wash the tank with soap and water. you can rinse the inside out with a garden hose but you will probably have to soak the tank with a cleaner to get the dried gas varnish out. I think some have used Sea Foam for this.
There's going to be more, much more, before you are ready to start this bike. Take it slow, one step at a time. Read the manual. Which one is it? Is it the 1980's vintage manual with a rider dressed in blue on a Beemer with a large red fairing? What tools do you have in the kit? Might be a good idea to take a picture of the tools also.
I know I ask a lot of questions but these are questions that will help. At this point we would really like to know what you find when you look in the carb float bowls and in the gas tank. Was the bike stored wet or dry?
You have one of the most desirable of Airhead models and one of the most powerful too. What color is she?
---Albert Einstein
disston screwed with this post 01-17-2013 at 08:19 PM
disston is online now   Reply With Quote
Old 01-17-2013, 08:29 PM   #8
JonnyCash
turd polisher
Oddometer: 1,571
Thank you!
I wouldn't bring her home to Mama, but Mama ain't home tonight.
JonnyCash is online now   Reply With Quote
Old 01-17-2013, 08:44 PM   #9
Leo562 OP
Oddometer: 22
It is this one http://www.ebay.com/itm/CLYMER-SERVI...-/230620599855
Old 01-17-2013, 08:13 PM   #10
pommie john
pommie john's Avatar
Oddometer: 1,448
You're going to get lots of advice here, some of it conflicting
In your position, what I would do is:
1 Check there's oil on the dipstick
2 Take out the spark plugs, place the plugs in the caps with the metal body of the plug resting on the metal of the engine. This is important, you must earth the ground electrode of the plug or you can damage the ignition system.
3 Put on a fresh battery and push the button until the oil pressure light goes out.
Any sparks at the plugs while you push the starter? If so, the next thing I would do is drain the fuel, take off the float bowls and spray carb cleaner everywhere in the carbs. Put them back together, fresh fuel , fresh spark plugs, and see if it starts.
If it starts, well done! Before you run the engine any longer, give it fresh oil and filter.
There are plenty of other things to check before you take it on the road, but we can cover them later
The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt.
Bertrand Russell
pommie john is offline   Reply With Quote
Old 01-17-2013, 08:34 PM   #11
Houseoffubar
fine beer sampler
Houseoffubar's Avatar
Oddometer: 1,782
Where are you? Having an inmate drop by, and take a look would pay dividends, I would imagine.
Old 01-17-2013, 08:34 PM   #12
Kai Ju
Kai Ju's Avatar
Oddometer: 1,836
Where are you located ?
You might want to check and see if there are any fellow airheads living in your neck of the woods. It's a lot easier to pick things up when somebody shows/teaches you.
Second to that is reading the manual, several times.
Keep us in the loop and get some pictures up. Would love to see it.
Kai Ju is offline   Reply With Quote
Old 01-17-2013, 08:39 PM   #13
Leo562 OP
Oddometer: 22
Before I start I would like to thank you all for your replies these are very informative answers and I am shocked how fast you replied and glad to see your interest in my project.
I am finally surrounded by a community who understand why I would like to run this bike again!
Ok so I can not answer all of these questions immediately due to the fact that I have Finals soon... so I am studying but this saturday I will address all of your questions!! ASAP!
AND PROVIDE PICTURES LOTS OF THEM!!!
I can say that the rubber tubes are one of the first things that I saw that looked like they need some help.
I also have another question! Where do you trust to get parts for a motorcycle of this type? Do you prefer OEM parts or...?
And I live in California near LA just incase anyone was wondering!
THANKS AGAIN
EACH AND EVERY ONE OF YOU!
Old 01-18-2013, 04:49 AM   #14
some_guy
some_guy's Avatar
Oddometer: 144
http://www.maxbmwmotorcycles.com/fiche/PartsFiche.aspx
If its a nice clean bike I'd keep it original. If its already a bit trashed...make it your own.
some_guy is offline   Reply With Quote
Old 01-17-2013, 08:40 PM   #15
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,373
A bike that has been sitting for almost 20 years? I think it needs a little more attention to detail. Drain the engine oil before the engine is turned one bit. To do this first take out the fill plug before you take out the drain plug. It is debatable whether you want to put a new filter in at this point. I'm willing to say you can leave that for later. But I would want fresh oil in the sump from the first get go. After the engine has been run for ten mins this oil will be drained. and fresh put in again.
Do you live close to a BMW Motorcycle dealer that you may be using for parts? There are sources for many things that are cheaper but you will benefit from the nearness of a dealer if that is an option. Where do you live? It is a good idea to put this info in your profile. Let's get some of the basic info up front so we know how to tell you and what to tell you you will need to know.
---Albert Einstein
Times are GMT -7.   It's 06:06 PM.
