Old 01-19-2013, 04:41 PM   #1
WilliamSven OP
samobilemechanic.com
WilliamSven's Avatar
Oddometer: 24
Buying a good 1150 GS, The guy has a parts bike, what xtra parts should I ask for ?
He has a good running 2002 1150 GS and a parts 1150 GS that was a hurricane flood bike.
the running bike is pretty clean, they changed the beak out, it was broken.
The parts bike was a hurricane flood bike. The motor turns over. wiring is corroded as hell.
I was thinking of asking him for a few things.
these bikes are hard to find in Texas.
WilliamSven is offline   Reply With Quote
Old 01-19-2013, 04:47 PM   #2
everycredit
everycredit's Avatar
Oddometer: 272
I could always use a right sided cylinder head (not the cover, the actual head).
Other than that, engine parts, electronics (if not shot), body parts, wheels.
everycredit is offline   Reply With Quote
Old 01-19-2013, 05:51 PM   #3
WilliamSven OP
Oddometer: 24
I saw the right heads sell on ebay, ( one sold for $300 n change + ship ) is that because they get less than the left head on kickstand warm up idle ? these are not like the OLD old Old bmws that you CANT idle on the kickstand, are they?
what would you offer on the right head? I can ask him to throw it in as part of the bigger deal.
how many hours is it for me to pull the head ya figure? im a mechanic. www.samobilemechanic.com
Old 01-19-2013, 08:07 PM   #4
everycredit
Oddometer: 272
No, friend offered to adjust my valves and overtorqued the cylinder head cover screw (two of them, actually). One broke and cannot extract. I think it would be simpler just to replace the head instead of getting it fixed by a shop (if any shop will redo a screw hole (lol)).
Old 01-19-2013, 07:45 PM   #5
def
Ginger th wonder dog
def's Avatar
Oddometer: 10,581
the running bike is pretty clean, vintage glood bike?they cha glood bike?nged the beak out, it was broken.
What vintsge?
def is offline   Reply With Quote
Old 01-19-2013, 08:08 PM   #6
kellymac530
motorcycle addict
kellymac530's Avatar
Oddometer: 1,052
All of them
it is easier to ask for forgiveness than permission
kellymac530 is offline   Reply With Quote
Old 01-19-2013, 09:03 PM   #7
WilliamSven OP
Oddometer: 24
Originally Posted by kellymac530 View Post
All of them
hhmm.. perhaps it is better just to hold em. walk away. The one hes selling does have high miles. but its the cheapest one ive found locally.
mayhap ill just pimp my trans alps suspension out.. it is one of the most reliable bikes ever made, if not the most reliable bike ever made.
Old 01-20-2013, 05:49 AM   #8
Jim Moore
Jim Moore's Avatar
Oddometer: 14,180
How many miles on the bike? How many miles on the parts bike?
Jim Moore
Jax, FL
Pay the lady, PirateJohn, you thieving piece of garbage.
http://advrider.com/forums/showthread.php?t=949341
Jim Moore is offline   Reply With Quote
Old 01-20-2013, 06:06 AM   #9
Dan Alexander
Ride Far - Ride Fast
Dan Alexander's Avatar
Oddometer: 7,654
Get it cheap enough and you can sell of parts and make a good return and lower the actual purchase price of the first bike.
Beemers Past and Present: 74 R90S, 77 R100RS, 85 K100RS, 2x 87 K100RS, 96 R1100GS (getting hacked), 99 R1100S, 2002 R1150GS, 2005 F650 Dakar, 81 GL500/Velorex
Plus the occasional Triumph, BSA, Yamaha, Honda, Suzuki and KTM but who's counting
Dan Alexander is offline   Reply With Quote
Old 01-20-2013, 03:33 PM   #10
WilliamSven OP
Oddometer: 24
90K on the bike for sale. I think ill end up getting it for $3700 if I actually get it.
20? k on the flood bike with the corroded wiring harness and ecm.
Old 01-20-2013, 09:17 PM   #11
DRONE
Dog Chauffeur
DRONE's Avatar
Oddometer: 4,025
I'd fer sure want the final drive. If the for sale bike still has the original crown gear set, then the FD prolly doesn't have alot of life left.
Swingarm with driveshaft too. Same reason.
Shocks? Did the salt water wreck 'em?
And wheels. If the wheels are OK they are worth money. Maybe $600 if not corroded by the salt water.
WUMPA
Sidecardogs.com
DRONE is offline   Reply With Quote
Old 02-18-2013, 04:03 PM   #12
WilliamSven OP
Oddometer: 24
The wheels, actually its come to me I should keep them so when we have our support trailer in big bend / Utah / etc.. I can bring a second wheel set with knobbies and ride there, then swap wheels for the off roady fun.
Put about 1800 miles on the 90k GS1150 so far. zero oil loss ( the seller said its normal to check the oil and they use it sometimes .. ice noticed 0 loss. )
its SMOOTH . .
im thinking about the Jesse Luggage now. in matching black of course.
Old 02-18-2013, 09:37 PM   #13
bone13
bone13's Avatar
Oddometer: 282
+1 on the final drive
It may or may not be any good having been flooded, but I would get the TPS. Actually it might be a good idea to get both the throttle bodies too. With 90k on the running bike unless the throttle bodies have been rebuilt, they'll likely need it or will very soon.
The ABS unit isn't bad thing to have around either as If the ABS servo fails, it's about $2300 (for the part) to replace.
On the 2001.5 - 2005 units when ABS unit fails you have next to no brakes at all, vs the pre 2001.5 which you just have no ABS if the ABS unit fails.
The Trouble with Trouble is it usually starts with Fun
www.ridgerunneradventures.com
bone13 is offline   Reply With Quote
Times are GMT -7.   It's 11:22 PM.
