Old 01-21-2013, 04:29 PM   #1
kellymac530 OP
motorcycle addict
kellymac530's Avatar
Oddometer: 1,052
Frame material?
I am curious if anyone knows what grade of aluminum BMW uses on the front upper frame section?
Most Asian dirt bikes use 6061 T6...but this is BMW....
it is easier to ask for forgiveness than permission
kellymac530 is offline   Reply With Quote
Old 01-22-2013, 04:45 AM   #2
everycredit
everycredit's Avatar
Oddometer: 272
It's not aluminum; it's unobtanium.
everycredit is offline   Reply With Quote
Old 01-22-2013, 08:05 AM   #3
Lensgrinder
Oddometer: 1,317
No wonder they always like to tip over, they're trying to drill to the Earth's core.
I was just out looking at mine and it looks like it's made of the same steel as the rest of the frame.
Maybe I'm not looking at the same thing as OP.
2012 R1200GSA
2009 F650GS (Wife's)
1987 Husqvarna WR 430
Lensgrinder screwed with this post 01-22-2013 at 08:19 AM
Lensgrinder is offline   Reply With Quote
Old 01-22-2013, 06:32 AM   #4
mouthfulloflake
Not afraid
mouthfulloflake's Avatar
Oddometer: 16,720
It also looks like a cast part to me.
Tilt your head, not the taco. - Pati Jinich
Charter member: T.O. club.
mouthfulloflake is offline   Reply With Quote
Old 01-22-2013, 10:01 AM   #5
kellymac530 OP
motorcycle addict
Oddometer: 1,052
This piece:
http://www.ascycles.com/Illustrated_...indCat=46_0304
It is definately cast aluminum...that I know, I am curious if it is 6061 or 50 series 40 series...or what. Also is it heat treated?
Just to clarify why, I am welding a 1998 Honda CR 125 R steering neck to that front upper frame and putting inverted forks on it. I am doing it similar to Fabrice's build {Fab418} so I just want to pick the right rod to weld with and then have it all heat treated...but 50 series aluminum is not heat treatable. The CR neck is 6061-T6 heat treated aluminum from what I have found...just need to know.
kellymac530 screwed with this post 01-22-2013 at 02:12 PM
Old 01-22-2013, 10:30 AM   #6
Desert Skies
One brick shy...
Desert Skies's Avatar
Oddometer: 2,344
Me thinks you be in da wrong forum.
“Sorry I'm late, feck'n off takes a lot of time.”
" The 'Wing is my wife's bike - I'm just the feck'n driver." - USMCG_Spyder
" This post is full of VonBadenisms." - Gordy
Tripn' with Tom Some pictures ZZ Rider - Tom Lowry Texas Blue - Tom Lowry
Desert Skies is offline   Reply With Quote
Old 01-22-2013, 10:36 AM   #7
kellymac530 OP
motorcycle addict
Oddometer: 1,052
Why?
That is the same steering neck/upper frame as a GS. The part number is the same as the RT. I know the bike will be in Some Assembly Resquired....but this is specifically an OILHEAD question.
Old 01-22-2013, 01:23 PM   #8
krellheat
Pepsi Challenged
krellheat's Avatar
Oddometer: 2,106
Someone did this conversion on advrider before. I'll post the link when found.
Just remember, once you're over the hill, you begin to pick up speed.
Devil's advocate. Hell conscientious and informed and downright argumentative dissenter.
krellheat is offline   Reply With Quote
Old 01-22-2013, 02:10 PM   #9
kellymac530 OP
motorcycle addict
Oddometer: 1,052
Fabrice did it.
http://www.advrider.com/forums/showthread.php?t=711018
Times are GMT -7.   It's 02:11 AM.
