Old 01-28-2013, 09:06 AM   #1
Beater OP
Dirty
Beater's Avatar
Oddometer: 3,198
OIl Pan and Oil Filter Installation Theories
Tell me how you put these gaskets on. I have replaced many in my short carrier, and every frickin' one of them leaks. Most just a drip here and there ... but the neurosis has finally kicked in, and if I see another drip, I'm going ballistic. Seriously.
The Dobber has always leaked a bit ... but after this latest gasket change, it's a large drip. Constant, and like 5mL / day. It needs to STOP.
The requisite picture:
Fred
'85 R80RT G/Sified <|> '91 R100GS Bumblebee (103K miles and climbing) <|> '73 R75/5 LWB
Airhead Zen: Ride - Repair - Ride - Maintain - Ride - Repeat
Beater is offline   Reply With Quote
Old 01-28-2013, 09:43 AM   #2
craydds
craydds's Avatar
Oddometer: 1,156
Are you asking about the oil pan, oil filter cover, or both?
1. Oil filter cover. http://bmwmotorcycletech.info/Oil.htm , and http://www.largiader.com/tech/filters/ .
measure this:
and this:
It is the white o-ring that seals and prevents leaks. I have no leaks on my bike. I do not use a gasket on the cover, some do, and this is addressed in Anton's article:
cover on, new white o-ring, correct thickness of o-ring and metal "shim" for the depth of oil filter canister equals no leaks:
2. Oil pan. Here is a fairly straight forward oil pan and gasket installation - http://bmwmotorcycletech.info/pangasket.htm
ABC #12947
'75 R90S
craydds screwed with this post 01-28-2013 at 10:59 AM Reason: oil
craydds is offline   Reply With Quote
Old 01-28-2013, 09:45 AM   #3
ozmoses
Ride On
ozmoses's Avatar
Oddometer: 3,312
I lightly grease the sump gasket, both sides.
Cray- where did you come by that measuring stick, it's perfect ( & dead simple) for this?!
Opinions are like internet connections- everybody has one.
ozmoses is offline   Reply With Quote
Old 01-28-2013, 09:58 AM   #4
craydds
craydds's Avatar
Oddometer: 1,156
I can't remember; I have had that thing forever (possibly a Sears Craftsman thing?). I use it all the time, it is stone axe simple, kind of like my brain.
ABC #12947
'75 R90S
craydds screwed with this post 01-28-2013 at 10:05 AM Reason: sears
Old 01-28-2013, 11:08 AM   #5
some_guy
some_guy's Avatar
Oddometer: 144
My oil pan gasket was weeping. No drips, but the pan kept getting oily a couple weeks after a wash. Pretty much all of the bolts had loosened to just more than finger tight. I'm going to start checking these more often.
some_guy is offline   Reply With Quote
Old 01-28-2013, 11:35 AM   #6
ME 109
ME 109's Avatar
Oddometer: 2,568
First thing would be to thoroughly check both surfaces (sump) for any scratches/gouges etc.
Second, I would check the sump cover for warp.
My sump weeps, sometime in the not too distant future I'll take my own advice.
Lord of the Bings, kangaroo farmer
ME 109 is online now   Reply With Quote
Old 01-28-2013, 08:49 PM   #7
supershaft
Oddometer: 9,110
Well, just to prove that I do sometimes agree with the bum. No sealant, oil or grease. Clean! Stock gasket. And now the Bum and I part. My advise is to buy and use an inch pound clicker torque wrench. Good with guessing torque? With bolts inches apart on top of such a thick gasket. No on is that good. 75inpd??? Not nearly tight enough! 100inpds. Around and around until they ALL click at the same time. Ride it just once or twice and re-torque. Re-torque them once or twice a year. You will find that there are at least a couple of bolts that need it! I have good luck with this method. My bikes have literally gone for decades thusly and not even weeped!
Old 01-28-2013, 09:39 PM   #8
DoktorT
BigBrowedNeandereer
DoktorT's Avatar
Oddometer: 1,143
For sure, if you just don't have the feel from daily experience, you should use a torque wrench. It will save you money. But lots of people do develop a good feel and simply do not need it for all but a very few critical fasteners on the Airheads.
DoktorT is offline   Reply With Quote
Old 01-29-2013, 03:26 AM   #9
Paul_Rochdale
Paul_Rochdale's Avatar
Oddometer: 150
Here we go again
Paul_Rochdale is offline   Reply With Quote
Old 01-29-2013, 03:36 AM   #10
georgesgiralt
Oddometer: 102
Ray,
Could you please tell me what is the device bolted into your filter housing cover and what's it's use ?
Thanks.
To the others, gluing the O-ring and shim with grease on the cover is an easy way to get the things done properly and not leaking...
georgesgiralt is offline   Reply With Quote
Old 01-29-2013, 06:57 AM   #11
craydds
craydds's Avatar
Oddometer: 1,156
Originally Posted by georgesgiralt View Post
Ray, Could you please tell me what is the device bolted into your filter housing cover and what's it's use ?
It is a temperature sending unit that came with my Acewell, it can be used for water or oil temp. There are two temp readouts on the Acewell, one for ambient air temp, the other for oil (or water) temp. A few more details starting in post #393 here - http://www.advrider.com/forums/showt...527749&page=27 .
ABC #12947
'75 R90S
Old 01-29-2013, 07:57 AM   #12
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 7,464
Oh noes, Paul...
I'm with HWG on this-- a faint coat of silcone sealant both sides. Belt-and-suspenders-- may not be absolutely necessary, but it doesn't hurt. And the silly-cone serves as a release compound-- the old gasket peels off with no scraping or cussing.
Tighten the oilpan bolts with a short 3" 'palm ratchet', tighten x-pattern starting in the middle and working outwards. Recheck after a couple of heating-cooling cycles.
Of courser, YMMV. Ride safe and keep the shiny side up.
--Bill
'73 R60/5 Toaster
Old 01-29-2013, 11:19 AM   #13
DoktorT
BigBrowedNeandereer
DoktorT's Avatar
Oddometer: 1,143
I decided to put the 81 on pan on my earlier RS. New pan, new gasket, clean and dry. After setting the bolts after a few rides, all seemed OK but within a few weeks I could see it was weeping more than it should.
Next maintenance inspection I pulled the pan. Flange looked fine and proved dead flat, but you could see the image of the final finishing process. I hit the flange with some 400grit and a palm sander. It now was flat matte homogenouse. Put it back on dry. Issue resolved. No weeping at all.
Next time you have the pan off, just go ahead and do treat the surface to insure a perfect seal.
Then let the engine drip overnight or several hours and mop it all up around the lower flange. Now take a flat file and just stroke it around the perimeter enough to see if highlights appear around any stressed holes. Proof positive of over tightening at some times in the past. Takes nothing but the right sized piece of wood and abrasive to make that a perfect surface again as well.
Refining these details is what is meant by enhanced specifications. You spend the extra time to make things better than the factory specs could. You tend to get overall better results than stock in this way.
Rare is the mechanic that will demand from his client the extra 20 minutes or so to do this better work for such as a leaky pan gasket replacement. My clients always knew it they wanted cheaper, it was available everywhere. They came to me because I resolved long standing problems with techniques as simple as abrasives and time, efficient and effective with skill. Now his garage baby doesn't drip anymore.
Refined results can only come from refined procedures. If you can do these things yourself, you can make the machine better in many ways as you do your scheduled maintenance and repairs.
Old 01-29-2013, 11:44 AM   #14
craydds
craydds's Avatar
Oddometer: 1,156
++1 !!! Methinks it rare to find anyone that will take the extra time to do a little extra work to make it RIGHT. I will re-do something if necessary until it is RIGHT ON.
ABC #12947
'75 R90S
Old 01-29-2013, 07:12 PM   #15
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,465
Don't get me wrong, I don't plan to cover it in crud and leave it. I wash off loose dirt and grime, but I don't get too anal about polishing every nook and cranny - not as some kind of proof that it gets ridden, more that I just don't have the time. I fully agree with what you're getting at though.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Times are GMT -7.   It's 03:41 AM.
