Old 02-09-2013, 05:32 AM   #1
schattat OP
schattat's Avatar
Oddometer: 1,325
Tuareg Rallye 2013 - The Next Adventure
Hi gang,
It's been a while since my last big adventure in Abu Dhabi in 2010. Since then I have completed my school studies, got into university and setup and expanded my RNS business for TripMasters and CompassRepeaters as many of you are aware of. Due to having so much going on I haven't had the time to actually race much. There was also the incident when my bike was knicked in July after a trail ride through France. Fortunately, the coppers were able to retreve the bike miraculously without any damage whatsoever (apart from worn down tires).
Anyway back on topic, this thread is about my preparation towards the Tuareg rallye in March. The event as many of you are familiar with was always held in Morocco in the past bu has since moved to Tunisia for the first time this year. The start will take palce in Douz, an Oasis in the very south pretty much bordering the Sahara desert. I will be joined by some good friends, Edward Taylor and Guillaume Martens (2nd in the Africa Race). There will of course be many ADVers joing including LukasM, GSNorCal, Neduro just to name a few. Yet again, I will be using my trusty WR450F and here is the build up that many of you fancy so much :
To start with, the bike is torn down to a nacked frame, which is repainted (matt blue):
Instead of designing my nav tower like in the past, I have opted to use a finished one from a KTM rallye, thanks to the help of the factory mechanics for helping me source some of the parts:
The nice thing about the setup is that it's wide, which allows one to mount more crap on to
The frame support is the same as in the past, but needs to be modified to accomodate the KTM forged supports (very nicely made):
I lathed some spacers so the 2 stainless steel mounts wouldn't be pressed together under the tension of the 2 screws:
The nice forged parts have spaces for the hex nuts instead of having a thread inside themselves, clever!
Post tower for the steering damper before the triple clamps are installed:
Rare to get hold of, original Yamaha factory rear hub with a cushion drive, less strain on the gear box:
Nice bling, 49T stealth sprocket:
RNS - Rallye Navigation Solutions
Yamaha WR450F Rallye Spec
schattat screwed with this post 02-17-2013 at 11:34 AM
schattat is offline   Reply With Quote
Old 02-09-2013, 05:38 AM   #2
schattat OP
schattat's Avatar
Oddometer: 1,325
Next custom mod on the list was something unique. I always liked the KTM footpegs on the rallye replicas, not too wide, but very long. Very nice with my size 47/12 boots:
A comparison, custom vs. stock:
I wasn't sure whether they would fit (why would they really?), but judging from many pictures I came to the conclusion that the folding angle of about 45° and the width to fit on to the frame were pretty similar to the stock WR pegs:
How right I was Even the 10mm bolt from the KTM fits perfectly, both in diameter and length!
First hold up was the width for the mount. KTM pegs width was 30mm, the space in the frame was 29mm (odd uneven number, not very Japanese-like):
Not to worry, just grind down a bit on the pegs on each side and they slip in perfectly:
I found the angle to which the pegs were tilted to the back to be too much, so I grinded more on the bottom of the pegs where they hit the frame:
schattat screwed with this post 02-17-2013 at 11:35 AM
Old 02-09-2013, 09:07 AM   #3
LukasM
Oddometer: 4,909
Proud member of the HUSABERG ADVENTURE TEAM!
'12 Husaberg FE570, 09 KTM XC-F/ 450 RFS hybrid, 07 KTM 450 SMR, 08+09 BMW F650GS twins/F800GS conversion, 03+05 YZF-R6
Old 02-09-2013, 09:55 AM   #4
Muecke
Muecke's Avatar
Oddometer: 31
nice tony so there ist One more reason to visit you in short time . bye muecke
Muecke is offline   Reply With Quote
Old 02-09-2013, 12:23 PM   #5
tehdutchie
tehdutchie's Avatar
Oddometer: 1,352
Goed bezig!
=> http://www.eatdirt.nl/blog <=
tehdutchie is online now   Reply With Quote
Old 02-09-2013, 01:52 PM   #6
doyle
RallyRaidReview-ing
doyle's Avatar
Oddometer: 21,520
Looks good.
Got Smugmug? Use code HWkDUhHwGv5Tc for a discount.
RallyRaidReview - @RallyRaidReview
doyle is offline   Reply With Quote
Old 02-09-2013, 01:55 PM   #7
Hayduke
///SAFETY THIRD///
Hayduke's Avatar
Oddometer: 41,608
Hayduke is offline   Reply With Quote
Old 02-09-2013, 09:35 PM   #8
K_N_Fodder
Weekend Warrior
K_N_Fodder's Avatar
Oddometer: 812
Hmmmm Tuareg F5?? :)
K_N_Fodder is offline   Reply With Quote
Old 02-10-2013, 04:03 AM   #9
schattat OP
schattat's Avatar
Oddometer: 1,325
Next step was to fabricate the new stabiliser bars between the two nav tower plates. I couldn't use the ones out of the KTM catalogue since the spacing between the plates was a little smaller than stock, but no problem lathing them quickly:
Same goes for the rubber mounts for the roadbook support plate, had to get different height model and place washers to fit them correctly:
Good fit now (450RR plate):
Added control lights:
As for headlights, I had a look around and finally came around to getting some LEDs ones. I chose the one sold my ADVmonster, very nice units and SUPER bright. Had to fabricate some spacers tohave the correctly fit the width to fit the fairing later:
First fitting attempt:
Final fit:
Let there be light:
Excuse the messy table:
One problem that did occur with the forged alloy parts from KTm was the steering angle was to large. Instead of the bottom of the triple clamps stopping he turning angle by hitting the stopper on the frame, the forks would do the job. Here you can see the space missing when the forks touched the forged parts:
I solved this by drilling holes into the stoppers on the bottom clamps and fitting some screws inside, therefore limiting the steering angle a tad. Similar principle to what many bikes have to adjust the steering angle. Unfortunately these Japanese MX derived bikes don't have that. Pics to follow!
Old 02-10-2013, 04:10 AM   #10
schattat OP
schattat's Avatar
Oddometer: 1,325
Here some additional parts installed.
Öhlins rear shock with harder spring rate, borrowed from dad for the event:
Clutch cover protection (the walls are very thin). Just to be on the safe side:
Tall bar risers:
ProGrip 786 rallye grips:
Motomaster 270mm disc adapter. With some careful geometry I drilled and tapped two M8 holes to fit the sensors of the TripMaster:
Front mounts to fit the bash plate (original Yamaha rallye kit parts). Again, borrowed from dad. I was planning on designing and fabricating my own one. The space between these two parts is big enough to make a compartment. Lack of time means I will have to do it sometime later:
Old 02-10-2013, 05:06 AM   #11
Deadly99
Fast and Far
Deadly99's Avatar
Oddometer: 6,824
Looking good
www.GravelTravel.ca Canadas Source For Overland Routes
Tales From The Bivouac Rally Print Publications
TCAT Trans Canadian Adventure Trail 15, 000 km GPS route across Canada
Deadly99 is online now   Reply With Quote
Old 02-11-2013, 08:52 AM   #12
640 Armageddon
640 Armageddon's Avatar
Oddometer: 438
Subscribed
Tony, a word of caution with the lights, I have used the lights from ADVmonster as well, they are indeed very bright and the setup was similar.
Having used the normal light supports first, they cracked on my first ride. I know the 640 vibrates a lot more than the Yamaha but better safe than sorry. John from ADVmonster sells also heavy duty supports but they are easy to manufacture from 2mm SS plates ...
Looking very good and the KTM tower looks
D.
Work like you don't need the money
Live like there's no tomorrow ...
640 Armageddon is online now   Reply With Quote
Old 02-12-2013, 03:04 PM   #13
Muecke
Muecke's Avatar
Oddometer: 31
Originally Posted by 640 Armageddon View Post
Subscribed
D.
can you give me a link where to see technical data of the light and where to buy?
Old 02-12-2013, 11:05 PM   #14
640 Armageddon
Oddometer: 438
http://stores.intuitwebsites.com/hst...StoreFront.bok
Vendors thread
http://www.advrider.com/forums/showthread.php?t=607184
D.
Old 02-11-2013, 09:19 AM   #15
Brodovitch
Team ⌘R
Brodovitch's Avatar
Oddometer: 3,161
Have to agree with Dimitri on the light supports, the Raid Designs have a similar design (might even be identical), and a friend's cracked in the 24H race a couple of months ago...
TALES FROM THE BIVOUAC
TWOONEZERO
Brodovitch is offline   Reply With Quote
Times are GMT -7.   It's 11:40 AM.
