Old 02-15-2013, 04:11 PM   #1
Deepc OP
Oddometer: 299
9 month old shorai needs a charge. Help...
05.5 950A won't start. I just installed the $$$ Shorai 9 months ago. No problems until now. I have a shcumacher charger. Any charging tips?
Deepc screwed with this post 02-15-2013 at 05:29 PM
Deepc is offline   Reply With Quote
Old 02-15-2013, 04:35 PM   #2
DuctTape
Oddometer: 351
Read this http://www.batterystuff.com/blog/can...y-shorai-.html you really should buy their charger since it is a charger/tender and reduces the oops factor.
2013 KTM 690 (Thanks FLHRCI Buyer! )
2011 990 Adventure Dakar (Thank you Honey!)
2010 Aprilia RSV4 Factory
2010 Ducati 1198S
DuctTape is offline   Reply With Quote
Old 02-15-2013, 04:54 PM   #3
Deepc OP
Oddometer: 299
Yes. If I could afford the shorai charger I would use it, but right now I'm stuck with a schumacher ship/shore speed charger. My choices are 2A trickle, 10A medium, and 15A Deep. Also, have a option for standard, agm, or gel cell.
Deepc screwed with this post 02-15-2013 at 05:32 PM
Old 02-15-2013, 05:05 PM   #4
DuctTape
Oddometer: 351
If it was my battery I'd contact Shorai about using that charger,
2010 Ducati 1198S
Old 02-15-2013, 05:26 PM   #5
Deepc OP
Oddometer: 299
I hear you about contacting the manufacturer but I'm kind of in a "Spot." I know some guys have had some luck charging these things on a standard charger. I've set it to a 2A trickle on the standard setting. This battery had been great until yesterday.I have heated grips on the switched circuit so that shouldn't be a problem.
Old 02-15-2013, 05:34 PM   #6
PhiSig1071
What's ******width?
PhiSig1071's Avatar
Oddometer: 2,439
If your bikes charging system can charge the battery, then any standard charger should be able too as well. However, The Shorai specific charger is better, because it's supposed to charge the battery cells evenly. One big thing I did notice about the Shorai I put in my KTM, it says if it's low on a charge, that you should charge it first, before trying to start a bike, apparently you can damage the battery if you try to start it with a dead battery.
I have a Shorai charger, if you were closer I'd let you barrow it. Or you can send me the battery, and I'll hook it up and send it back when it's done.
Which one of you FF's was it?...FOUNDER!
Entia non sunt multiplicanda praeter necessitatem
PhiSig1071 is online now   Reply With Quote
Old 02-15-2013, 06:41 PM   #7
sstewart
sstewart's Avatar
Oddometer: 1,056
Shorai
I ruined mine by trying to start when weak.
sstewart is offline   Reply With Quote
Old 02-15-2013, 05:34 PM   #8
Dogtown
Dogtown's Avatar
Oddometer: 410
shorai
I'm on my 2nd.....I keep mine on a trickle charger/battery tender. Lots of guys that I respect on here love this batt but its the last one i will own. Just dont trust um 100%. Originally Shorai said the standard batt tender was fine but some guys on here say NO and if your running your big ktm with accesories the battery will not full charge while riding.
No Bueno!
Cheers and good luck
OH 7 990
Marin County To Cabo!
Dogtown is offline   Reply With Quote
Old 02-15-2013, 06:07 PM   #9
DuctTape
Oddometer: 351
No Bueno!
I run the Shorai in both my Ducati and Aprilia but not my 990 that ends up a long way from home and tow trucks, LOL.
2010 Ducati 1198S
Old 02-15-2013, 10:08 PM   #10
_cy_
Oddometer: 6,191
good call ... only LiFePO4 batteries I can recommend for 990 adventure are Shorai LFX36 and Earth-X ETX36. there's a huge difference between bikes that only make short trips from home base vs a bike that get ridden in the middle of no where, sometimes camping out in cold weather.
_cy_ is online now   Reply With Quote
Old 05-31-2014, 03:00 AM   #11
korkin25
Oddometer: 13
Pissed
I own Shorai Power LFX18A1-BS12 since Aug 2013.
Today.... on the way from Pamir (Tajikistan to Moscow) that battery begin to show 3.45V...
I will never use/buy it anymore...
I am anoight...
korkin25 is offline   Reply With Quote
Old 05-31-2014, 08:34 AM   #12
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,245
I was under the impression that these things were so wonderful - and so expensive - because you never have to charge them and they are so light.
That does not seem to be the case.
Chuckracer is offline   Reply With Quote
Old 02-15-2013, 06:39 PM   #13
_cy_
Oddometer: 6,191
No Bueno!
that depends on which battery tender ... what's critical is does battery tender terminate current after full charge is reached?
some battery tender will deliver a slow charge for long as charger is plugged in.
only use exact model and brand tender mfg recommends.
my recommendations is not to use a tender, unless your parasitic drain is higher than normal.
some tenders charge so slow, it could take several days to reach full charge. use a normal dumb automotive charger to charge your LiFePO4 batteries. then monitor voltage (14.6v max) and don't allow charger to remain on battery past overnight.
most LiFePO4 cell mfg (not battery mfg) will recommend a .5C to 1C charge rate during bulk stage. example: Shorai LFX 21 actual = 6 amp hour ... so 3A - 6A charge rate is preferred during bulk stage of charge. some battery tenders charge at 150-500 milliamps
Old 02-15-2013, 05:40 PM   #14
FakeName
Wile E Coyote SuperGenius
FakeName's Avatar
Oddometer: 1,799
I have successfully used a standard auto charger on mine.
I wouldn't do it all the time, but sometimes, a guy leaves the grips on .
2011 White 990 Adv S
2014 500EXC Black
FakeName is offline   Reply With Quote
Old 02-15-2013, 05:44 PM   #15
_cy_
Oddometer: 6,191
which Shorai do you have installed in 950?
the short answer is yes you can charge Shorai batteries with most any automotive charger without conditioning mode. which will go up to about 15.5v, would not be good for LiFePO4 batteries.
LiFePO4 batteries for motorcycle are fully charged at 14.6v .. your Schumacher charger should charge at peak 14.3v or so... so long as your auto charger stays below 14.6v, you should be fine. bulk part of charge is not critical .. As your LiFePO4 battery charges up, current will naturally slow down. using a dumb charger without float mode requires you monitor charge levels to prevent overcharge.
in other words, measure your auto charger to make sure peak voltage doesn't exceed 14.6v and don't leave your charger attached longer than overnight.
it's my experience some Shorai have internal BMS, some don't. all have external balance ports ... Shorai batteries should be balance charged from time to time with a charger with balance leads.
see my LiFePO4 battery testing thread for LOTS more details .. link in sig..
Shorai LFX 21 being balanced charged with Powerlab 8 (note balance cables in center)
_cy_ screwed with this post 02-15-2013 at 06:03 PM
Times are GMT -7.   It's 12:55 PM.
