Old 02-16-2013, 01:10 PM   #1
Izzy3 OP
Freak of Unnature
Izzy3's Avatar
Oddometer: 165
Is the BMW LED Canbus brake light worth the $?
I like easy so plug and play means a lot to me. Looking for a little more "hey I'm braking up here on I-95" and want an easy to install, but effective alert to the butt riding tools on I-95.
Is the BMW part work the extra coin compared to a Hyperlite or other application? I don't want Canbus issues or soldering work.
Thanks.
'12 R1200 GSA
Izzy3 is offline   Reply With Quote
Old 02-16-2013, 01:23 PM   #2
jdub
Dawg bytes reel gud
jdub's Avatar
Oddometer: 1,825
Doesn't your '12 already have an LED tail/brake light? I thought those started as standard equipment in 2008.
Current: 2014 R1200GSW
jdub is offline   Reply With Quote
Old 02-16-2013, 01:39 PM   #3
Izzy3 OP
Freak of Unnature
Izzy3's Avatar
Oddometer: 165
I want more visibility and and the "I'm braking flash feature" in the aftermarket systems.
'12 R1200 GSA
Old 02-16-2013, 04:22 PM   #4
JetSpeed
Naviator
JetSpeed's Avatar
Oddometer: 3,286
The BMW LED tail lamp assembly is the same exact unit that you already have on your bike (assuming its a 2012 model) the kit is designed for the 4-07 models..
Pull chocks.
JetSpeed is offline   Reply With Quote
Old 02-17-2013, 04:54 PM   #5
Izzy3 OP
Freak of Unnature
Izzy3's Avatar
Oddometer: 165
The catalog lists it as an additional tail lamp which fixes at the bottom of the the license plate frame. My current tail light (OEM) doesn't flash, is above the license plate and is smallish to say the least.
WTF?
'12 R1200 GSA
Old 02-18-2013, 08:18 AM   #6
JetSpeed
Naviator
JetSpeed's Avatar
Oddometer: 3,286
WTF?
You're talking about the "Supplemental Brake Light".
At $170 with the wire harness its pricey, but works great.
As for an additional "supplemental" brake light there are dozens of other options and you need not worry about the CANBUS as it's a load sensor withing the ZFE that triggers the LAMP Out error and that is already set to LED on 2008 and newer models.
Pull chocks.
Old 02-16-2013, 01:26 PM   #7
LaurelPerryOnLand
Oddometer: 3,478
Thanks.
1. No. Not for my money.
2. Hyperlites 16 LED version will provide PLENTY of reward visibility without CANBUS issues or a trip to the BMW dealer to have a "software change to LED". Just get the Hyperlites and be done with it.
3. Soldering isn't rocket science....learn it...you'll have a new capability that can/will serve you well.
http://www.hyperlites.com/moddf.html
LaurelPerryOnLand is offline   Reply With Quote
Old 02-16-2013, 01:42 PM   #8
Izzy3 OP
Freak of Unnature
Izzy3's Avatar
Oddometer: 165
I can solder, I just don't want to crack into the wiring if I don't need to do so. I was not aware of a trip to the BMW dealer because I added a BMW LED tailite.
'12 R1200 GSA
Old 02-16-2013, 02:18 PM   #9
lkchris
Albuquerque
lkchris's Avatar
Oddometer: 1,019
The BMW light comes with ZERO for instructions.
I think you can find how to install one on the MOA website somewhere.
The BMW light is on always as a taillight and when you first hit the brake it flashes very quickly for maybe two flashes and then is constant and a little brighter than normal. It's almost as if it flickers. It's not a big show for sure.
No, the R1200RT has never had an LED taillight.
Kent Christensen
Albuquerque
'12 R1200RT, '02 R1100S, '84 R80G/S
lkchris is offline   Reply With Quote
Old 02-16-2013, 03:10 PM   #10
GB
Mod Squad
GB's Avatar
Oddometer: 56,538
A more effective brake / running like would be the P3 lights, easy install, and much brighter than the bmw light:
www.skenedesign.com
Old 02-18-2013, 04:57 AM   #11
Hikertrash
Oddometer: 2,866
www.skenedesign.com
+1
They're much brighter than the hyperlites and don't require soldering.
Hikertrash is offline   Reply With Quote
Old 02-18-2013, 08:41 AM   #12
gspdbill
noobie allover again
Oddometer: 404
Thanks for this info, just ordered the 16's last night, make sure they send you your commission check...
I've had various HyperLight setups on my bikes for the last 10+ yrs., never had an issue with them. This will be the first CANBus install though.
Bill
'05 R1200GS for now......
gspdbill is offline   Reply With Quote
Old 02-16-2013, 04:35 PM   #13
Steiney
Oddometer: 80
I have the Skeen P3 LED's on the rear - highly visible during riding and braking. What appealed to me is the way they oscillate, they really grab your attention...
Sent from my DROID RAZR using Tapatalk 2
Steiney
2012 GSA
Steiney is offline   Reply With Quote
Old 02-16-2013, 04:42 PM   #14
TuefelHunden
TuefelHunden's Avatar
Oddometer: 591
http://www.twistedthrottle.com/admor...ls-smoke-10018
I have one of these. It works. No Can-Bus issues. It is very bright. 30 minute install.
If you want an omelet, you have to break some eggs. Using posi-taps to connect electrical bits is so easy a 6 year old could do it.
Old, but not Dead
TuefelHunden is offline   Reply With Quote
Old 02-16-2013, 05:09 PM   #15
SR1
Back in S. Korea
SR1's Avatar
Oddometer: 4,412
Ain't that the truth. But the OP prizes convenience over money, so let him go.
Me, I'm an egg breaker. (and I am hoping that the OP looks around and sees that most GS owners are "egg breakers" and learns how to do it himself too)
My TAT trip in 2014: http://advrider.com/forums/showthread.php?t=998193
SR1 is online now   Reply With Quote
Times are GMT -7.   It's 03:36 AM.
