Old 02-20-2013, 06:24 PM   #1
DGW OP
Oddometer: 20
Cylinder Hone for twostroke
The Asrto is getting a new ring for the season. I'm looking for a hone with long stones. Any I have found are all 3" stones. I think that could be a problem passing over the ports. Any info out there ?
DGW is offline   Reply With Quote
Old 02-21-2013, 06:31 AM   #2
anotherguy
anotherguy's Avatar
Oddometer: 6,207
Are you talking about sizing the bore or prepping for new rings?
If you're just prepping the surface for rings a ball hone will do the trick.
Sizing the bore is a different story. It's not the length of the stones it's surface area that does it right. You'll need a double stone/guide set-up for sizing to keep the stones from hanging in the ports. These things make doing big bore smokers a pleasant job. Small and medium bores are downright fun with this deal.
Here's a photo on a Sunnen AN-600 head.
Old 02-21-2013, 06:45 PM   #3
DGW OP
Oddometer: 20
I have two years racing on a new bore and piston. I pulled the top end to check everything, so best to put in new rings. I can still see the hone marks on the bore. I was thinking it best to give it a clean up with new rings. If a ball hone will do the job thats terrific.
Old 02-22-2013, 06:43 AM   #4
anotherguy
anotherguy's Avatar
Oddometer: 6,207
What kind of rings? Tell me and I'll let ya know what grit.
Old 02-22-2013, 11:44 PM   #5
darmst6829
Oddometer: 366
Leave the bore alone and just stick new rings into it. The motorcycle will run better then trying to make it better by honing the cylinder. In my humble opinion and years of experience.
Dave
darmst6829 is offline   Reply With Quote
Old 02-23-2013, 01:20 PM   #6
anotherguy
anotherguy's Avatar
Oddometer: 6,207
nah...........
Old 02-24-2013, 03:53 PM   #7
supershaft
Oddometer: 9,110
Originally Posted by darmst6829 View Post
leave the bore alone and just stick new rings into it. The motorcycle will run better then trying to make it better by honing the cylinder. In my humble opinion and years of experience.
Dave
+1
Old 03-01-2013, 05:53 AM   #8
anotherguy
anotherguy's Avatar
Oddometer: 6,207
incredible luck
dave
ftfy
Old 03-01-2013, 02:50 PM   #9
supershaft
Oddometer: 9,110
What do you call incredible luck when most everyone has it?
Old 03-02-2013, 06:19 AM   #10
CharlieT
old school
CharlieT's Avatar
Oddometer: 1,667
Get one of these:
Called a brush hone or flap hone.
Disagree with the gentleman above who stated do nothing. Smokers will develope a glazing on the cylinder walls. Even though you can still see the hone marks, new rings will seat much better and maintain compression longer if you deglaze the cylinder walls first. You only need to run the brush hone thru it for maybe 15-30secs to do this. You will not dimensionally alter the cylinder or damage the existing hone marks, nor will it damage the port edges. All it will do is deglaze the cylinder.
If you have small dainty hands, you can acheive the same thing with some soapy water and a scotchbrite pad. Just do a google search on deglazing a 2-stroke cylinder and you'll find plenty of info and alternatives.
A good bike mechanic only needs two tools, WD40 and duct tape. If it doesn't move, but should, use the WD40. If it does move but shouldn't use the duct tape.
http://www.facebook.com/pages/Checke...22319847810910
CharlieT is offline   Reply With Quote
Old 02-23-2013, 07:28 PM   #11
DGW OP
Oddometer: 20
The cylinder do's look really good. I'm running a two ring Wisco piston.
Old 02-24-2013, 08:39 AM   #12
anotherguy
anotherguy's Avatar
Oddometer: 6,207
Is the top ring a chrome faced ring? If so 320 grit. If it's a moly (bright gray in color) faced ring 240 grit.
They are moving towards a much finer finish than older ringsets. When I don't know I always defer to the manufacturer and every ring manufacturer recommends preparing the bore surface for a new ringset.
Cleaning after the preparation is important. Wash in hot soapy water,dry with compressed air. Then using a lint free towel with WD-40 wipe from the bottom to the top changing the wiping surface until it comes out clean,i.e. no gray honing remnants.
There's no reason to try something that isn't recommended and risk the cylinder in a nice Astro.
Times are GMT -7.   It's 09:51 AM.
