Old 02-24-2013, 05:45 PM   #1
xsf18cdf OP
Oddometer: 94
Question Problem mounting my Motoverland Tail rack....
I was mounting it- very straightforward- 2013 F800. I came to the last bolt and it seemed more snug from the get-go than the others. I finally reached a point that the bolt quit progressing downward into the threads and just kept turning. Did the nutsert inside come loose?.....any ideas?
Thanks,
Gary
xsf18cdf is offline   Reply With Quote
Old 02-24-2013, 05:50 PM   #2
Vandal 62
Mouth Breather
Vandal 62's Avatar
Oddometer: 364
E mail Dave directly at Motooverland first. Best customer service and products I have encountered in a long time. He will help you for sure.
Paul
Vandal 62 is offline   Reply With Quote
Old 02-24-2013, 05:52 PM   #3
duffs
I have a beard
duffs's Avatar
Oddometer: 1,207
Sounds like something stripped... maybe Dave from MOD can help you?
Ride reports: Europe 2014 | Alps 2013 | Fryslân 2012
2012 F 800 GS Trophy 2014 R 1200 GS TE
Blog: Gelände Straßetastic! Facebook Tumblr
Ride reports, photos, tips, experiences, general twaddle
duffs is offline   Reply With Quote
Old 02-24-2013, 06:12 PM   #4
xsf18cdf OP
Oddometer: 94
I think the nutsert is freespinning. The problem is the bolt will not back out now.
Old 02-24-2013, 07:33 PM   #5
ebrabaek
Oddometer: 4,726
You will need to take off the top plastic, so you can gain access to the nut. Most likely the bolt was cross threaded, and the nut is now spinning. You might need to retap the nut after you gain access. When you install the rack again. Begin all 4 bolts just a little before you Torque'em.
Erling
Old 02-24-2013, 09:43 PM   #6
toowheels
on a mission...
toowheels's Avatar
Oddometer: 963
Thanks,
Gary
Hi Gary just saw your email...and your post so I figured I'd answer here since all the info is here anyhow and it's good for everyone to see.
First off sorry to hear about the problem. I know how much it sucks to go to install something and it goes wrong!
Yes the rivnut/ rivet nuts/ nutserts is the problem.
I've heard about it in maybe 1 in 100 installs.
There have been a few threads on it.
This one has a trick that may work for you:
http://www.advrider.com/forums/showthread.php?t=783341
edit**I've just been thinking about the above trick more and before you hammer it down try to leverage the bolt up by the head while you try to unthread the bolt. Maybe the claw end of a hammer if you have the sapce? I'm hoping that by pulling up on the rivnut it will catch enough for you to undo the bolt.**
http://advrider.com/forums/showthrea...hlight=rivnuts
More sources for replacement:
http://www.advrider.com/forums/showthread.php?t=712208
Those should give you an idea to help you get it sorted.
DO ask your dealer if they have seen it and if they can help you out.
It shouldn't happen to a new bike!!
When you do get the bolt out check it and let me know if the threads are messed. I'll send you a replacement one.
Also a note to everybody if any bolt stops threading in smoothly stop immediately, back out the bolt and chase the threads. NOT blaming you Gary! Just want to emphasize the relatively fragile nature of the rivnuts.
Please let me know how it works out too.
Dave
P.S. Thanks for buying our parts!!
Moto Overland [MOD] -Skid Plates, Top racks, Tool Boxes etc for Adventure bikes
www.motooverland.com
toowheels screwed with this post 02-24-2013 at 11:55 PM
toowheels is offline   Reply With Quote
Old 02-25-2013, 09:05 AM   #7
xsf18cdf OP
Oddometer: 94
Thanks Dave. The bike is due its first service. I'll print this and let him have a go at it.
Thanks,
Gary
Old 02-25-2013, 09:07 AM   #8
xsf18cdf OP
Oddometer: 94
Dave, forgot to ask. It it difficult to replace the rivnut- for the dealer? I'm just wondering if he doesn't warrant it how many stacks of bills I'll be handing over.
Thanks,
Gary
Old 02-25-2013, 10:19 AM   #9
toowheels
on a mission...
toowheels's Avatar
Oddometer: 963
Thanks,
Gary
Hi Gary,
No they are very easy if they have the tool (and rivnut) to do it. They are by no means exclusive to our bike either. BMW use on a lot (all?) models. The biggest challenge will be getting the bolt out. Try the edit I suggested above.
On the links above there are sources to buy them and make your own tool to install them. You don't have to buy the tool! The linked explanations show you exactly how to make one and they work the same way. It's pretty simple really. Very thorough explanations, especially #2:
http://www.aulro.com/afvb/projects-t...tool-pics.html
http://www.fjr1300.info/howto/rivnut-tool.html
http://www.ridgelineownersclub.com/f...%2C+DIY+Rivnut
Good luck!
Dave
Old 02-25-2013, 10:36 AM   #10
toowheels
on a mission...
toowheels's Avatar
Oddometer: 963
Yes it's not necessarily a warranty issue. (hey where did itsatdm's post go?)
It could've been the rivnut that was flawed or it could've been the bolt. The bolts do get a rough check when they are put together with the top racks and in my experience it's more to do with the rivnut.
That being said maybe we'll start testing each and every bolt to be sure!
Some dealers are more willing than others so feel it out first.
1. Have they had it happen? (you're "setting the table" here)
2. If so how did they fix it? Do they have the tool? rivnuts?
3. Is it a warranty thing? If not how much will it cost me?
If it costs (too much) and they have the parts :
4. Can I buy the right size rivnut from you?
Then do it yourself.
As I said try to get the bolt out first. Anything you can do to make it fast and easy for the dealer (if you're getting them to do it) will mean less of a headache for them. It's really time they need (want) to charge for.
BTW if you can get the bolt out then try to tap it first, then use the tool to re tighten the rivnut. If that fails (or seems weak) then replace it.
Dave
toowheels screwed with this post 02-25-2013 at 10:41 AM
Old 02-25-2013, 11:41 AM   #11
Mtl_Biker
Mtl_Biker's Avatar
Oddometer: 585
Dave,
I haven't installed the top rack and skid plate you sold me yet (picking my bike up on March 8th), but between the beautiful quality finish and design of your products and the exceptional customer service I see you deliver time after time, I must say I am real happy to be among your clients.
Best regards,
Eldor
Mtl_Biker is offline   Reply With Quote
Old 05-28-2013, 09:10 PM   #12
73datsun
73datsun's Avatar
Oddometer: 270
Guess which dummy just did the same thing?
Brand new bike. Had less then 20mi on it. Went to install my bad ass MotoOverland tail rack, first three bolts went in like butter. Fourth one started to bind. Oh, I'll just give it one more turn.
So after swearing, sweating and twisting, I finally got the bolt out.
Prior to finding this thread, I decided to try to Helicoil. Well that didn't work.
Guess I should have done some digging here, first.
Local hardware store (not a big box), didn't have replacement M8 x 70 (think this was the size) bolts, any other suggestions? I'll look forward to figuring out this rivit nut b.s. when I get back in town.
73datsun is offline   Reply With Quote
Old 05-29-2013, 11:26 AM   #13
toowheels
on a mission...
toowheels's Avatar
Oddometer: 963
I hate hearing this happening to people!!
Nothing worse than trying to install something new on your bike (new bike no less) and it won't work!!
I visually inspect each bolt and randomly check them with a nut too so I know it's not the hardware.
The front bolts are M8 x 60mm and the rear one M8 x 70mm, both stainless flat head socket cap screws of course.
We get a lot of our hardware from Fastenal so check them out. You can check stock online too for a location near you.
Link to one:
http://www.fastenal.com/web/products...Id=&rfqLineId=
Please email me if you need help/questions!
dave(at)motooverland(dot)com
Dave
Old 05-29-2013, 12:07 PM   #14
73datsun
73datsun's Avatar
Oddometer: 270
Great. Fastenall is a Minnesota company. Turns out they have a storefront not far from my house.
The bash guard went on spectacularly. No screw ups there.
Thanks for an excellent product, I really dig your stuff.
Times are GMT -7.   It's 12:41 AM.
