Old 03-08-2013, 03:29 PM   #1
DLvid OP
Oddometer: 37
Fuel pump relay failures
Hi all, I've read many posts that relate to failed fuel pump relays and my story is very similar. My question is what is causing the relay to fail? Specifically the relay is damaged (not visibly) and won't work again. What is happening in the circuit that can short the relay but not blow the fuse?
Some background: Riding at 70 on the FWY, bike suddenly lost all power. After successfully not having a bigger problem, power suddenly resumed after about ten seconds. Rode another sixty miles without incident. At end of day got on bike to ride home and no fuel pump prime with key on. Swapped fuel pump relay with horn relay and got home.
Bike is an 02 GSAdv with 50K miles.
I figured it was just one of those things until it happened again several rides later. Went to start bike and again no fuel pump prime.
Those of you that have had this failure can you report back where you finally found the failure point. I'm going to start at the kill switch and pay close attention to tight zip ties but as you know trouble shooting a wiring harness is not easy. And just for fun, I may pull the HES and check that too...
Thanks for any input.
No good deed goes unpunished.
DLvid is offline   Reply With Quote
Old 03-08-2013, 09:09 PM   #2
roger 04 rt
roger 04 rt's Avatar
Oddometer: 2,224
A couple questions:
Have you tried putting the bad relay back in?
The fuel pump relay powers the fuel pump, fuel injectors and O2 Sensor Heater. Do you have a Powercommander, Techlusion or anything else attached to the injectors?
roger 04 rt is offline   Reply With Quote
Old 03-11-2013, 08:11 AM   #3
DLvid OP
Oddometer: 37
Originally Posted by roger 04 rt View Post
A couple questions:
No, nothing attached to the circuit.
I tested the 'failed' relays and they still 'work'. Putting 12v to them causes them to close as normal but they will not allow the fuel pump to prime. VERY odd. Resistance across the coil is 6 ohms instead of the new relays 1 ohm. There is some micro pitting on the contact closure (found after removing relay from shell). Perhaps there is too much current being drawn... I need to measure the voltage at the relay socket next.
I have installed the new part number relay and it's working (for now). It's not a good feeling when you can't trust your electrics!
Haven't found any shorts yet but will continue to check.
Old 03-11-2013, 08:23 AM   #4
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 52,283
More than likely your relay was bad despite appearances. It is not that uncommon.
Jim
JimVonBaden is online now   Reply With Quote
Old 03-18-2013, 04:21 PM   #5
DLvid OP
Oddometer: 37
Jim
One bad relay I'm ok with. I put the horn relay into the fuel pump position and after a few rides it failed too...
Old 03-18-2013, 05:54 PM   #6
JimVonBaden
"Cool" Aid!
Oddometer: 52,283
If that is the case, it is likely that your pump is failing! A failing pump can cause excessive draw and burn up relays.
Jim
Old 03-08-2013, 11:18 PM   #7
fallingoff
Oddometer: 3,677
on my son's bike he had a erratic fuel pump operation
i tracked down to the wire into the tank
goes thru plastic
wire was broken inside the plastic
so it would work sometimes
just moving the bike and changing the relay
just a thought
cheers
fallingoff is offline   Reply With Quote
Old 03-19-2013, 11:28 AM   #8
baloneyskin daddy
bikaholic
Oddometer: 2,102
Could there be a problem with the fuel pressure sensor that is allowing the fuel pump to overwork itself to the point of a current over draw.
baloneyskin daddy is offline   Reply With Quote
Old 03-19-2013, 07:12 PM   #9
rdwalker
Oddometer: 2,540
On the R1150, there is no fuel pressure sensor in the electrical circuit, pump is always powered.
In the plumbing, fuel distributor regulator relieves excess pressure and routes it back to the tank. If it fails, there will be either too low or too high pressure at injectors, either would affect driveability.
Regardless, overstressed pump would be continuously overloaded and should blow the 10A fuse. If it stays below 10A, it should not affect the longevity of relay contact.
My feeling is that OP's issue is intermittent, as I mentioned above - not likely caused by the regulator. But, of course, that is possible as well. It all depends what tools OP has to diagnose his bike. Fuel pressure could be involved to measure.
Robert in Northern NJ __ '09 R12GS, '03 R1150RT, '01 F650GS
-->> James Bay & North Road Solo Blitz -->> Patagonia / Tierra del Fuego Cappuccino Tour
-->> Trans-Labrador Highway Solo Blitz --->> South African Cappuccino Tour
rdwalker is offline   Reply With Quote
Old 03-20-2013, 05:21 PM   #10
DLvid OP
Oddometer: 37
Thanks, guys. I will perform the checks mentioned and get back to you.
The first thing I did was to replace the fuel pump. Nothing like spending $500 to cover a $15 dollar relay...
This morning the headlights were not functioning, so I replaced the 'load relief' relay and they came back on. Any idea what the function of the load relief relay is?
Old 03-20-2013, 08:02 PM   #11
roger 04 rt
Oddometer: 2,224
When you press the starter button the Load Relief relay disconnects lights, horns, and heated grips. This reduces the load on the battery during starting.
Old 03-20-2013, 09:24 PM   #12
rdwalker
Oddometer: 2,540
The first thing I did was to replace the fuel pump. Nothing like spending $500 to cover a $15 dollar relay... ...
This deed is done, but before you spend any more money on your bike parts, check for the available alternates to OEM. You'd be surprised how much you can save.
A great source is Beemer Boneyard - not only used parts, but also many new ones. Here is the link. They do carry fuel pumps etc. for most models.
Here is an example: oilhead Valeo starter motor is $200, Hall sensor $230.
Old 03-04-2014, 07:19 PM   #13
DLvid OP
Oddometer: 37
Hi all. Wow, it's been a while but the problem has been found. There is a diode related to the Motronic and most of the relays that was failing. My hat is off to Mike at Moto Marin for having the courage to tear apart the fuse box, find the diode, test it and confirm that when warm it was allowing voltage to flow in two directions (not what a diode does). Since this find and repair all is well.
Times are GMT -7.   It's 06:07 AM.
