Old 03-11-2013, 08:14 AM   #1
tilting40s OP
Oddometer: 57
Terrible Milage 07 990ADV
Hey guy's I have a 07 990 Adv and I'm gettin about 90-95 mile before the gas light comes on. I think this is pretty terrible. The bike smells like gas when it runs so I have a feeling its running rich -but it still hauls ass so it runs well. I would love to re map it but don't have a PC nor do I want to go through the hassle of installing windows on a mac/I'm super noob so i don't want to f-up the bike either. I live close to the guy who does Tune ECU in San Rafael CA but I'm concerned he will charge an arm and leg for just leaning it out at critical points/don't really wan the wear and tear of dyno testing on the bike. Any suggestions/ people who have used Tune ECU privately in the bay area? I guess I'm really looking for guidance. Thanks!
-Nick
tilting40s is offline   Reply With Quote
Old 03-11-2013, 12:51 PM   #2
crazybrit
crazybrit's Avatar
Oddometer: 8,552
-Nick
Are you the original owner? Unless someone previously has messed with the map I cannot see how Tune ECU will help resolve a chronic fuel consumption issue such as this.
If someone has screwed up the map, getting it back to stock shouldn't require a dyno. Figuring this out and it's been messed with, returning it to stock, would be my first step.
crazybrit is offline   Reply With Quote
Old 03-11-2013, 01:11 PM   #3
brents347
Trusting my Cape...
brents347's Avatar
Oddometer: 3,802
Do you have the petcock on one tank turned off? Becuase this is TERRIBLE mileage!
07 Yamaha R6
07 KTM 950 Super Enduro
04 KTM 250exc- plated two-stroke
01 Kawasaki KE100
74 Honda MR50
brents347 is offline   Reply With Quote
Old 03-11-2013, 01:14 PM   #4
crazybrit
crazybrit's Avatar
Oddometer: 8,552
This thought crossed my mind also but if he's only draining the left tank I'd expect he'd be hitting reserve before 95 miles (isn't the left tank smaller to accommodate the fuel pump -- so with both tanks on he'd be getting well over 200 before reserve which seems too high) ..... also he said the bike smelled of gas when running ... but yeah it's worth checking.
Old 03-11-2013, 07:48 PM   #5
grinns
Semper Fi
grinns's Avatar
Oddometer: 1,327
It's normal for limp mode if it runs super rich. I would look at it but I am to far. Mine gets usually 42-44 highway maybe 40 with 16-45 worse.
Offroad anywhere from 35 - 40 usually.
It hasn't been that hard of a bike to troubleshoot so far. Maybe that is why mine has stuck around through 10 other vehicles LOL!
2012 300 EC Race
2010 690 R
2014 hypermotard sp
grinns is offline   Reply With Quote
Old 03-11-2013, 02:25 PM   #6
catalina38
Contrarian
Oddometer: 1,633
Running the Akra map? The smell very rich with a gas odor and give very poor mileage.
Clogged or partially clogged MAP sensors will cause poor mileage issues.
A mangy man chasing a cautionary tale
Lurking more and posting less
KTM 990R 500EXC
catalina38 is offline   Reply With Quote
Old 03-11-2013, 07:51 PM   #7
grinns
Semper Fi
grinns's Avatar
Oddometer: 1,327
My bike had this problem. Look down the throttle bodies and post a pic.
2012 300 EC Race
2010 690 R
2014 hypermotard sp
Old 03-11-2013, 08:06 PM   #8
tilting40s OP
Oddometer: 57
I'm going to give it a look tomorrow, and both tanks are drained after a ride that was my first thought. The bike was originally tuned at
http://www.factorypro.com/prod_pages...dventurer.html
It's the bike that he show's the dyno run of so it's a one off map for the leo vince exhaust. I'll take a pic tomorrow and post. Thanks guys.
Old 03-11-2013, 08:38 PM   #9
bikepsych
Oddometer: 225
Not sure but maybe the low octane connector was disconnected somehow?
BG
Bruce
Camarillo, CA
2015 Triumph Tiger 800 XCx
2009 Harley Road Glide
2006 Buell Ulysses
bikepsych is offline   Reply With Quote
Old 03-12-2013, 06:42 AM   #10
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,997
I remember LITO had a similar problem
I cannot remember how but he found a solution. I think more recently VioLator had similar issues. I cannot remember if he solved it though.
Cheers.
gefr screwed with this post 04-26-2013 at 04:00 PM
Old 03-11-2013, 03:20 PM   #11
speedy 1
Wizard
Oddometer: 16
43.5 mpg
43.5 mpg is the average mine is posting
this is commuting 120 miles round trip
fuel light comes on at 175 ~ 180 miles
brents347 has a good suggestion ... both fuel tanks on ?
speedy 1 is offline   Reply With Quote
Old 03-11-2013, 03:30 PM   #12
LocuL
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,326
Would a faulty Lambda make it swallow gas?
KTM 950(1190) Adv-s, Soon to be Project 1190
KTM 530 EXC-R 08
LocuL is offline   Reply With Quote
Old 03-12-2013, 04:00 PM   #13
catalina38
Contrarian
Oddometer: 1,633
Check out a parts fiche on one of the online parts sites to see where they are.
munnracing.com
KTM 990R 500EXC
Old 03-12-2013, 04:17 PM   #14
DSM8
Where fun goes to die....
DSM8's Avatar
Oddometer: 3,920
http://65.57.254.60/shoponline/catal...76014100%2Egif
# 60 IIRC
Follow the vacuum line from the underside of the throttle bodies to where it plugs into the sensors. I don't know what side of the throttle bodies they are on.
Here is a pic of one from my bike. See the line coming out of the intake tube going to the sensor on the frame rail.
Other side of bike
One more
DSM8 - A different kind of mean
SQL > SELECT finger FROM hand WHERE id=3
http://share.findmespot.com/shared/f...d5LbKWMz6cHxaH
DSM8 screwed with this post 03-12-2013 at 04:23 PM
DSM8 is offline   Reply With Quote
Old 03-12-2013, 04:52 PM   #15
catalina38
Contrarian
Oddometer: 1,633
The brass fitting being pointed at has a 1mm hole that gets clogged. Use some thing just a bit smaller than 1mm and clean the hole. One side is easy to get at the other not so much.
KTM 990R 500EXC
Times are GMT -7.   It's 10:05 PM.
