Old 03-14-2013, 10:58 AM   #1
pdxmotorhead OP
pdxmotorhead's Avatar
Oddometer: 733
Fitting on oil filter housing..
I noticed on the front of the housing part of the case for the oil filter is a plug, In some dry sump systems on cars this is where I would put a oil pressure fitting? Filter pressure should be oil main pressure correct?
Theory's ? Thoughts?
Dave
pdxmotorhead is online now   Reply With Quote
Old 03-14-2013, 10:57 PM   #2
Zuber
Zoob
Zuber's Avatar
Oddometer: 1,983
Have to check, but not so on this motor. The filter is before the oil pump and may be under suction. For a pressure sensor, why not Tee off the location of the factory pressure switch?
"Son, you can't do both"
Old 03-15-2013, 12:18 AM   #3
pdxmotorhead OP
Oddometer: 733
Cause the oil pump fitting is easy to get at.. :)
I was going to use the pressure sender port with a T,, but while changing my oil got to looking at that fitting.. I hope the filter is after the supply pump like most engines,, suction on a paper filter is bad..
Cheers
Dave
Old 03-15-2013, 04:26 AM   #4
Orangecicle
Orangecicle's Avatar
Oddometer: 2,562
Which is a good reason to run a Scott's!
Orangecicle is offline   Reply With Quote
Old 03-15-2013, 08:47 AM   #5
DirtyADV
DirtyADV's Avatar
Oddometer: 2,234
Would guess its suction since the filter collapse if restricted cause of water contamination.
/Johan
Have changed name, was previously Dirty950
www.dirtyadv.com (under construction)
DirtyADV is offline   Reply With Quote
Old 03-15-2013, 05:29 PM   #6
pdxmotorhead OP
Oddometer: 733
Could be either,, if its under pressure,, its pressure from the outside in,, so it would collapse when the water fouled the element.
Hopefully I am past that problem for a while with the new CJ kit in there! :)
DAve
Old 03-16-2013, 12:12 AM   #7
Masa
Masa's Avatar
Oddometer: 297
Pressure pump is before the filter and oil flows from outside to inside of filter.
Oil pressure taken from the filter housing wouldn't inform about clogged filter - right?
Masa is offline   Reply With Quote
Old 03-16-2013, 12:23 AM   #8
pdxmotorhead OP
Oddometer: 733
I figured if you check it with a new filter and the filter water fouls the pressure should climb letting you know its plugged..
But on thinking on it,, it may just dump all the oil out the relieve valve.. Hmm.
Dave
Old 03-16-2013, 01:09 AM   #9
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,915
Dave
Relieve valve? is there a relieve valve?
Old 03-16-2013, 05:01 AM   #10
Masa
Masa's Avatar
Oddometer: 297
I suppose you would get higher pressure on low rpms, before the pressure regulator's working window.
You could tap the line for the gauge to either of the cam tensioner bolts, as others have done.
Old 03-16-2013, 03:36 PM   #11
pdxmotorhead OP
Oddometer: 733
Ok,, I admit it,, I'm a gauge freak.. So I have a new more better idea for that port, I'm going to use it for an Oil Temp guage.. and put a T on the pressure sensor (Factory location) for the pressure guage..
Eventually I'll have, Oil Pressure, Oil Temp, Exhaust temp, Cyl head temp. Via a single quad display, havnt decided on needles or digital yet... Its a sickness..
Dave
Old 03-16-2013, 05:14 PM   #12
Katoom72
Katoom72's Avatar
Oddometer: 861
Dave
Damn, is that some catchy virus or something?
Now:
'03 KTM 250sx -- '05 KTM Adventure 950
Before:
'00 KTM 250sx -- '03 KTM 450sx -- '03 Yamaha R6 -- '08 KTM SuperDuke R --- '13 KTM 690 enduro R
Katoom72 is offline   Reply With Quote
Old 03-17-2013, 11:29 AM   #13
pdxmotorhead OP
Oddometer: 733
I don't know,, I guess its a racing thing,, I maintain track cars for other people on the side, while I don't tune with them knowing all the temps and pressures has helped me head off bad things before they happen..
Now I feel like I forgot something if I don't know the voltage, oil pressure etc..
Cheers..
Dave
Times are GMT -7.   It's 06:57 PM.
