Old 03-20-2013, 10:23 PM   #1
canuckle head OP
Oddometer: 3
klack klack klack
I just picked up a 2004 950 adventure in trade. Got my new prize home and started to give it the love and attention it so badley deserves. When I picked it up it made some engine racket when cold but went away once the engine got to operating temp, buddy said no big deal had alwas done this. Not donted by a challange here I are. I found your site and began to learn about my prize. One dude talked about the oil bypass spring and it was possible here in was my answer. I drained the engine oil (way past it's shelf life) removed the offending spring, stretch,tug, pull, reinsert and assemble. Fill with 10w/50, coolant and to my suprise klack-klack-klack !!!! Again asoon as the engine reaches 100c to 110c it becomes quiet ish. So talk to my local KTM dealer... WELL COULD BE THE P47 OSSILATOR TUBE OR THE GIMSON VALVE RETURN SPRING. BETTER BRING IT IN. Hange up the phone, make note to self to find new dealer next week. I've read about cam chain tensioners and cam chains and ballance shaft interferance but it's the change in noise at temp that gets me. So next is to check oil pressure, but I think it's o.k as the light goes out after start up. One thing I did notice is that if the engine rpm is left below 1250 klack-klack-klack is back. Looking for any insight befor I tear it down to expose her shinney bits.
canuckle head is offline   Reply With Quote
Old 03-20-2013, 11:00 PM   #2
rossguzzi
990 Adv.
rossguzzi's Avatar
Oddometer: 971
Perhaps oil pump worn, slightly blocked oil gally somewhere?
rossguzzi is offline   Reply With Quote
Old 03-20-2013, 11:06 PM   #3
Two Moto Kiwis
Homeless Somewhere
Two Moto Kiwis's Avatar
Oddometer: 3,833
Water Pump
Check the oil filter for a wavey patten, could be a knackered waterpump with coolant in the oil.
When the oil warms up it flows through the wrinkly filter better than cold and your symptoms sound very much like this.
Pull off the clutch cover on the RHS and see if it looks like a Latte inside, easy to check this.
Andi (oveja negra) & Ellen (chica amarilla)...Two Moto Kiwi Grüvers .....riding Maya somewhere ..Una Chimba
Two Moto Kiwis Home Page ..Danger Is Real ... Fear Is Optional
For More Of Two Moto Kiwis Photos
....Where The Hell Are We .. Spot Us
Two Moto Kiwis is offline   Reply With Quote
Old 03-20-2013, 11:10 PM   #4
Zuber
Zoob
Zuber's Avatar
Oddometer: 1,988
Well, first off it should idle at 1400 rpm. That should help a little.
The cam chain tensioners do go bad and make a terrible noise, usually at low rpm, cold engine startup and then when the engine gets very hot. They are about $80 each and are easy to change. If raising the rpm helps but doesn't get rid of the noise, then new cam chain tensioners will probably fix it. It fixed my early 05 model. Later CCT's were made better.
There is also a torque adder loose bit on the clutch, but it usually doesn't make much noise. Noise is while under way.
There is also a clutch on the starter motor that makes a horrible noise, but only on starting. The early 04 models did not have this.
Lots of discussion about this.
"Son, you can't do both"
Old 03-20-2013, 11:38 PM   #5
gunnr
optimsm
gunnr's Avatar
Oddometer: 290
My 06 was doing the same thing. Cam tensioners were klacking due to low oil pressure until it warmed up. Although my light was not coming on. I replaced the piston and spring in the pump. That fixed it. I wished I would have replaced it when I replaced the waterpump.
gunnr is offline   Reply With Quote
Old 03-21-2013, 04:17 AM   #6
Apple Jam
Forest Flyer
Apple Jam's Avatar
Oddometer: 6,437
07, same story.
Just did the CCTs, not too hard. Oil pump rebuild is next.
Along with valves and fresh plugs.
It's my first time this deep into the beast.
So far, it's all straight forward.....
"got no problem with keeping truly roadless areas as wild....
On the other hand, if it has been logged or mined and roads already exist,,
...then that land should be open for public use" (peterman)
Apple Jam is offline   Reply With Quote
Old 03-21-2013, 06:29 AM   #7
gunnr
optimsm
gunnr's Avatar
Oddometer: 290
Originally Posted by Apple Jam View Post
07, same story.
Yeah it's pretty straight forward once you get to the motor.....
Old 03-21-2013, 09:38 PM   #8
canuckle head OP
Oddometer: 3
The next step
Thanks for the info. Like I said the next step will be check the oil pressure both hot and cold. It only has 31000k but might have been riden hard and put away wet ? I did change filter when it was appart for the bypass spring but did not pay attention to the pleats (coolant in the oil).Still stumped about the noise going away with engine temp, you would think that as the oils becomes thinner things like the hydraulic assisted cct would leak worse and the noise would stick around to continue to irritate. Will keep you posted.
Old 03-22-2013, 08:58 PM   #9
Stephen
Stephen's Avatar
Oddometer: 3,191
I wasn't gonna say anything..
I wasn't gonna say this, but after compulsively reading this, I just gotta.
My 04 has, since new, rattled like crazy on startup, then settled to its properly cacophonous symphony of mechanical bliss before it's even warm enough to drive. It still does. All the pre-06 ones that I've been around do. It doesn't bother me. In fact, I like the clackalacka better than the constant whirring of the later bikes. Not that it ever bothered me riding my friend's 06 around Idaho. I reckon it's just different ways for engines to be.
IIRC, the startup racket started bothering Pyndon, and he described updating to 06 cam-train and uprating the oil pressure thing in his epic maintenance thread.
If it really bothers you, there's your fix, but I'm not convinced the noise means anything is wrong. If mine blows up I guess you get to laugh.
Stephen is offline   Reply With Quote
Old 03-24-2013, 07:39 AM   #10
Oz Nutter
Oddometer: 1,251
Wink
Never worried me, and I owned an Africa Twin before this.
Yes the 04 rattles, done 70000kms still rattles, no worries, ride on
Oz Nutter is offline   Reply With Quote
Old 03-24-2013, 09:05 AM   #11
GZERO
GZERO's Avatar
Oddometer: 263
just so you guys know, i have change many timming chains that rattle a lot, and after doing so the bikes had more power.
Why is this you ask?
easy, when a chain stretches the timming goes off by a few degrees at the most, but those few degrees makes you loose a little power.
Need some parts? shoot me up an mail and i'll quote it to you.
gsiblesz@hotmail.com
GZERO is offline   Reply With Quote
Old 03-24-2013, 07:58 PM   #12
Bugman98
Oddometer: 207
I have an 04 950 that did this. It would make a lot of noise, and after about a year of being told the noise was "normal " the oil light started coming on when the engine temp was hot. i figured that was not normla! I replaced the entire oil pump (spring, piston, housing,etc) for about $60 and it solved all my problems. The engine still clakety claks but its not nearly as loud.
Bugman
Norman, OK
Wind in my hair, bugs in my teeth!
Bugman98 is offline   Reply With Quote
Old 03-24-2013, 10:00 PM   #13
canuckle head OP
Oddometer: 3
double stack
So I tested the oil pressure and it's 28 psi @ idle and 48 @ 5000 (hot). After poking around a bit I removed the rear cct and noticed two copper washers stacked under the retaining nut. I checked the cct and found oil bypassing the plunger so will order a set on tuesday. I assembled the engine with only one copper washer under the nut and flashed it up. The klack klack klack is gone, so that much differance in depth must make just enough change for the tired cct to stay in contact. I'll work my way through the rest of my list and go ride it after all my parts are in. Thanks for the helpfull hints!
Times are GMT -7.   It's 05:02 AM.
